| Subject: Merkava Mk IV |
 | Cory Sutton corsutton | Location: Oklahoma, United States Member Since: June 17, 2005
Posts: 252 entire network,
224 this site
| Posted: Wednesday, February 11, 2009 - 11:54 AM UTC |
I received my Academy Merkava Mk IV today and already started it. I plan on doing this as a Blog. I will get some pictures up soon. Today I have already masked off all of the top surface of the hull and turret. I then sprayed Rust-Oleum Multi-Colored Textured paint to simulate the rough uneven non skid so prevalent on IDF vehicles. It worked great and I am very excited about how it looks. Like I said, I will get some pics up soon. Until next time. |
| HIDE SIGNATURE AREAS |
224 this site
| Posted: Wednesday, February 11, 2009 - 04:20 PM UTC |
 | Bob Johnston Gt351 | Location: Tasmania, Australia Member Since: July 26, 2003
Posts: 130 entire network,
103 this site
| Posted: Wednesday, February 11, 2009 - 07:55 PM UTC |
Hi there, nice work you have there, will be interesting to see under a coat of paint, what did you use for the masking off, looking forward to seeing more, cheers Bob. |
 | Mike Land Kelley | Location: Georgia, United States Member Since: November 21, 2002
Posts: 1,728 entire network,
1,431 this site
| Posted: Thursday, February 12, 2009 - 01:17 AM UTC |
Nice start Cory, I have this one sitting on my desk as well, I'm working on an inbox review for the site, so I'll be keeping an eye on your blog. A comment and a question: The area around the smoke grenade launchers on both sides of the turret has a part that should be attached there, I can see you masked the right side ones off but not the left side, did you glue the part on the left side already, or maybe you haven't removed the masking fluid yet? (I hope  ) Also, does your kit have any non-skid molded on? Mine does not, but others have said their kit does have it (although very understated). Mike |
224 this site
| Posted: Thursday, February 12, 2009 - 01:12 PM UTC |
Kelley: I had not removed the liquid mask as yet on that left panel. If you look real close you can see a light blue tint on that panel. There was no non skid molded in the kit. I used what photos I could to figure where the non skid was.
Gt351: I used Micro Scale Liquid Mask for the masking. It worked great. It took a little time to apply then remove after the non skid was applied, but the result is good.
I started some construction today, not much, but I started. Right away ran into two problems. First was those stupid motor holes in the bottom of the hull that need to be filled, They were huge. I used a bunch of styrene rod to fill most of them, then putty and glue. The back door frame came with 8 sink hole marks on the outside of the part, where the detail is. The inside surface was flat on doesn't show at all. They should have turned this part over and put the sink holes on the back side. Oh well, a little putty and careful sanding and all is good. More pics soon. |
 | Wayne CB1000h | Location: Pennsylvania, United States Member Since: March 01, 2006
Posts: 225 entire network,
180 this site
| Posted: Saturday, February 14, 2009 - 01:05 AM UTC |
Nice start I just got mine 2 days ago as well and I have the Textued spray can Can you post more pics I am kinda nervous about using it this would be the first |
| My other vehicle is a Stryker | | |
 | Evan punisher2-2 | Location: North Carolina, United States Member Since: January 01, 2009
Posts: 50 entire network,
44 this site
| Posted: Monday, February 16, 2009 - 03:00 PM UTC |
Looks good man, I've got mine on standby. I'm still fairly new to the 1/35 scale so I have a few questions about the non-slip texture. First after the mask is applied and then the non-slip texture was added...how do you remove the liquid mask? Also I've seen a few diff. types of this liquid masking so is one more preferred than the other or does it just come down to availability? Well thanks in advance for all the help...and I'm sure I'll have more questions as you move along with your blog. Thanks! |
 | Keith Forsyth docdios
Managing Editor Features
|  | Location: England - West Midlands, United Kingdom Member Since: December 01, 2001
Posts: 1,451 entire network,
923 this site
| Posted: Monday, February 16, 2009 - 03:22 PM UTC |
I saw one built up on a stand at at model show in Huddersfield on Sunday, it looked a real nice kit. The modeller had replaced the rear hull baskets with resin items as well as the wheels. he hadn't added any form of anti slip, as yet (and having built the kit may not be able to) and the kit wasnt painted but it looked a nice representaion of the mark IV I would have posted a couple of pictures if I had taken my camera to take some with  cheers keith |
| A VETERAN - Whether active duty or retired is someone who, at one point in their life, wrote a blank check made payable to "Great Britain", for an amount of "up to and including my life". That is HONOUR, and there are way too many people who forget this | |  |
224 this site
| Posted: Tuesday, February 17, 2009 - 07:18 AM UTC |
Here are a few pics of the turret, 90% finished. I just need to add the guns and the stowage in the basket. Next is the hull and tracks. I am going to use the kit tracks. Let me know what you think.   Here is a shot of what I used to fill the motorization holes on the bottom of the hull. After this set I topped it with green putty and sanded it back to shape.  punisher2-2: I use Micro Mark liquid mask. It dries to a clear blue color and is easily trimmed. After the non skid is applied, just use a sharp blade and pick the liquid mask off. If you are lucky, you can get major sections off as one. If not, like me, then you need to pick at it and pluck off small bits with pointy tweezers. |
224 this site
| Posted: Saturday, February 21, 2009 - 02:26 PM UTC |
A little update. Well, I have finished the turret and hull and am ready for some painting. The biggest problem I have run into is with the main gun. The locating cutout was misplaced, making the barrel go into the mantlet on its side. I had to cut a chunk out of the top of the barrel base to make it fit correctly in the mantlet. Easy fix, but disappointing. Anyway, heres a some pics.  A close up showing the corrected locating mark. |
 | Julian Lewis juljon | Location: England - South East, United Kingdom Member Since: March 10, 2008
Posts: 40 entire network,
39 this site
| Posted: Monday, February 23, 2009 - 10:33 AM UTC |
Hi,
I have had the same problem regarding the placement of the gun into the turret. Thanks for the info. Hobby Boss Merkava 4 is being released around June 2009 this was confirmed by Hobby Boss to me by email today.
Regards
Juljon |
 | John Charvat Tankrider | Location: Oklahoma, United States Member Since: October 07, 2002
Posts: 553 entire network,
537 this site
| Posted: Monday, February 23, 2009 - 01:28 PM UTC |
Cory, Nice work. I am interested to see the textured paint under some primer. When are ya'll meeting at HT USA next??? I want to see your work in person. John |
John Charvat
"Hey baby, I only ride 'em, I don't know what make them work" Oddball
 | Matan metooshelah |  | Location: Jerusalem, Israel Member Since: February 06, 2009
Posts: 542 entire network,
464 this site
| Posted: Wednesday, February 25, 2009 - 01:22 AM UTC |
I was thinking on buying that model, but i have poor experience with academy models. I've built a "magach" once, as a present for a friend, and I hated every minute of it. How is this model going for you? do the parts fit, or you have to put some muscle into it? I had a pain building that "magach" : |
George: "If we do happen to step on a mine, Sir, what do we do ?"
Blackadder: "Normal procedure, Lieutenant, is to jump 200 feet in the air and scatter oneself over a wide area."
'AMPS-Israel' VP | | |
 | Dan-T Panzerfan | Location: Mexico Member Since: May 31, 2002
Posts: 24 entire network,
24 this site
| Posted: Friday, February 27, 2009 - 07:29 AM UTC |
Hello:
I'm wirting from México. Your work in that Merkava is great, but I have a question.
You said that used "MULTICOLORED TEXTURE PAINT" to replicate the anti-slip surface of your tank. Could you explain me what kind of paint did you use?
I like the results you get, but I never heard about that paint before.
If you can put pictures of the paint can will be great
Let's hope you can help.
Best Regards. |
 | Tim Kelly tjkelly | Location: Maryland, United States Member Since: May 04, 2007
Posts: 1,122 entire network,
1,114 this site
| Posted: Friday, February 27, 2009 - 09:00 AM UTC |
Good start Cory, nice use of the masking to keep the texture off those unwanted spots. Keep at it, looking forward to seeing it with some color as well to see how your technique worked. Thanks for sharing! Cheers - Tim |
Current projects:
AFV 8.8cm Flak 18 (35088) (paint stage)
Academy Warrior MCV (OIF) (final touches...then paint)
Next up:
Revell A-6E Intruder (?) | | |
 | calvin calvin_ng | Location: New York, United States Member Since: June 23, 2008
Posts: 848 entire network,
677 this site
| Posted: Friday, February 27, 2009 - 10:13 AM UTC |
Dan the paint he uses might not be sold in mexico, if it is its under the name "rust-o-leum terracotta" hope you can find it calvin ng |
 | Glenn Ryder tachikawa | Location: Washington, United States Member Since: June 07, 2008
Posts: 38 entire network,
6 this site
| Posted: Sunday, March 01, 2009 - 12:29 PM UTC |
Cory- Did you spray just one coat of 'terra-cotta' paint on the turret? Or are we seeing several coats built up? BTW nice job so far!
Glenn |
224 this site
| Posted: Sunday, March 01, 2009 - 03:23 PM UTC |
Allright, I'm going to try and answer all the latest questions. First off, a picture of the paints used to simulate the non-skid. I have a picture of both kinds I use. The Terra-Cotta one is used for most country's non-skid. It creates a nice, even, rough surface. The other paint is the Multi-Colored Textured paint that I use for IDF vehicles. It gives a rough, uneven surface, much like the IDF's non-skid.  Here are some shots of the primer I use and the primed Merk.    I found my paints in Walmart and Lowes. I'm not sure about Mexico. Hopefully with the pictures you should be able to find it or something similar. Good luck. Tankrider, the next meeting is this coming Friday, March 6th, at 7pm. |
224 this site
| Posted: Sunday, March 01, 2009 - 03:33 PM UTC |
Metooshelah, sorry I missed yours. Overall the fit has been pretty good. I have had to use a little filler to fill some misplaced sink marks. I used a little filler on the turret hatch, but not much. The barrel has a misplaced locating tab as mentioned earlier. Some of the seam lines are a little heavy but its not that big a deal. I built the Academy M-60 Blazer with mine rollers several years ago and I don't remember having that many problems with it. I will say that this Merkava Mk IV has gone together pretty smoothly. |
224 this site
| Posted: Monday, March 02, 2009 - 07:44 AM UTC |
I just found that Legends released a Basket set for the Merkava Mk IV. Since I was planning on this tank being in service I decided to order this set. I am waiting for this to arrive so progress has stopped for the moment. On to the M113 Zelda. |
 | hugohuertas | Member Since: January 26, 2007
Posts: 17 entire network,
16 this site
| Posted: Tuesday, March 03, 2009 - 05:36 AM UTC |
It seems in the pics that applying the textured paint covers the numerous bolts that are a characteristic of this tank, and that are tiny molded on the surface of the model Am I right? |
180 this site
| Posted: Tuesday, March 03, 2009 - 06:23 AM UTC |
I used the same textured paint as above and I used liquid mask to cover the hinges and bolts etc. prior to using the textured paint I believe it was also used on this built as well I takes time but it is worth it The build looks good Cory I also ordered the Legends stuff I got about as far as you and am waiting for ther parts too should be here on the 12th |
 | Alberto Alberto_Solis | Location: Puebla, Mexico Member Since: November 20, 2008
Posts: 3 entire network,
2 this site
| Posted: Tuesday, March 03, 2009 - 07:03 AM UTC |
hello Dan-T, you can find that "MULTICOLORED TEXTURE PAINT" in The Home Depot, I have seen before that product, and it cost $ 50.00 pesos, Sorry for my english. . . |
224 this site
| Posted: Tuesday, March 03, 2009 - 09:26 AM UTC |
Hugohuertas: yes the textured paint did cover the bolts, however they are still very prominent. The liquid mask does take some time but actually works very good. I am very happy with the result. After the Legends set gets here and I can move on, I will get some colored paint on there and it should look pretty good. |
16 this site
| Posted: Tuesday, March 03, 2009 - 11:18 PM UTC |
Good to know this, it would be a shame if the bolts were covered!!! |
 | Chandler Cody Northwestern | Location: Nevada, United States Member Since: May 03, 2007
Posts: 167 entire network,
116 this site
| Posted: Wednesday, March 04, 2009 - 10:37 AM UTC |
Hey Man The tank is looking awesome, I have this on the shelve, but it's going to be a while before I build it If you are going to do a base for it or a diorama, this video can give you ideas http://www.youtube.com/watch?v=vjVg4Bdri8Y |
Compulsive Modeler by Hobby, Maintainer of F-16's by Trade
USS Enterprise CV-6, May her memory live on forever in our minds and hearts
Take my advice! "Pull down your pants and slide on the ice" Major Sydney Freemen, M*A*S*H | | |
224 this site
| Posted: Wednesday, March 11, 2009 - 01:30 PM UTC |
Northwestern: Thanks for that link. That was a pretty awesome video. I can't wait to get the basket set here so I can finish the kit. This will only be the first of these I build. I will get another one and super detail it. |
 | Javier Beitia Tranquilito | Location: Panama Member Since: November 15, 2008
Posts: 15 entire network,
14 this site
| Posted: Thursday, March 12, 2009 - 09:57 AM UTC |
Removed by original poster on 11/06/09 - 21:48:13 (MST). |
464 this site
| Posted: Sunday, March 15, 2009 - 08:27 PM UTC |
you forgot some anti slip in the commander's hatch and gunner sights as well. |
14 this site
| Posted: Wednesday, March 18, 2009 - 03:34 AM UTC |
Removed by original poster on 11/06/09 - 21:48:52 (MST). |
