Яusso-Soviэt Forum
Dragon BMP-2 with AEF sets
bison126
Correze, France
KitMaker: 5,222 posts
Armorama: 5,097 posts
Posted: Sunday, March 22, 2009 - 05:23 AM UTC
Hi all,
despite I'm stuck with the turret interior I tried to have some progress with this kit.
I shifted to the upper hull. Basically AEF hull is a re-molding of Dragon one with the rear hatches properly aligned.
But doing so AEF forgot some Dragon inital mistakes. Moreover AEF missed some details present on the Dragon kit.
Here are some pics to show what I did
At first, I corrected the front access hatch location. I filled the former one with CA glue and engraved a new one. It's not perfectly straight though ! The hinges are still to be added.
Then I modified the position of the rounded thnigie with bolts on its top. I enlarged the bolted hatch near the turret and repositioned and hollowed the small air vent on the right.
I cut off the vision blocks and repositioned them all. Dragon and AEF got it wrong with the vision blocks. Their position and alignement were off.
The next picture shows the details present on the Dragon hull that AEF missed.
As you can see, I've still a long way to go ! But the exterior is a pleasure as compared with the interior. I begin having a clear idea of the troop compartment and the driver station. The turret floor is growing clearer too but the sights locations are still to be guessed !!
Olivier
Removed by original poster on 03/22/09 - 18:18:15 (GMT).
Jacques
Minnesota, United States
KitMaker: 4,628 posts
Armorama: 4,496 posts
Posted: Sunday, March 22, 2009 - 08:55 AM UTC
Very good start. I am glad to see you trying this out and it looks like a good model will come out in the end. It also shows just how far off DML was on the BMP kits...and why they need a nice new fresh kitting!
bison126
Correze, France
Posted: Sunday, March 22, 2009 - 08:21 PM UTC
You're right and if the general rule confirms, as soon as I complete this model a brand new plastic kit will reach the shelves !!
So cross your fingers that I finish it
BTW any pics or drawings of the turret interior are welcome.
Olivier
Minsk94
Wisconsin, United States
KitMaker: 418 posts
Armorama: 408 posts
Posted: Monday, March 23, 2009 - 07:29 AM UTC
I don't know if you have this link: http://www.thetankmaster.com/ENGLISH/afv/bmp-2_01r.asp but there are 47 pics of the exterior of BMP-2
bison126
Correze, France
Posted: Monday, March 23, 2009 - 08:41 AM UTC
Thanks Alex, I already knew this excellent site. I got your mail, thanks for that too
Olivier
bison126
Correze, France
Posted: Saturday, March 28, 2009 - 03:06 AM UTC
Hi all,
having found some interior pictures (thanks Alex) I started to detail the turret floor. In fact, AEF have oversimplified it. I deleted the seats supports and a kind of electric box. I made from scratch the ammo storage boxes all around the floor and added the poles that link the floor to the turret ring.
The empty sheel case (?) and the co-ax ammo magazine (the beam-like part) were modified as well. First, the case misses the front panels so I made them with plastic card. Then I thinned the co-ax magazine so that from a square section it turns into a rectangular one.
In the same time, I started modifying the turret exterior. To put in a one word, this is scrap !! The turret is wrong in many respects and fixing that needs a considerable amount of extra job. So I decided to fix only some tweaks.
First, the hatches holes are to small and ill-placed and mis-shaped ! The vision blocks must be moved forward on the left station.
The smoke dischargers are too aft and will be moved rearward. To start with, their location holes are filled. The armored cable is removed, it will be replaced later.
Comments welcome.
Olivier
PS: stupid question maybe, but where does the gunner sit ?
Minsk94
KitMaker: 418 posts
Armorama: 408 posts
Posted: Saturday, March 28, 2009 - 03:36 AM UTC
Hi, Olivier
Looking great! Honestly, looking at the page of AEF instructions you sent me, I am surprised how anyone can built anything using them?!
...where does the gunner sit ?
The crew consisted of only three people.
Page 65 of the Manual, illustration 29:
7) brackets for gunner/operator's sit
14) brackets for comander's sit
Illustration 30 - the sit itself
Jacques
Posted: Saturday, March 28, 2009 - 03:57 AM UTC
Gunner sits on the left, commander sits on the right.
IIRC, in the BMP-2 the infantry commander (dismount squad commander) sits behind the driver.
bison126
Correze, France
Posted: Saturday, March 28, 2009 - 08:58 AM UTC
Thanks Alex and Jacques, you confirm what I thought. I was not sure as looking at the interior pics I have, the commander station appears much more fitted with sights and controls than the gunner's one.
I think I'll finish the work (mods) on the turret exterior tomorrow and post pictures.
Olivier
bison126
Correze, France
Posted: Sunday, March 29, 2009 - 06:50 AM UTC
Small update,
I added some details on the exterior, re-locate the left vision block (nearly cut off one of my finger with my dremel doing that ).
I also started to fit the AEF parts inside A lot of dry fitting, sanding and reference checking. Fortunately when it's complete, the inaccuracies won't be that noticeable.
Olivier
bison126
Correze, France
Posted: Saturday, April 04, 2009 - 07:06 AM UTC
Here I am again.
I started to fit AEF turret interior parts. Trying to guess their location on the poor instruction set, I finally gave up and shifted to the TM sketches to help in the process.
The TM and the Kagero book show many parts omitted by AEF so I decided to add some of them. All the white parts are scratchbuilt.
I had to make a second control unit for the turret at the gunner station, I added some radio and electronic device in the turret "bustle". With the help of pictures, I did the back of the 2A42 gun from the wrong AEF part and added the co-ax PKT. Next step will be the Konkurs control system and a spare missile on the turret floor near a kind of bottle (extinguisher ?)
Here are the pics
Some parts on the turret floor are just put in place with Patafix (kind of Blutac). The painting of the floor requires to have the seats and the PKT ammo magazine apart.
Olivier
Jurjen
Groningen, Netherlands
KitMaker: 3,040 posts
Armorama: 1,016 posts
Posted: Sunday, April 05, 2009 - 03:53 AM UTC
Hi Olivier,
you have done some serious work! Do you consider to add some additional wires? Keep up the good work.
bison126
Correze, France
Posted: Sunday, April 05, 2009 - 06:00 AM UTC
Hi Jurjen,
I will do but only the most visible ones as the turret interior will hardly be seen from the hatches. I have some black wire for homemade jewelry that will do the trick and save me some extra painting job
PS: @ Jacques, I do hope Sergej's upper hull is correct dimensionally wise. I just noticed that AEF one is too short approximately by 2mm and that the sides are not at the right angle and so the hull does not sit on the lower hull in the right way
Olivier
Jacques
Posted: Sunday, April 05, 2009 - 11:57 AM UTC
The best answer I have is this link to the SAAM sight showing one I built a while ago.
I would say that it is a improvment over the DML details, and the length was perfect for use on the DML kit, but as for angles and such, probably not. This is Sergej's dilemma: He knows how bad the DML kit is compared to the real thing. Recently he discovered that the DML and Esci kits are both probably 5mm too wide! But this woudl involve a whole new lower hull as well as upper hull...along with all the other known problems, such as running gear, tracks, etc... Sergej is discontinuing both kit 118 and 128 as he is having a heck of time casting the upper hulls without miscasts, and he is not selling very many upper hulls. He will keep kit 123 and 124 in production until the molds wear out. But he wants to concentrate on more lucritive areas of modelling, like the T-80 series.
Anyhow, you are doing very good work and I hope it inspires Miniarm to finally come out with their complete resin kit, but...
bison126
Correze, France
Posted: Sunday, April 05, 2009 - 06:42 PM UTC
Hi Jacques,
I knew of your page about Sergej's hull. On your pics, it looks OK but one can never really know from pics and if you made some fitting work. Obviously, AEF one will need some. Maybe the upper hull width has been fixed, it's narrower than Dragon one by 2mm at the rear, but same width at the front ?!
Miniarm are on their way to a full BMP-2 but I'd rather see Trumpeter popping up with a plastic one ... not at the BMP-3 and T-62 speed however
bison126
Correze, France
Posted: Saturday, April 11, 2009 - 07:07 AM UTC
Latest update with the turret interior painted. I tried to dryfit it to the hull and faced some issues I'll address later on. To put it quickly, the turret will pop up from the hull roof if I don't shorten the support poles. I followed AEF instructions by cutting rods of 3cm long which is obviously inappropriate.
I added some details to the AEF parts : the gun rear part, the coax MG (nearly invisible !), the gunner controls (AEF only give the commander's), the Konkurs missile control (not accurate as I had only one drawing of its left profile, I "guessed" the right one).
To the floor, I added the fire extinguisher and the missile. The stencils are masking tape bands painted black with some silver to represent the letters.
Olivier
Reiter960
KitMaker: 503 posts
Armorama: 500 posts
Posted: Saturday, April 11, 2009 - 12:33 PM UTC
I think you are doing great work on this rather mediocre piece of resin. Keep it up
marsiascout
Noord-Brabant, Netherlands
KitMaker: 1,247 posts
Armorama: 913 posts
Posted: Saturday, April 11, 2009 - 09:21 PM UTC
Nice work on those details! Is such a red color common on Russian AFV's?
Lars
bison126
Correze, France
Posted: Sunday, April 12, 2009 - 06:43 AM UTC
Hi,
thanks for the comments. Lars, the red should be a little more orange in fact. It acts as a warning about the hazard that are the rotating parts. This is for the troops in the rear compartment. The VC and gunner should know where they sit !
bison126
Correze, France
Posted: Saturday, April 18, 2009 - 05:03 AM UTC
Hello,
not much time for modeling those late days but I managed to make some progress with the BMP interior.
First I had to cut the sides and build new ones with an angle. Unfortunately I didn't cut low enough. So it doesn't angle that visible.
Then I started to add some bits to the hull top. AEF give the vision blocks and the firing ports. Many of them come with air bubbles so I used CA glue to fill them and thin plastic strips to redo the lip outside the firing ports.
I also added a kind of tubing that runs on both sides of the roof just behind the vision blocks.
The large resin block is the NBC filter. It had some small bins attached to it. I had to remove one and thin the remaining one as it would not fit inside the space designed for it.
Olivier
MBroneman
Moscow City, Russia
KitMaker: 34 posts
Armorama: 31 posts
Posted: Wednesday, May 06, 2009 - 03:53 AM UTC
Looks good!
bison126
Correze, France
Posted: Wednesday, May 06, 2009 - 05:45 AM UTC
Thanks Nikita,
I've been a bit busy those days so I could not do anything new to the BMP.Hopefully, I will have some good modeling time this coming week-end, cross my fingers !!
seb43
Paris, France
KitMaker: 2,315 posts
Armorama: 2,158 posts
Posted: Wednesday, May 06, 2009 - 09:34 AM UTC
Look Super Great Olivier
Keep up with the good work
Seb
iamsu7
Vendor
TRUMPETER
Anhui, China / 简体
KitMaker: 354 posts
Armorama: 339 posts
Posted: Thursday, May 07, 2009 - 07:42 PM UTC
AEF's width looks right, DROON's is wrong, BMP-2 is wider than BMP-1
