Armor/AFV: Axis - WWII
Tamiya Pz II C Polish Campaign
wbill76
KitMaker: 5,425 posts
Armorama: 4,659 posts
Posted: Friday, June 12, 2009 - 04:36 PM UTC
As a follow-on to the In Box Review of the Tamiya Polish Campaign Pz II C kit, this build log will serve to evaluate the kit fit and parts assembly. Largely OOB, the only thing I will be adding is a Lionmarc brass KwK30 2cm barrel along with maybe a tool clamp or two.
Work started in on this 2008 release kit from Tamiya today and things began where they usually do in Step 1 with the road wheels and running gear. The drive sprockets had their 4 shallow ejector marks carefully sanded down on the inner face and then the mount posts added. The road wheels were removed from the sprues and the mold seam on the rubber portion sanded down with a sanding twig, then the polycaps and rear inserts added. The idlers were also assembled with the outer rim carefully removed from the sprue to avoid warping/distorting it and glued to the hub using very careful applications of liquid glue around the perimeter to get it to sit nice and even in terms of diameter. It too received a poly cap and styrene cap on the inner side. Last but not least the return rollers were removed and their slight seams also sanded down.
Step 2 started in with the lower hull, adding the suspension arms for each side. Care has to be taken to keep the parts separate as they are not only handed but the final 5th suspension element is subtly different in terms of the spring angle, so I made sure to attach the first four then the final fifth separately to avoid any accidental mix-ups. The slight mold seam on the suspension springs was carefully removed with a sharp #11 blade. The idler mounts were also installed in their fixed position on both sides. The rounded hull nose plate was then installed and it fit perfectly in with the lower hull. Once the glue had set, I installed the final drive housings along with their trapped poly caps for the sprockets.
I went ahead and skipped Step 3 except for the installation of the rear hull plate since the rest of that step installs the various items from Step 1 to the hull.
Step 4 deals with the installation of the link-and-length tracks so was temporarily skipped...I'm going to see if I can still fit the track lengths in with the upper hull installed or not before committing to doing that...more on that later.
Step 5 begins the work with the upper hull. There are a number of holes that need to be opened up from the underside and, using the kit diagram to insure I only opened the ones needed for this variant, this was easily done using a #68 finger drill. Holes needed to be opened on only one fender side but also the underside of the superstructure roof to take the splash guards in Step 6. The inserts for the side air intake as well as the angled hull sponson were added without issue.
Step 6 adds all the panels to the superstructure as well as the splash guards and fender extensions. I removed all the panels and carefully cleaned up their sprue attachment points and opened up the two holes needed on the driver's side panel to take the splash guard for the view port using the same finger drill from before. A test fit of the panels showed that the panels fit well together but that the driver's plate had a slight gap on the superstructure roof as well as the angled butt joint where it mated up with the rear portion of the hull. This gap was small but noticeable, so some very careful use of Squadron white putty was called for along with strategic sanding to avoid damaging the nicely molded on weld bead detail on the edge of the plates. The other plates didn't need any putty work, only some light sanding to blend in their edges to create the seamless look needed.
The splash guards came next and these presented an unexpected problem during clean-up. Due to the way they are attached to the sprue, the attachment point is actually on the base of the part via a little tab. This works well to preserve the fine angled detail but when I removed the tab with sprue cutters, the slight stress was enough to take part of the edge of the delicate angled portion with it...creating a slight gouge in the process. These were repaired with same targeted putty work once the guards were installed to the hull. Finally, the rear fender extensions were added to complete this step.
Step 7 calls for the upper and lower hulls to be joined, so before I commit to that I'm going to have to do some tests with the link-and-length segments first to see what my options are. If the tracks have to fitted now, then some paint work will be required first before I can proceed to that step.
Nito74
Lisboa, Portugal
KitMaker: 5,379 posts
Armorama: 4,721 posts
Posted: Friday, June 12, 2009 - 07:24 PM UTC
I have the same kit waiting for some free workbench time, so I'll follow this one with great care..
Nice work so far, How's the 2cm gun barrel ? Have searched for other brands ?
spitfire303
Vendee, France
KitMaker: 1,435 posts
Armorama: 1,404 posts
Posted: Friday, June 12, 2009 - 08:06 PM UTC
Another brilliant build log it will be Good luck. BTW I have purchased my two first Tam kits (Hetzer and B1 bis ger) I'm shocked how few parts there are compraing to DML boxes (don't get me wrong there's nothing wrong about it it's just a fact).
good luck
spit
wbill76
Posted: Saturday, June 13, 2009 - 05:45 AM UTC
John, the 2cm gun barrel is going to be replaced with a turned brass item from Lionmarc. The Tamiya barrel is slightly too long by about 1 mm and also doesn't have the open vent holes in the muzzle brake or at the barrel neck. The LM barrel also has the grip sections for changing the barrel out which the Tamiya item doesn't. On the positive side, the Tamiya barrel is molded as one-piece and has an already hollow muzzle end.
Spit,
Glad to have you along for this one! The parts count is certainly lower vs. your normal DML kit these days, no question there. That's due in large part to the lack of any sort of interior and, of course, the use of link-and-length tracks which cuts the parts count by 200+ just right there. This one might set a record for me in terms of start-to-finish time.
wbill76
Posted: Saturday, June 13, 2009 - 06:41 PM UTC
Ever just get in a groove with a build and really get rolling? Today was such a day...probably one of the most productive model-building days I've had in a long time in fact.
Picking up from yesterday, I did a check with the top run of tracks and the clearance with the upper fenders and decided I had enough room to work with once the upper and lower hulls were joined. The test fit also revealed to me just how much of the underside of the fenders would be visible, so I went back and filled and sanded all the ejector marks on the underside as a precaution.
With that out of the way, I proceeded to work on Step 7 and join the upper and lower hulls. The fit here is good but the contact surfaces are not very large, so I used some rubber bands as added insurance to get a solid join all around.
Step 7 calls for the installation of the rear engine access hatch as well as the radio operator's hatch. Curiously the engine hatch actually has latch detail on the underside but since it's molded as one piece, you'd have to cut through that if you wanted to show the hatches open. The detail on the hatch is very good and the gap around the perimeter is supposed to be there just like on the real vehicle. After checking references and realizing that the fenders weren't jointed, I carefully filled the slight gap where the fender extensions met the hull from the previous step and sanded down the edges smooth.
Step 7 also adds the glacis plates and large access hatch for the driver. This fit beautifully and just required a little bit of liquid glue at the front to get the weld seam join to look the part. The correct style of view ports for the C were installed for the driver, these are called out properly on the instructions but are right next to the type for the c, A, or B so a double-check is a good idea to be sure you don't accidentally grab the wrong ones. The one piece tow rope/transmission hatch was also added along with the front tow hooks. The front fenders supports were also installed to complete the step after some ejector marks on their rear surfaces were sanded down.
Step 8 takes care of some sub-assemblies in preparation for later steps. These include the 4 part jack, the spare barrel box and lid, the two front headlights with blackout covers, the two-part antenna tray, the three-part tow hitch, and the 4 part muffler. The antenna holder had some ejector marks on the inner surfaces that I sanded down out of an abundance of caution. The muffler required the most work, with it's seam sanded down and some putty added to fill small gaps on either ends where the armored pipe from the engine and the hollow exhaust pipe installed.
Step 9 deals primarily with the rear hull plate details. The muffler is installed along with the rear brake light, the tow pintle, and the rear tow eyes. The PE mesh heat shield cover for the muffler was annealed over a gas burner flame and then carefully curved to shape using a Mission Models Multi-tool. The PE, since it's steel, is stiffer to work worth vs. brass so it took several sessions to get it to shape properly. The hull has small cut-outs molded in to take the mount tabs, so getting it into position was easy with no guess work required. The rear fender supports were also installed along with the mud-flaps. The tool box and spare barrels boxes were installed on the right side fender while the jack went on the left. The radio operator's view port was also installed and, unlike the driver's ports, this one is the earlier c/A/B type and not the C type. It's the only option provided so there was no choice there and is a minor thing in the long-run. Last but not least all the tiny little lifting eyes were added to the upper hull. No spares are available so I worked slowly and one at a time to make sure I didn't have any casualties along the way.
Step 10 deals mostly with the fender gear and I was selective in terms of what I installed and what was left off for later. The left side fender received the antenna tray, the fire extinguisher, and the long pry bar but the shovel, axe, and jack block were left off for later. All of the tools on the right fender were also left off and the front headlights were installed. I added the missing wiring conduit using 0.5mm diameter solder cut to shape and carefully glued down with liquid glue as an added detail.
Step 11 deals with assembling the commander's chair and the interior detail for his hatches. Since I'm not posing the hatches open, I skipped this step entirely.
Step 12 deals with the main armament and the first order of business is to install the MG34 and KwK 30 into the interior mantlet. Since the KwK 30 is molded as all one piece, I removed the molded on barrel portion with sprue cutters and sanded it down smooth. A mount hole was drilled with a pin vise and the Lionmarc turned brass barrel installed. The open sighting view ports were also added to the mantlet along with the circular elevation parts, the elevation parts are not glued. Only one of these receives a poly cap and the result is a very snug, but still movable, fit while the other just fits loosely on the other side elevation pin.
Next was the addition of the external mantlet plate which also serves as the turret front plate. This has to be carefully installed by getting small D-shaped tabs to align with the elevation parts.
The other half of this step is the assembly of the turret itself. The top and bottom halves were joined using a combination of regular and liquid glue and allowed to set up. The splash guard for the commander's hatches and the signal port cover were also added.
The step is completed with the installation of the mantlet and guns into the turret proper. I used a careful combination of liquid glue and regular glue, making sure that the guns could remain movable throughout. Some slight finger pressure was needed in a couple spots but otherwise a very snug fit. The main open sight hatch kept popping loose on me so I decided to pose it in the open position since that gave a larger glue surface. It also has the added benefit of the feel that the vehicle is "crewed" since most of the other hatches aside from the commander's hatch don't have any interior detail and have to be posed closed as a result.
Step 14 deals with the installation of the commander's hatches and the remaining side vision ports. The turret lifting eyes were also added. I also added some weld texture to the missing areas on the angled lower turret plates by carefully scoring the plastic with the tip of a sharp #11 blade. I then came back and sanded it down to make it smaller and more regular...the photo makes the area look a little more pronounced than it actually is.
Step 15 calls for the installation of the turret into the hull as well as the addition of the rear rhomboid number plate. This was added using a drop of CA gel and some liquid glue. I also added an Armorscale 2m brass antenna (trimmed down to fit the 1.4m antenna tray) by removing the stub in the mast and drilling out a small hole and gluing it in place with CA gel. The mast was then installed to the hull side in the down position.
Incredibly as it sounds...this one's now ready for painting!
vanize
KitMaker: 1,952 posts
Armorama: 627 posts
Posted: Saturday, June 13, 2009 - 06:49 PM UTC
looking good.
wbill76
Posted: Sunday, June 14, 2009 - 04:34 AM UTC
Thanks Vance!
Belt_Fed
KitMaker: 1,381 posts
Armorama: 1,318 posts
Posted: Sunday, June 14, 2009 - 05:01 AM UTC
lightning fast and precise. What more could you ask for?
Beleive it or not, I took the French campaign Panzer II along with me (and my tools) to my dad's office one day when I decided i wanted to go to work with him. I was able to build the entire lower and upper hull (including the tracks!) in that one day. If we stayed just another 30 minutes, I could have finished the turret. all well...
Just think- i could build an intire Tamiya kit in the time it takes me to do one step on a Gragon kit
wbill76
Posted: Sunday, June 14, 2009 - 06:47 AM UTC
Thanks Jon! This little guy has come together pretty quickly...I'm heading out to the garage for some time with the AB so will have an update later today with the paint scheme and then it's on to the detailing and tools, tracks, etc.
bill_c
MODEL SHIPWRIGHTS
KitMaker: 10,467 posts
Armorama: 8,043 posts
Posted: Sunday, June 14, 2009 - 08:43 AM UTC
I'm curious, Bill, why you did not go for a JBModele.eu or Aber MG34 barrel?
wbill76
Posted: Sunday, June 14, 2009 - 12:11 PM UTC
Bill,
I wanted to stay OOB on this one as much as possible and only used items that I already had on hand vs. ordering a lot to go with it. I got the kit for $18 USD so wasn't really looking to spend a whole lot on it. Plus, since I did a Review on it, I wanted to stay OOB as much as possible there as well. The kit-supplied MG barrel is good enough for the purpose and wouldn't really have gained much from a replacement barrel except to say, yep, I did replace it. Once painted it's going to do just fine as there aren't any dimensional or detail issues with it per se. The KwK 30 on the other had had a dimension error as well as the lack of detail on the muzzle brake, so the LM barrel was used but only because I had them on hand for other kits and could afford to order another and wait for it to be delivered as a replacement.
Nito74
Lisboa, Portugal
Posted: Sunday, June 14, 2009 - 12:39 PM UTC
Looks great.
Really fast one too, don't you love those days where everything fits perfectly ?
I think the 2cm Kwk metal gun is worth it, it improves the build and corrects the few Tamyia flaws.
Looking forward to see it painted ! Great work
KurtLaughlin
KitMaker: 2,275 posts
Armorama: 2,250 posts
Posted: Sunday, June 14, 2009 - 02:04 PM UTC
Bill, did you notice any sink marks along the right hand side engine doors? One guy had quite a few on his "France" kit but my "Poland" kit has only slight ones.
KL
wbill76
Posted: Sunday, June 14, 2009 - 02:13 PM UTC
Thanks John!
Kurt,
I don't recall any sink marks on the engine doors, there weren't any on the exterior surfaces and the interior surface may have had some but I didn't pay that much attention since they were in a non-visible area. Sorry I can't offer much more than that.
wbill76
Posted: Sunday, June 14, 2009 - 02:34 PM UTC
Weather was perfect for painting today, so the first order of business was the usual prep. The turret was separated from the hull and mounted on a cardboard tube with strips of blue painter's tape for easier handling of both the turret and the hull. The road wheels, idlers, and return rollers were mounted on toothpicks with only the return rollers needing some blue tack putty to hold them in place since the others had the poly caps.
Everything was primed using Model Master enamel Italian Dark Brown. This was particularly helpful since the Tamiya plastic is already dark gray to insure that all the plastic surfaces were painted before applying the base coat. The base coat of Panzer Schwarzgrau was then added in multiple passes to build it up over the primer coat.
The next step applied some highlights and variation in the form of about an 80/20 mix of Panzer Schwarzgrau/Light Gray in a reverse shading pattern. Some of the areas were going to be covered with the camo pattern but that's ok, the idea was to get the gray areas looking the way I wanted to first.
Since the ordered scheme in effect at the time of the Polish campaign called for a 2/3 Dunkelgrau 1/3 Dunkelbraun scheme, I used Model Master enamel Panzer Schokoladenbraun as the Dunkelbraun and applied it freehand. I tried to break up the pattern a bit and also adhere to the required ratio even though the temptation was there to go 50-50. Given the overall size of the vehicle, it was a balancing act and I worked slowly and deliberately since the Tamiya instructions were no help at all in terms of the pattern.
The road wheels were also painted at this stage in preparation for mounting. They were also primered with the Italian Dark Brown and then the rubber portions painted using enamel Gunmetal and then the hubs painted using a circle template. In the 2/3-1/3 spirit, I painted 6 in Dunkelgrau and 4 in Dunkelbraun. The return rollers also had their hubs painted using the same method.
This will sit now until next weekend and then it's on to the tracks and other remaining details.
Self-Propelled
Bayern, Germany
KitMaker: 252 posts
Armorama: 229 posts
Posted: Sunday, June 14, 2009 - 03:28 PM UTC
You're really marching straight towards the finish line on this one. The camo is very interesting, I have to try one on a future model. You're doing excellent work!
wbill76
Posted: Sunday, June 14, 2009 - 04:32 PM UTC
Thanks Sebastian! Give the two-tone a whirl, it definitely opens up a lot of possibilities in terms of the finish vs. the "classic" panzer gray. This is the second time I've done an early-war vehicle with this scheme (first one was a Bison I) and when I compare the MM colors to the color chips that are in PT 1-2 for the two colors they are a very close match IMHO.
Negrillo
KitMaker: 58 posts
Armorama: 54 posts
Posted: Friday, June 19, 2009 - 09:53 AM UTC
Bill,
You`re making an excellent job of a great kit - this kit is beautifully engineered and is a typical 21st century Tamiya "shake & bake" kit - I`m building the initial "French Campaign" kit at the moment and when I compare it`s quality to the ill-fitting "warpfest" that is the Dragon Panzer II C there`s just no contest at all , Tamiya have rectified the idler on the "Polish Campaign" version ( `though the Polish version can be used as a tank serving throughout the 1940 campaigns as I`ve seen photos of Panzer II`s serving in Norway & France without the extra turret/hull armour - so basically this particular kit can be used as the modeller desires to cover all bases from 1939-40 - with a few decals from the spares box - looking forward to seeing the final product Bill - your paint job looks great so far !
Regards
Stirl
wbill76
Posted: Friday, June 19, 2009 - 04:37 PM UTC
Thanks Stirling! I've been thoroughly enjoying the build so far and was surprised at just how quickly it all came together. I'm sad to hear about the DML II-C kit though as I have that one in the stash as well but I guess I'll have to grin and bear it when its turn comes on the workbench.
I was very happy to see that Tamiya corrected the idler diameter and, not only that, but also provided new idler mounts so they would sit at the right height for the link-and-length. All of the French Campaign vehicle parts are present in the kit with the exception of the parts for the up-armored hull nose, so you do have to pay close attention not to accidentally include the wrong parts in some locations but nothing too serious.
wbill76
Posted: Sunday, June 21, 2009 - 02:40 PM UTC
This weekend was kind of a slow model-building weekend...I guess that's appropriate considering how much got done last weekend! I did make progress on the detail front with the first order of business being to paint up all the tools and get them installed. This followed my usual pattern with the metal portions painted with Non-buffing Metalizer Gunmetal and lightly dry brushed with Steel. The wood portions were painted first with my custom "wood" color and then given a light wash of Leather followed by a strategic dusting of Burnt Umber artist pastels. The jack block was also counter dry brushed with the "wood" color to give it more variety. The wire cutters had their Bakelite handles painted with Italian Dark Brown and the rubber end caps painted with enamel Gunmetal. The tools were then installed to both fenders.
Next up was the final hurdle, the tracks! This is what the instruction diagram looks like back in Step 4.
This process turned out to be longer than I thought it would be. All of the links and lengths sections were removed from the sprues and cleaned up. Since the contact surfaces are so small due to the small size of the Pz II links, I went ahead and formed the curved parts first. To do this, I used the sprockets and idlers as, well, formers, and glued the curved sections together and then left them to dry overnight resting on their respective surfaces.
Once those had set up, I attached the sprocket curved portion to the angled length portion and glued that into the long base piece. This was done for both sides so that they would form as a single piece that could still be removed for painting. This was possible due to the fact that the sprocket could remain movable courtesy of the polycap.
The different sections were then base coated with Non-buffing Metalizer Gunmetal, heavily dry brushed with Steel, and then given a wash of Burnt Umber to prepare them for installation.
The final steps involved getting the remaining lengths to join up into a single track run. To accomplish this, I first positioned the top run and then glued the idlers into place but didn't yet glue the top run onto the idlers. A little bit of slack is needed to play around with to get the front and rear portions lined up, so it's best to do this last. Once the top run had set for about 1 hour, I then joined the bottom run up at the idler to the top. At this stage it was no longer desirable that the sprockets and idlers be able to rotate as they kept putting a little bit of "play" into the way the tracks were setting, so I applied some liquid glue to their inner contact surfaces with the mount arms and they are now fixed firmly into position. Then, using some strategic toothpicks to hold it down and prevent floating, the top run was glued down to the return rollers.
Process was repeated for the other side and after several hours (much of it spent waiting for glue to set up), both tracks were finally installed.
Next up will be adding the markings and then onto the weathering stage!
Jamesite
KitMaker: 2,208 posts
Armorama: 2,152 posts
Posted: Sunday, June 21, 2009 - 11:29 PM UTC
Nice work Bill, looks great.
Shame to close up the turret hatch after putting the breech together!
Keep it up,
James
wbill76
Posted: Monday, June 22, 2009 - 02:59 AM UTC
Thanks James! The gun breeches didn't require all that much work since they are necessary for the guns themselves to be installed. The hatches are nice and big and would provide a lot of viewing potential into the turret and lower hull but there's nothing there in the kit. If you don't stuff the figure into the hatch, you'll have a lot of void! Since I didn't particularly want to include the figure, the hatches got closed.
trahe
KitMaker: 1,149 posts
Armorama: 944 posts
Posted: Monday, June 22, 2009 - 03:20 AM UTC
Looking really good there! I really like the post shading effect on the gray color. Looking forward to seeing the completed model. Thanks for sharing!
barkmann424
KitMaker: 357 posts
Armorama: 353 posts
Posted: Monday, June 22, 2009 - 07:06 AM UTC
He's at it again! I only went to make a brew... And you have built it and started the paint job already!
This looks a nippy little devil Bill, really like all that subtle shading and camo clouding... A definite blinder.
Excellent stuff mate... Phil.
wbill76
Posted: Monday, June 22, 2009 - 07:14 AM UTC
Thanks Thomas, appreciate the comments!
Phil, you've got to pay close attention or this one will pass you by if not careful! Appreciate the kind words as well.
