| Subject: 1/6th scale early Production M4 sherman |
| John armourguy | Location: Pennsylvania, United States Member Since: March 12, 2008
Posts: 153 entire network,
89 this site
| Posted: Sunday, July 26, 2009 - 10:50 AM UTC |
Hi Guys, Now that I finished off a batch of German tanks I decided to build some more American tanks. First will be this old Viper Sherman Hull and turret that I recently acquired in a trade.  For those of you who are un familiar with the Viper Sherman it was an all resin and fiberglass early production M4 Sherman that was released in limited numbers back in 2003. The Model itself is a scaled up copy of the Tamiya 1/35th scale early production Sherman. The model came with a two piece upper and lower hull, non functional VVSS suspension, and lots of crew equipment that would be inserted into all of the holes that are drilled into the tank's surface. The problem with these models is that their resin construction made them very fragile and prone to damage. They also became unpopular because of their weight. Viper soon folded after the release of their Late Tiger I kit that was very un popular because of the same reasons.        I always liked their M4 and I have built two of them when they were released. After building my two Shermans I saw room for improvement, and in making the tanks more rugged and robust.    One problem that the kit has is that the lower hull doesn't have the hull sponsons. The hull is also molded that the hull wall is lower than the sponson by 1/2 an inch. Because of this there is a huge gap that can be shows through to the other side of the tank.  To correct this I cut several pieces of 1/2 inch plywood to construct the sponson and hull wall extender. I used this thickness of material because I wanted to use a material that was the same thickness of the tank's hull, also because it gives me a stronger point to attach fasteners. The sponsons had to be very strong because they will also be used to attach the top hull and the bottom hulls turning them into one solid piece. This alone reduces the fragility of the tank immensely. The sponsons were attached to the tank via fasteners, then they were treated and reinforced with fiberglass cloth and resin.   Prior to in the upper hull installation I reinforced the entire upper hull with more fiberglass cloth and resin. The tank does have cloth imbedded in its casting, but I felt that the thickness was too thin and the extra cloth and resin was a good measure. The Hull now sounds more "Solid".  The upper Hull was attached permanently to the lower hull with fasteners, fiberglass cloth, resin, and epoxies.   I will not be using the stock Viper VVSS suspension. In it's place I will be using my own functional VVSS suspension. Because of this I plugged up the holes for the kit supplied suspension with casting resin. I also used the casting resin to plug up all of the equipment holes.   The tank came with a few tools and other accessories molded in shovels, fenders, head/ tail lights...ect. These were all removed and new ones will be added in their place    The tank's turret also had it's extra armor molded in. The problem was that the kit has the armor placed too low and had to be removed  I will also be tooling up some new Resin components, as well as updating some of the older ones with newer tooling. |
| HIDE SIGNATURE AREAS |
89 this site
| Posted: Friday, July 31, 2009 - 11:38 AM UTC |
89 this site
| Posted: Tuesday, August 04, 2009 - 07:51 AM UTC |
I have added a new component to the US AFV poduct Line. More parts are to follow. http://www.eastcoastarmory.com/ustankparts.htmResin M4 Sherman Bow 30.cal canvas mount ring   I have also assembled and installed the tank's functional VVSS Suspension. On this model I went with the Mid production VVSS skid rail. I also used different styles of swing arms, and road wheels for the "in field" mix and match look.     One weak point that these kits had were their suspension. The stock VVSS suspension was made out of the same brittle resin that the tank was constructed out of. The stock suspension was also ridged and non functional. This made the tank very unrealistic when placed on an uneven surface. Another problem because of the ridged and fragile combination was that when the tank was placed on an uneven terrain all of the tank's weight would be focused on one or two pressure points, giving the potential for the swing arms to snap. With the new functional VVSS the tank now has a natural look on an uneven surface, and the tank's weight is distributed thought the entire suspension safely.     Now that the suspension is out of the way the tank's progress will be more rapid. |
 | Matt Wagg pebblemonkey | Location: England - West Midlands, United Kingdom Member Since: January 26, 2009
Posts: 139 entire network,
115 this site
| Posted: Tuesday, August 04, 2009 - 09:38 AM UTC |
Beautiful work!! |
| When Death Smiles at us, All we can do is Smile back and say "Does your Mum know you're gay???" | |  |
 | Alex AlxUSMC |  | Location: Armed Forces Europe, United States Member Since: December 04, 2008
Posts: 186 entire network,
111 this site
| Posted: Tuesday, August 04, 2009 - 11:17 AM UTC |
Jesus.....how much does a kit like this run |
Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem.
89 this site
| Posted: Saturday, August 08, 2009 - 04:01 AM UTC |
89 this site
| Posted: Wednesday, August 12, 2009 - 03:16 PM UTC |
I have completed more new components for the M4 and the M4 family. All of these new items have been added to the product line. http://www.eastcoastarmory.com/ustankparts.htm1. Resin M4 Sherman Family Lower Hull Lift Hook set.     2. Viper M4 Sherman Idler Mount Quick Fix set. Set comes with two resin Hex heads, and two plastic discs. This set is a simple quick dress up kit for the Viper Idler Mounts.  Stock Viper Idler Mount:  Modified with the dress up kit:   3. Rear deck Armored air intake. This part will work on all 1/6th scale M4 Sherman on the market.    4. Resin M4 Sherman Rear Engine Air Filter canister set. This set will work on The Viper M4, M4A1, M3 Lee, M7 Priest, and M12 SPG. These sets will not work on the Panzerwerk, Armortek, Plastic Panzer, and JD M4A3 Sherman. The Air filters are hollow and come with a removable top, and air filter. These sets would be perfect for a maintenance diorama. This set also comes in two options, One as a kit form, the other as a pre built set.       On the tank I completed the tank's rear firewall details.   I have also been working on the tank's front armored plate details including a travel lock, side view mirror mounts, and front antanna mount cover plate.     On the tanks top deck, new tow cable cleats and a new fire extinguisher control box were added.   |
 | ian hepplewhite woody6968 | Location: England - North East, United Kingdom Member Since: March 02, 2006
Posts: 266 entire network,
220 this site
| Posted: Sunday, August 16, 2009 - 12:58 AM UTC |
hi there . just wanted to say this is one hell of a build , i'll be watching this as you progress ,i realy like large scale ,,and your detailing is top rate ,,keep up the good work ,, |
 | Richard Singleton RSingleton | Location: Kentucky, United States Member Since: August 26, 2008
Posts: 286 entire network,
273 this site
| Posted: Sunday, August 16, 2009 - 03:04 AM UTC |
It is great to see you building more of these! Watching with great interest Rich |
"Building is easy. Painting is hard. Weathering is harder. Not going crazy doing the above is the hardest."
If it moves, shoot it. If it screams in [insert enemies language], shoot it again!
Play the XBox 360? Look for fallshirmjager9 | | |
 | Joe Driver ViperAtl | Location: Georgia, United States Member Since: August 22, 2005
Posts: 211 entire network,
172 this site
| Posted: Sunday, August 16, 2009 - 03:35 PM UTC |
Which room will display this monster? |
Support your Local Hobby Store.
Still boycotting Dragon Sytrene tracks. Ick-poo!
Current project:
Looking for my mind, I lost it somewhere.
89 this site
| Posted: Tuesday, August 18, 2009 - 07:37 AM UTC |
89 this site
| Posted: Thursday, August 20, 2009 - 01:10 PM UTC |
89 this site
| Posted: Sunday, August 23, 2009 - 02:11 PM UTC |
89 this site
| Posted: Thursday, September 03, 2009 - 11:37 AM UTC |
89 this site
| Posted: Sunday, September 06, 2009 - 11:25 AM UTC |
 | armyguardian | Location: Hainaut, Belgium Member Since: April 27, 2005
Posts: 21 entire network,
21 this site
| Posted: Sunday, September 06, 2009 - 02:38 PM UTC |
beautyfull work! |
 | Todd Hall tjbear66 | Location: Alberta, Canada Member Since: February 10, 2008
Posts: 73 entire network,
71 this site
| Posted: Sunday, September 06, 2009 - 04:27 PM UTC |
Got a crew lined up for it yet ? Cheers. Todd. |
http://www.mvpa.org/
Why don't you knock it of with them negative waves? Odd Ball. | | |
89 this site
| Posted: Monday, September 07, 2009 - 08:24 AM UTC |
 | Jeff sgtreef |  | Location: Oklahoma, United States Member Since: March 01, 2002
Posts: 4,657 entire network,
3,379 this site
| Posted: Monday, September 07, 2009 - 07:45 PM UTC |
Wow that is one Big tank and a great finish and build.
At $400.00 for original not bad for a static display at 1/6 scale.
But with the added parts makes it a better piece.
Thanks for sharing. |
220 this site
| Posted: Monday, September 07, 2009 - 09:27 PM UTC |
wow ths realy is an ore insiring build ,, hats off to you |
89 this site
| Posted: Thursday, September 10, 2009 - 12:53 PM UTC |
89 this site
| Posted: Sunday, September 13, 2009 - 04:14 PM UTC |
89 this site
| Posted: Friday, September 18, 2009 - 04:25 PM UTC |
The last of the parts were added and the tank is now finished. To quote Queen "Another one Bites the Dust!". Over the weekend I'll be shooting an out door dio, and make the tank's gallery webpage. Once the gallery is complete it is off to the next one      The tank's Tools and "funiture" were built and completed.     I have added to the product line a Set of US AFV tools. I have had these tools since I built the M10, but I never got around to adding them to the website. http://www.eastcoastarmory.com/ustankparts.htm The tank's gas caps were machined out of aluminum, and their retaining chains were added.   Chain was also added to the tow Hitch and the tow hitch mount.  For the tank's AA 50.cal I used the Dragon 1/6th scale Plastic 50.cal kit. The kit is an excellent detailed 50.cal. The kit also goes together very nicely, but needed very few enhancements.  The gun has a functional bolt and charging handle, but a spring was added to make the bolt return.  The gun's barrel has sveral notched molded into onto the ring. Due to the way the parts were molded the notches are absent on two sides of the ring. So the two notches were added to the ring.  The gun's top ammo hatch is functional that has two molded notches. These notches are too small and the plate is held in place, but the door tends to fall out. To fix this I drilled out the notches and used a small wire brad to hold the plate on keeping it's functionality. STOCK ALTERED For the Gun Cradle, I used the Armorpax white metal kit. The Armorpax kit is also a very nice add-on. To make the cradle pivot I used two micro slot screws that were screwed into the guns pivot points.       The gun comes with a nicely detailed ammo belt, but the problem is that the ammo Belt is made out of ridged styrene, and is not flexible. DS styrene would have been a better choice for the ammo belt material. The kit also comes with a nice ammo box, but the ammo box is not for WWII. The Kit's tripod is also excellent, but is not going to be used on this model. For the ammo I used a DID cloth and brass ammo belt. The 50.cal shell casing were left natural brass, and bullet heads were painted copper and tracers were added to every 5th round.         |
89 this site
| Posted: Thursday, September 24, 2009 - 08:15 AM UTC |
89 this site
| Posted: Tuesday, September 29, 2009 - 01:44 PM UTC |
 | tom tomzag | Location: Alberta, Canada Member Since: January 27, 2006
Posts: 27 entire network,
23 this site
| Posted: Monday, November 16, 2009 - 04:16 PM UTC |
wow, great model!!! compare with yours, mine are nothing. |
| Tom's rc tanks: tomsrctanks.com | | |
3,379 this site
| Posted: Thursday, November 19, 2009 - 10:59 PM UTC |
Great job on the build and one big Tank at that. Thanks for sharing. |
