Constructive Feedback
1/35 Trumpeter BR 86 Dampflokomotive
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Saturday, January 30, 2010 - 01:53 PM UTC
Thank you milvehfan for your kind words
And here finished PE base for both air parts of the compressor. Now I will make a mould to get exact resin castings. Other details will be mounted on them, and the steam part of the compressor with steering and lubrication on the top. Then all the parts will make final mould for Tolkien-Knorr compressor, commonly used on many various German locos after 1934 year.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, February 02, 2010 - 07:57 AM UTC
Some progress made on steam part of the compressor, many details still to be added here and on the mud trap as well. Whole thing will contain about 150 parts (excluding PE´s used for air part and armatures on the sides )
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, February 02, 2010 - 11:54 PM UTC
Today continued with detailing.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, February 03, 2010 - 07:11 AM UTC
The steam part finished in surfacer coat, some additional cleaning and polish will be necessary before making the mould. Also grease equipment is finished, the nozzles at the back will be cast separately.
Libor
Gorizont
Sachsen, Germany
KitMaker: 1,462 posts
Armorama: 1,289 posts
Posted: Wednesday, February 03, 2010 - 08:40 AM UTC
Again, I have no words for that!
On my soviet Venus-lander builds, I also had some ideas for building some additional parts/ machines... but my ones are very simple against yours.
GREAT!
As I said some time ago, in other words... "seeing the build of a product is much better than seeing the finished product".
"All hard work can be seen in this, not in the result".
greetings...
Soeren
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, February 03, 2010 - 08:52 PM UTC
Thank you Soeren, you are always very kind
You know, thats actually very exciting if you can build something part by part, getting know what they were for and how it worked. This suits me much better than building of kit from the box. Next month I will start something else, the real cracker
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Thursday, February 04, 2010 - 12:07 PM UTC
Before a mould for the air part of the compressor is ready, I can start Tolkien-Knorr water feeding pump. This is gonna be quiet hard nut to crack.
For the start, I got some basic parts, long float barrel, pump cylinder, and Tolkien control unit, which I´ll be working with now.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Friday, February 05, 2010 - 09:38 PM UTC
And here a few pictures from my last night progress on control unit.
This is actually really time consuming thing, however, the result should be very good (in one or two more weeks )
Libor
Frootbat
Australia
KitMaker: 3 posts
Armorama: 2 posts
Posted: Saturday, February 06, 2010 - 04:06 PM UTC
I have been watching your locomotive builds for some months from the sideline. With the best of intentions I say "You Sir, are a freak".
My own kit of the BR52 only just arrived after almost a year of waiting and now that I have seen yours this girl doesn't want to build hers.I am hoping the voyager PE should arrive in the post any day now so it might help a little. While I may have to stick to the kit parts more than I would like to the detail you put into the build logs is fantastic and will give me the encouragement to scratchbuild some of my own simpler parts.
What do you use for your nuts and bolts etc. They look beautifully done. I don't know where you get your deterity and patience from.
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Saturday, February 06, 2010 - 10:21 PM UTC
Thank you Joanne, your feedback is much appreciated. Voyager´s detailing set is very nicely done, I can highly recommend. I want to use one in the future for my armoured BR52. Many parts I have done for my BR86 will be used there as well, because they are suitable for most German locos from that times. So far I use nuts from Masterclub, but they are sometimes quiet hard to get, so I will have to make mould for them soon as well
Continued on the control unit, which is finished, just some lifting to be done, when surfacer is applied. Also grease mechanism box is ready for surfacer coat.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Sunday, February 07, 2010 - 12:31 PM UTC
Another bit done tonight, the pump cylinder.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, February 09, 2010 - 01:35 AM UTC
The float cylinder is finished, now just the most difficult part to go
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, February 10, 2010 - 11:28 AM UTC
Continued on tricky lower part, the main work is done and there will be lots of cleaning and polishing later on. I tried to stick all the parts together and everything seems to fit just great. Trumpeter´s pump added to compare. Tomorrow I will bring pictures of finished master.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Thursday, February 11, 2010 - 09:02 AM UTC
Finished parts of the pump, ready for making a mould.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Sunday, February 14, 2010 - 09:12 AM UTC
Just very small progress today, because I was kinda busy last couple of days, making some moulds for wheel bases. Anyway, I have finished another part for the compressor and all the tricky pipes and flanges to connect it later.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, February 16, 2010 - 05:22 AM UTC
Yesterday I got ready some moulds, the compressor body, a few small parts, which I need to duplicate, and also base for all the wheels. Then I started other parts for compressor.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, February 16, 2010 - 08:49 PM UTC
All adds for the compressor finished, today I hope to get some castings
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, February 17, 2010 - 07:32 AM UTC
In the middle of busy work, a couple of castings here. Small flash (tiny membrane) can be easily removed by modelling knife.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Thursday, February 18, 2010 - 08:04 AM UTC
Cleaned hub with spokes to make driving wheels and compressor cylinder base to finish whole thing
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, February 24, 2010 - 01:17 AM UTC
Some small progress after while, wheel ring for all the drive wheels the same is finished and I will complete it with hub part. I have also made some other moulds, double free axlee wheels mould and more for various small valves, fittings etc.
Libor
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Thursday, February 25, 2010 - 08:25 AM UTC
Some castings obtained from the moulds shown last time.
Libor
Gorizont
Sachsen, Germany
Posted: Thursday, February 25, 2010 - 09:47 AM UTC
Ohh, I wish I had your skills in my hands! It´s always fun to see the progress on all of your work!
I also would try to make "copies" from some parts of my projects, but I don´t have the possibilities for this.
(the "ladder" - but I think about to build another one)
Yes, these are very small parts - and I´m exited how to place MY small parts to its "big one".
(the "teeth" to the lander´s ring)
Thank you for the inspiration to scratch-build some things!
greetings...
Soeren
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Saturday, March 06, 2010 - 11:57 PM UTC
Thank you Soeren, I was gone for the last few days, and also some other things appeared to be finished without delay, but here I am back again and working even harder. I will have to catch all the progress made here at the website last week, and I will drop in your topic soon as well.
A mould for the wheel rings is finished, and moulds for water feeding pump, couplings and some other parts as well.
Libor
Babcat
Michigan, United States
KitMaker: 269 posts
Armorama: 259 posts
Posted: Sunday, March 07, 2010 - 07:43 AM UTC
Libor, That is some impressive detailing! I don't want to slow you down too much but I do have one quick question... actually two... What are you using for the translucent mold material for your castings? How are you casting, pressure, vacuum, or just dang good? I never see a bubble, amazing. I will definately be back this way to keep an eye on your progress.
Aloha
Babcat
grave_digger
Clare, Ireland
KitMaker: 952 posts
Armorama: 834 posts
Posted: Thursday, March 11, 2010 - 12:17 AM UTC
Thank you buddy for your kind words. PM sent.
Back in building at last, I have finished (actually for another purpose, but the hose and connector will be used for my loco as well)connector with air hose, and castings for the drive wheel are ready to complete whole things. More soon.
Libor
