TUTORIAL: For Campaign Leaders
GaryKato
KitMaker: 3,691 posts
Armorama: 2,691 posts
Posted: Monday, October 26, 2009 - 05:46 PM UTC
A Guide for Campaign Leaders
Proposing a Campaign
Start a thread in the Campaign Forum with the general rules of the campaign. Be sure to name it something like "Sign Up for the XX Campaign". The initial purpose of the thread is to see how many people are interested in your campaign. A proposal needs a certain number of people replying to the thread saying they would join to move to the next step (Armorama:10, Historicus Forma and Automodeler: 5). The number may be different for other Kitmaker sites so check their Campaign Guidelines. The name of the campaign should be less than 27 characters so the yellow CAMPAIGN tag can be put in front of the title of the official thread.
There are three rules you really should specify. For Armorama, these are now required.
1. A photo of the final build MUST appear in the campaign gallery to qualify for a ribbon. Campaign threads can get lost amongst all the other threads so it's good to have these pictures in an easy to find spot. In-progress photos can also go into the campaign gallery, especially if the photos are of major scratch building/conversion work that will not be as noticeable after more plastic and paint have been put over the model.
2. Whether or not you desire that kits for the build not be started before the campaign starts. This is the normal rule but it is really up to the leader. For example, the "Get the Job Done" campaigns are specifically for kits that were started then put on the back burner and forgotten and "Tank Overhaul" is for updating the job you did on a previous build. It is up to the leader how much has been built that will qualify. You might allow someone to finish a partially kit he bought on Ebay or was given to by a friend, maybe a kit where only a few pieces were glued together, or maybe a kit where only the decals and protective coat are needed. At least be aware that you may have to make a ruling on entries during the campaign.
3. Whether builds from other campaigns are allowed. I have assumed "one build - one campaign unless allowed in the rules" however there are other seasoned Armorama vets who assume "one build - multiple campaigns unless prevented by the rules". So now it must be explicitly stated in the rules.
Armorama campaigns without at least these three rules will not be approved until the rules are added.
Another rule that I strongly recommend is to have people post in-progress photos either in the thread or in the gallery. I am afraid we have had people entering models they built several years ago or that they didn't build themselves.
** "advertising a campaign in other forums **
If either your campaign is a Kit Maker-wide campaign or you just want to "advertise" your campaign in other forums, after posting in another forum, send a PM to the Campaigns Manager of that forum containing a link to that thread with a request to lock it. Your message should have a link to the actual campaign thread. This way you won't go crazy checking threads in umpteen forums.
Once the required number of people have shown interest in signing up in your thread, go to the Campaign page and click on the "Guidelines for Starting Campaigns" link. Read the page and figure out as much as you can. Note that the start date you pick is not guaranteed as it depends on how many other campaigns are running at that time. Click on the "Propose a Campaign" link and fill out the form. Submit the form and wait for the Campaign Manager to approve your campaign. When this happens, the official campaign page will appear in the Campaign section of the site.
During the Campaign
Once the campaign has started, you should be assigned an official (sticky) campaign thread and a photo gallery. If not, bug the Campaign Manager as these are essential. Usually the initial proposal thread is used for the campaign thread but you can create another one and request that as your official thread. Now that the official campaign page is visible to everyone, more will come on board. Don't forget to have the people who responded to your sign-up thread enlist on the official campaign page.
The campaign leader should also get the campaign ribbon designed as early as possible since this can be quite a motivator for people to finish the campaign. A campaign ribbon is a GIF file that is 50 pixels wide by 20 pixels tall. The leader can make a design or have someone else do one, but it is up to the leader to get it designed and uploaded. To upload the ribbon image, campaign leaders will see an extra link on their campaign page labelled "Create Award". Clicking on that link takes you to the Create Award page. Fill in the two text fields: "Award Name" and "Award Description". Typical entries are "XX Campaign" and "This award signifies this person completed the XX Campaign". Click on the "Add Award" button.
** New ribbon uploading method **
Two new buttons appear. One is "Choose File". Clicking that will bring up a chooser box that allows you to navigate to the GIF file on your computer. Once that is done, click on the "Add/Update Award" button and your file will upload. You can go back to your campaign page to see the results. (For old hands, there is no longer a requirement to give the file a special name).
Another duty of the leader is to enforce the rules of the campaign. The more exact your campaign description is, the fewer people will be confused as to what won't be allowed. The leader should keep up to date on the postings of their campaign thread. Encouraging your fellow campaigners is also a good thing to do, especially if others in the thread aren't. If you see a real knock-out of a build, you might want to send a PM to the builder and suggest that there could be a possible Feature here and to contact the Features Manager about it. One rule that you must enforce is that a build can only qualify for one campaign. Someone may post a question or they may just post that they are building a kit for more than your campaign.
As the campaign nears the ending date, some will ask for more time. This is entirely the campaign leader's decision. If you want an extension, figure out for how long an extension you want, then PM the campaign manager with your request. One of the problems with a formal extension is that more people might join during the extension and they may need a further extension to finish. Another choice is an informal extension where the campaign isn't officially extended (the campaign page still disappears from the Current Campaign list) but the leader awards a ribbon for a late finisher.
Editing Your Campaign Page
If you look near the top of your campaign page, you will see this: "ADMIN:[EDIT]". This allows you to make changes to your campaign page. This is handy when it turns out your rules were too ambiguous and you need to tighten them up. Here are some extra fields that were not in the Campaign Submission form.
Postscript Text
This is for adding something after the campaign ends. It might have a count of how many finished. Totally optional.
Additional Info/Images URL:
Not sure what this is yet.
_AWARDIMAGE:
_BANNERIMAGE:
An option is to have a campaign banner. These are 468 pixels wide x 60 pixels high. The size is just right to be used as a signature image in people's profiles. Having the banner in signatures makes for a great advertisement of a campaign as it gets seen in all messages posted on Armorama. It is up to the campaign leader to have someone design one then add the URL to the "_BANNERIMAGE:" field. Just the URL is needed, no [IMG] tags are necessary.
Don't forget to bookmark your campaign page. Once the campaign ends, the page will disappear from the main campaign page. It will be easier to find when it's time to hand out ribbons.
After the Campaign
Awarding Ribbons
The first step is to go through the gallery and make a list of all the people who uploaded photos of their finished model. You should also go through the official thread and send PMs to those who uploaded their images there but not to the gallery and get them to upload to the gallery. To qualify for ribbons, it is now a requirement that the images MUST be in the campaign gallery. This makes it much easier to create a Feature of the campaign.
The next step is to go to the campaign page where you should see a link saying "Add/Remove Awards". Clicking it will provide a list of all who enlisted with a "Give Award" button on the end of each name. When you click on it, the ribbon will be awarded. Notice that after awarding someone, the link turns into "Remove". This way you can easily fix things if you give an award to the wrong person. Also note the check box by all the names. You can award multiple ribbons by clicking on the check box for all the awardees then clicking one of the "Give Award" buttons.
After you are done, don't forget to click on the "update" button at the bottom of the page.
Finding the Campaign Page After the Campaign is Over
Don't worry, it's still around! If you go to the Campaigns page, you will see a list of categories (Armor/AFV, Dioramas, Figures, KitMaker University,...). Click on the one that your campaign belonged to and you will get a page with a list down the left hand side of past campaigns. The fastest way to find your campaign is to use your browser's text search as I am not sure there is a pattern to the order that past campaigns are listed in.
Cautionary Note
Things happen in real life. If you can't come by often enough to lead the campaign, notify the campaign manager so a new leader can be found.
For Amorama campaigns: If I notice that you haven't signed on in a month, I will assume something has happened to you and I will find another to replace you.
GaryKato
Posted: Monday, October 26, 2009 - 05:48 PM UTC
OK, this is the first cut. As you can see, I still have some experimenting to do.
Bigrip74
KitMaker: 5,026 posts
Armorama: 1,604 posts
Posted: Monday, October 26, 2009 - 06:21 PM UTC
Gary thank you for the guide lines and descriptions on the campaign leaders. I found that after reading your thead that I finally understood what to do.
Robert
Tarok
Victoria, Australia
KitMaker: 10,889 posts
Armorama: 3,245 posts
Posted: Tuesday, October 27, 2009 - 10:29 AM UTC
A proposal needs at least 10 people replying to the thread saying they would join to move to the next step.
Thanks Gary. But it should be highlighted that the 10 person count is local to Armorama, and that other Kitmaker sites may require fewer participants. For example both Historicus Forma and Auto Modeler only require 5 participants to kick off a campaign.
Rudi
GaryKato
Posted: Tuesday, October 27, 2009 - 10:51 AM UTC
Rudi,
Thanks for pointing that out. I'll update it.
Cuhail
Illinois, United States
KitMaker: 2,058 posts
Armorama: 791 posts
Posted: Tuesday, October 27, 2009 - 04:27 PM UTC
Thank you Gary! This is pretty cut and dry. I wish this thread existed years ago. I've always hesitated before hitting that button to start a Campaign. I finally did and it was really pretty easy, but, I had worked it up as soooo much more complicated in my head. Matt Leese helped a ton.
Thanks for the tutorial. It helps.
Cuhail
AussieReg
AUTOMODELER
#007
Victoria, Australia
KitMaker: 8,069 posts
Armorama: 185 posts
Posted: Tuesday, October 27, 2009 - 08:51 PM UTC
Thanks Gary, I have initiated my first campaign build (Boom Boom - Twin Boom Campaign on Aeroscale) and this thread has answered a few questions that I still had lingering. I can just enjoy the builds now confident that at the end I can reward those finished.
Now EVERYBODY SIGN UP !!!
Cheers, Damian
Cuhail
Armorama: 791 posts
Posted: Wednesday, October 28, 2009 - 01:35 AM UTC
Gary, if you could focus some time on uploading award ribbons, please. I've made the GIF file (to the correct dimensions), followed the directions given by the Admin Edit process, but, it won't load up.
Let me know, huh?
Cuhail
endrju007
Wojewodztwo Podkarpackie, Poland
KitMaker: 2,435 posts
Armorama: 1,256 posts
Posted: Wednesday, October 28, 2009 - 01:42 AM UTC
I've found out that problem may lie in file name. if the extension is ".gif" than everything works ok but if it is written with capital letters ".GIF" it may not be visible on the campaign page.
Andrzej
Cuhail
Armorama: 791 posts
Posted: Wednesday, October 28, 2009 - 01:55 AM UTC
The filename on my computer has it in lower case. AND I renamed it to the "number name" as the process dictated.
C
endrju007
Posted: Wednesday, October 28, 2009 - 01:58 AM UTC
Than I have no idea on what happened Cuhail... Only problem I had with ribbon was caused by extension letters size.
A.
Cuhail
Armorama: 791 posts
Posted: Wednesday, October 28, 2009 - 02:05 AM UTC
The gif image is 83 X 34 pixels (1.7k) is that the problem? (Ya think?) Maybe it's too big?
Cuhail
GaryKato
Posted: Wednesday, October 28, 2009 - 02:06 AM UTC
Cuhail
Yeah. Ribbons are 50 wide by 20 high.
Cuhail
Armorama: 791 posts
Posted: Wednesday, October 28, 2009 - 02:13 AM UTC
Thanks Gary, THAT may just fix the issue...lemme try.
Cuhail
[edit] THAT did it, guys! Thank you very much for the help! [/edit]
Bigrip74
Posted: Wednesday, October 28, 2009 - 02:49 AM UTC
Hi Gary:
I tried to install the ribbon for Mighty 88 and all it did not upload. After looking at the file type it is PNG. How do I try to reinstall when the file is changed to gif. the campaign page does not have the admin create button now.
Robert
GaryKato
Posted: Wednesday, October 28, 2009 - 09:08 AM UTC
There should be an ADMIN: Add/Update Award Image link. Use that.
Bigrip74
Posted: Wednesday, October 28, 2009 - 09:22 AM UTC
Hi Gary:
Sorry to be a pain, the ribbon is in my gallery.
Robert
GaryKato
Posted: Wednesday, October 28, 2009 - 10:55 AM UTC
Hmm. I downloaded the image from the gallery and it looked fine. Uploaded fine too. At least the ribbon is up now. I am puzzled at what happened.
Bigrip74
Posted: Wednesday, October 28, 2009 - 11:06 AM UTC
Gary there is probably a short here between the chair and the keyboard. I tried first with the ribbon in the PNG format then found out that it needs to be GIF. Tried it again when Jaypee converted the image to that format but to no avail (3) times.
Again Thanks for the hard work in dealing with the problems.
Robert
GaryKato
Posted: Saturday, October 31, 2009 - 07:36 PM UTC
I've updated the document for two things:
1. Campaign names should be a maximum of 27 characters. When the campaign is approved, I add the yellow CAMPAIGN tag onto the title of the thread. I can't do that if the campaign name is too long.
2. I added a section at the end to remind leaders to pass leadership to another when real life interferes with running the campaign. Sometimes life takes us by surprise so if I've noticed that a leader has not been online in a month, I will search for a new leader.
GaryKato
Posted: Sunday, November 08, 2009 - 09:46 PM UTC
I've updated the document about two more things:
1. A build can only qualify for one campaign. This rule is set in concrete.
2. Normally a kit can not be started until the campaign starts, but this is really up to the campaign leader.
GaryKato
Posted: Tuesday, November 17, 2009 - 07:00 PM UTC
Updated the document with information about how some file viewers (Windows Explorer, Mac OS X Finder) hide the file extension (".gif") in the filename. This means that you might add a second ".gif" to a ribbon image file and that can cause it not to upload.
GaryKato
Posted: Thursday, November 19, 2009 - 08:17 AM UTC
I added a piece on informally extending campaigns. One of the problems with formally extending a campaign, changing the end date on the campaign page, is that more people might join during the extension. Then they might need an extension to finish. A campaign can be informally extended by not changing the end date, awarding ribbons for those that finished, but awarding a ribbon later when the people who needed an extension finish.
grayghost666
#021
KitMaker: 2,458 posts
Armorama: 656 posts
Posted: Thursday, November 19, 2009 - 01:15 PM UTC
Hello Gary,
Can you add to the campaign leader area a spot for an XO if one is used. That way you can have a replacement ready for a AWOL leader. You also might have a place on the submit page that if something happens to the campaign leader, Who would they like to replace them.
With my recent Illness I made sure that everyone in my campaigns knew that Jim McIntosh was going to be in charge, But I forgot to let you know. I am very sorry about that.
I would also like to suggest that when a person runs a campaign for the first time, You might suggest that a season campaign leader ( that has Ran 5 or more campaigns) to help the newbie and be there to help make the campaign run smoother. Just an idea.
I will be happy to volunteer to help.
Just my 2 cents
Bruce
Tomcat31
#042
KitMaker: 2,828 posts
Armorama: 45 posts
Posted: Sunday, December 20, 2009 - 04:58 AM UTC
When I did my campaign I used this to upload a larger image of the ribbon I had designed. once uploaded there a link on the campaign page under the start and end dates that says "Additional Info/Images: Click here to view" when you click on it it takes you to the image you uploaded.
