Scale Modeling Sponsors
See Your Ad Here!
Dioramas: Flora & Fauna
Trees, shrubs, nature and animals.
making fake mud for scenery ground work.
thanan
Bangkok, Thailand / ไทย
KitMaker: 335 posts
Armorama: 331 posts
Posted: Wednesday, August 04, 2010 - 10:25 AM UTC
Hi friends, again with new method of making mud for diorama scenery ground work. This method of making mud can use to make mud surface texture or tree trunk texture too. It's fast and easy also you can keep it for another works as you need. Thank you to every comments and suggestions from everyone.
drop white glue (latex) to plastic ware (big or small depend on yours work.)
mix on saw dust to the glue ratio 1:1
stir glue and saw dust.
use pulp in brown color and spin it.
mix after spin pulp and drop some turpentine then stir its.
prepare one piece of foam for scenery base (up to yours style)
coat fake mud to scenery base by easily using yours finger.
texture it with plastic sheet.
prepare trees and others while waiting the mud dry.
banana and sugarcane trees.
scatter some of broken bricks to the ground.
after finish and mud is dry then create yours scenery ( I design this scenery to story of Vietnam war.)
mud surface. you can make more dark color if you want.
You can add more fake mud if you want more texture and more details of the surface you want. time for mud use to dry is about 2 hours depend on how thick of it.
Some confuse to my pics explain because of my English not so good please apologize.
MrMox
Aarhus, Denmark
KitMaker: 3,376 posts
Armorama: 1,088 posts
Posted: Wednesday, August 04, 2010 - 10:32 AM UTC
Your pictures speaks a 1.000 words, very good work!
No suggestions - except maybe make the edge of the diorama more uniform/smooth - otherwise, perfect!
Cheers/Jan
brynje
Kobenhavn, Denmark
KitMaker: 176 posts
Armorama: 175 posts
Posted: Wednesday, August 04, 2010 - 09:30 PM UTC
This looks good. And a good and easy technique^^ how do you make mud if you wan't it to look wet? I saw a guy adding floor varnish or something. Maybe you got something else?
meaty_hellhound
KitMaker: 786 posts
Armorama: 753 posts
Posted: Wednesday, August 04, 2010 - 11:47 PM UTC
always fun to see your work Prasert. one option i use is, instead of saw dust, i use fine sand with the fine dirt/water/glue. i find the sand brings the dirt down in scale and works to create a denser "mud".
keep it rolling and love the clear bright pics, you should update your buildings with your new camera my friend. cheers, mh.
HONEYCUT
Victoria, Australia
KitMaker: 4,001 posts
Armorama: 2,946 posts
Posted: Thursday, August 05, 2010 - 03:12 AM UTC
Simple and effective Prasert!
I'm not sure Jan; I think the rough edging adds to the feel of a 'chunk of jungle' ripped out for display, subterreanean and all The shape of the base really adds to this feel methinks...
Brad
Gorizont
Sachsen, Germany
KitMaker: 1,462 posts
Armorama: 1,289 posts
Posted: Thursday, August 05, 2010 - 02:14 PM UTC
Thanks for sharing, Prasert!
I also had many ideas in mind about streets, buildings and also some muddy scenery“s.
Using some plants can give more complex results. (it looks better)
Your english is good and the pictures shows your work and meaning of this.
greetings...
Soeren
thanan
KitMaker: 335 posts
Armorama: 331 posts
Posted: Thursday, August 05, 2010 - 02:58 PM UTC
Hello friends, thanks to all of you about every comments.
Jan: Yes, I think so about that edge. Thanks Jan.
Simon: I mostly use glue call "UHU" to make it look more wet. Thank Simon.
Mh: Thank so much for sharing more technique Mh.
Brad: Thank to yours comment Brand.
Soeren: Thank and very glad of your reply.
Removed by original poster on 08/05/10 - 12:04:22 (GMT).
