Armor/AFV: Modern - USA
M551 SHERIDAN "GULF WAR" (Academy)
bat-213
Canada
KitMaker: 902 posts
Armorama: 788 posts
Posted: Tuesday, August 14, 2018 - 10:22 AM UTC
that is a very cool build ,thanks for shareing .
JSSVIII
Massachusetts, United States
KitMaker: 1,169 posts
Armorama: 1,067 posts
Posted: Tuesday, August 14, 2018 - 11:03 AM UTC
Really nice job, great build!
Klaus-Adler
MODELGEEK
Scotland, United Kingdom
KitMaker: 1,505 posts
Armorama: 840 posts
Posted: Tuesday, August 14, 2018 - 12:39 PM UTC
I thought academy only produced a Vietnam era m551 Sheridan. I didn't know that they made a gulf war version...also I thought the gulf war Sheridan had smoke discharges fitted on the front portion of the turret?
Kevlar06
KitMaker: 3,670 posts
Armorama: 2,052 posts
Posted: Tuesday, August 14, 2018 - 01:02 PM UTC
I thought academy only produced a Vietnam era my 51 Sheridan. I didn't know that they made a gulf war version...also I thought the gulf war Sheridan had smoke discharges fitted on the front portion of the turret?
David, Academy makes two versions-- a Vietnam version with the early coupula and cargo rack, and the late version (which is what this one is) from the 1st Gulf War (ODS). They both have the grenade launchers, which you can see on this model as a small "quad" set of four mounted on the lower side of the forward turret. The Vietnam Version has the more familiar four single launchers along the bottom edge of the forward turret that you are thinking of. As a former Sheridan commander, I've always been frustrated that Academy didn't manufacture the "mid" life Sheridan with the commanders slab armor "teacup" (that's what we called it) laser range finder, and the older cargo rack. If you wanted one of those, you'd need to buy both the "Vietnam" and "ODS" kits and combine the two. Still waiting for someone to produce the 1975-80 version we had in the 11th ACR in Germany-- that's the one I believe you are thinking about right?
VR, Russ
Klaus-Adler
MODELGEEK
Armorama: 840 posts
Posted: Tuesday, August 14, 2018 - 04:12 PM UTC
VR, Russ
Yes that's the one I was thinking of, thanks for the clarification. Great work by the way, I really need to build the ones I have in my stash.
4egevara
Vladimir, Russia
KitMaker: 209 posts
Armorama: 205 posts
Posted: Tuesday, August 14, 2018 - 04:46 PM UTC
Fabulous work really great how did you get that chrome finish inside the search light ?
Hi John! I'm glad that I liked my work. Reflector in the spotlight I made from ordinary foil from candy.
You're welcome!
Thanks for the comment!
Thank you for your appreciation ...
David, thank you for evaluating my work! Good luck in assembling your version of this rover!
VR, Russ
Russ - applaud your knowledge! I learned a lot from your post!
PzDave
KitMaker: 319 posts
Armorama: 285 posts
Posted: Tuesday, August 14, 2018 - 06:38 PM UTC
When I read this I thought--doesn't this guy know the Sheridan was a failure and we don't use this vehicle even in 91! I did a little research and boy was I wrong!! Great build and research sir. Well done model.
4egevara
Vladimir, Russia
KitMaker: 209 posts
Armorama: 205 posts
Posted: Wednesday, August 15, 2018 - 06:03 PM UTC
I was also surprised when I learned the history of the application of this tank ... As far as I know, now I use only as simulators for drivers' mechanics in the US?
David, thank you for evaluating my work.
Klaus-Adler
MODELGEEK
Armorama: 840 posts
Posted: Thursday, August 16, 2018 - 05:49 AM UTC
What sources did you use for your research into this m551 Sheridan? Any books videos or Internet sites would be welcome as I fancy a crack at this kit.
Thanks in advance
GulfWarrior
KitMaker: 1,051 posts
Armorama: 1,029 posts
Posted: Thursday, August 16, 2018 - 06:02 AM UTC
There are some in use by the 11th Armored Cavalry Regiment at Fort Irwin California that are visually modified (VISMOD'd) to look like soviet era equipment, BMPs etc.
4egevara
Vladimir, Russia
KitMaker: 209 posts
Armorama: 205 posts
Posted: Thursday, August 16, 2018 - 04:55 PM UTC
Very interesting information, but there is no photo? One could try to make such a model ... Are they simply painted in khaki, or are some elements added for more visual similarity?
Thanks in advance
The compilation certainly requires improvements and corrections.
From the inaccuracies of my time, here's a wonderful article:
http://www.perthmilitarymodelling.com/reviews/vehicles/academy/acd13208d01.htm
I got acquainted with the books of Steven J Zaloga (US airmobile tank 1941-2001), looked at the photo reviews of this machine on the Internet. I fixed the most powerful mistakes, as it seems to me. In modeling, I prefer to focus on the visual component and not not the match.
Kevlar06
Posted: Friday, August 17, 2018 - 04:03 AM UTC
There are some in use by the 11th Armored Cavalry Regiment at Fort Irwin California that are visually modified (VISMOD'd) to look like soviet era equipment, BMPs etc. [/quote]
Thanks in advance
Besides the sources already listed, I think there's at least one photo in Squadron's "M551 Sheridan" book, and if you look for "OPFOR Sheridan" on line, some photos will likely pop up (OPFOR is an acronym for "Opposing Forces"). The OPFOR sheridans at Fort Irwin were converted to Soviet block type vehicles by using a fiberglass shell to change the turret and body "look" of the vehicle into a "T-72 -T-90 "simulator" or even a BMP. The vehicles were painted overall desert sand. Many flew the green and black OPFOR pennant (green background with a black star in a circle). I just did a quick search on line using OPFOR Sheridans and came up with a dozen or more photos of M551s "dressed" as all kinds of Eastern Block vehicles.
VR, Russ
ttwells
KitMaker: 316 posts
Armorama: 77 posts
Posted: Friday, August 17, 2018 - 06:00 AM UTC
first I loved looking at the building progress and finished model! As for the comments on the weathering, stowage, lights rust etc. you build the way you want and think it looks right. This is one of many reasons I do not like to post models of ACTUAL subjects, or enter in contests for that matter. I recall one time somebody picked apart my M1A1 HA in Iraqi Freedom and its vision blocks. I had reflective material pinkish and green colors and somebody said they didn't look like that.. well photo evidence still didn't shut this guy up so guess what? I stopped posting for a while... so build it to suit your needs
4egevara
Vladimir, Russia
KitMaker: 209 posts
Armorama: 205 posts
Posted: Sunday, August 19, 2018 - 09:48 PM UTC
Thanks in advance
VR, Russ[/quote]
Already searched and found many photos, thanks for the help. Here I think somehow I'll buy some other m551 for experiments ...
I am absolutely convinced that it is impossible to do the right model. Conditionalities have always been and will be. We paint, take pictures, we are all in different ways. Everyone has different monitors, different color renditions, all have different knowledge of history, who knows more, who is less. someone can translate their knowledge visually, someone gets it to a lesser extent. In any case, the main thing that we should receive from our hobby is pleasure. There will be pleasure - all the rest will appear!
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Sunday, August 19, 2018 - 11:58 PM UTC
The VISMODS used at Ft Irwin have fiberglass shells and bits and pieces added to them so they look like Soviet vehicles as well as being repainted. Here are a few.
18Bravo
KitMaker: 7,219 posts
Armorama: 6,097 posts
Posted: Monday, August 20, 2018 - 11:07 AM UTC
First off - very nice build.
Regarding VISMOD M551s - Google is not always your friend when it comes to things like this. However, I have photographed two variants in enough detail you could do very good representations of them.
Example detail shot:
I vacu-formed a turret shell and added appropriate edges with half round.
And for good measure, another based on the M113:
As usual, these walk arounds are far better than what you'll find in any printed publication, or the internet. If you're serious about building one PM your email address and I'll send you the walk arounds.
4egevara
Vladimir, Russia
KitMaker: 209 posts
Armorama: 205 posts
Posted: Tuesday, August 21, 2018 - 04:27 PM UTC
Thank you all for the photos and links. I liked the option of camouflage for an awl, probably on it and stop.
