Not You Average M113
mic113
Morbihan, France
KitMaker: 88 posts
Armorama: 59 posts
Posted: Tuesday, December 31, 2013 - 03:44 AM UTC
Hello to everyone there
I just discovered this subject today after being away from the forum since a long time
Is it still possible to enter the campaign ?
I have been posting some of the variants I did some years ago
You can watch these on my album
If you accept me on your subjetc I will post some pics of Variants I did ?
Regards
mic113
Morbihan, France
KitMaker: 88 posts
Armorama: 59 posts
Posted: Wednesday, January 01, 2014 - 01:01 AM UTC
I just uploaded some of the various M113 and variants I did some years ago
If any interest just browse onto my albums
These are only a few Samples if some interest I can post more !
For the campaign I can upload more pics of the work in process of The Italian submersible version
Removed by original poster on 01/03/14 - 17:34:23 (GMT).
mic113
Morbihan, France
KitMaker: 88 posts
Armorama: 59 posts
Posted: Friday, January 03, 2014 - 05:39 AM UTC
This is the version I choice to enter the campagn
named Arisgator is an Italian amphibian M113 version
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Friday, January 03, 2014 - 08:59 AM UTC
mIchel: Yes, it is still good. I look forward to your build.
gcdavidson
KitMaker: 1,698 posts
Armorama: 1,563 posts
Posted: Sunday, January 05, 2014 - 02:24 AM UTC
I've never seen one with a 25mm turret! PS, the other one in your WIP gallery is excellent!
mic113
Morbihan, France
KitMaker: 88 posts
Armorama: 59 posts
Posted: Sunday, January 05, 2014 - 07:43 PM UTC
more in my gallery
rfbaer
KitMaker: 1,866 posts
Armorama: 1,696 posts
Posted: Wednesday, January 08, 2014 - 04:57 AM UTC
I have a bit of progress on mine, a few external fittings and such. I've got the lights on, the rear can rack and what I believe is a storage box. Some of the pieces to be added later are together but not cleaned up yet. I also put the crane base together, mostly to ck fit to the mount. It's pretty rough, and I expect the rest of the crane to be the same. I also want to do some hydraulic lines on it.
Pics:
Crane base, filler inside.
Rear. Light guards are from scrap PE and plastic; kits parts were pretty poor.
I hace a couple of pics of IDF M113s with what appear to be bash plates over the final drive housings, so I knocked some out using plastic strio and hex rod for bolt heads.
This is actually a pretty rough kit in a lot of places, notably how the left side headlights mount. I've tried to clean this area up, but I may have to hide it with a tarp or spare parts, don't know until I get primer on.
I also tried to detail up the driver's periscopes a little, not much in the kit.
mic113
Morbihan, France
KitMaker: 88 posts
Armorama: 59 posts
Posted: Monday, January 13, 2014 - 04:20 AM UTC
POOOOUUUUUUUUUUUUUUUF
never watched such slow campaign progress !
Nevermind mines are done !
rfbaer
Posted: Wednesday, January 15, 2014 - 07:35 AM UTC
I had a little time last night so I got started on the exterior. It seems like every single part had flash or pin marks or both, made for slow progress, but it's starting to look like the Clampett's truck, so that's good. I can see where a good set of etch would be very useful, but this is supposed to be a quick build, and for me it's going at the speed of light.....
I haven't decided if I'm going to wait for Friuls or order the AFV Club tracks, but I'm not ready for them for a while yet anyway.
I ran in to one big issue with the driver's hatch: with the crane in place, it can't open as it should, hits the crane before it gets to it's fully open, on the rest position. I suppose this is a kit omission, and I don't have any pics of the top of one of these to see if the Israelis modified the hatch itself or built a stop to hold it as I've glued it. I will probably whip something up to look like an extended "rest" bracket or mount.
jvazquez
KitMaker: 857 posts
Armorama: 811 posts
Posted: Wednesday, January 15, 2014 - 08:26 AM UTC
Yea definitely go with the friuls. Granted they are pricey and take almost as long to make as the vehicle itself with all the cleanup and such, but to me the final result is worth it.
When done just right you get just the right sag that is distinctive with the M113.
rfbaer
Posted: Wednesday, January 15, 2014 - 09:44 AM UTC
Yeah, I really like Friuls. I'm just trying to figure out how to get them in the budget.
mic113
Morbihan, France
KitMaker: 88 posts
Armorama: 59 posts
Posted: Thursday, January 16, 2014 - 04:44 AM UTC
Just browse onto your friend "gougl "and you will find alot Of pics of IDF Fitter
That hatch is rarely fully opened when the crane works , then when they drive the crane is on the "road position clamped to his support so the hatch does not interfer with Crane base .
A photo edge set would be terribly more réalistic than the plastic parts specially on all fixing stuff as thickness of brackets would match better to the real deal ! and it was not much more longer to use some of the parts on the outside photo edge set and maybe not all of these ?
Specially for the exhaust side protection that in the kit is and so ugly thick part !!
So in these conditions do you think that expensive and tricky Friul tracks will add more to your model ?
Academy one by one tracks if well assembled and wheathered can be a sufficient solution ( they also are time consuming !!!)
Good luck for your building
canuck100a
Nova Scotia, Canada
KitMaker: 96 posts
Armorama: 96 posts
Posted: Saturday, January 18, 2014 - 02:00 PM UTC
I am in with this kit, but not completely sure what actual vehicle it will end up being, but it will be in realm of what if. I am contemplating mounting a variation of the Marder APC early turret with a ATGM set-up.
Eric
Trackjam
KitMaker: 831 posts
Armorama: 614 posts
Posted: Saturday, January 18, 2014 - 03:03 PM UTC
I wasn't entirely happy with the Accurate Armour hull roof so I made my own. Lots of bolts from Scale Hardware and tie downs from Mouse House. I corrected the tiller bar mechanism and plan to do the same with the pivot steer handles.
mic113
Morbihan, France
KitMaker: 88 posts
Armorama: 59 posts
Posted: Saturday, January 18, 2014 - 10:53 PM UTC
LOT of cheap stuff for various M113 on there ;
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=271376215845&ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=271376930487&ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
http://www.ebay.fr/itm/Kit-M548-afv-club-/271376213771?pt=FR_YO_JeuxJouets_MaquettesModelisme&hash=item3f2f48670b
rfbaer
Posted: Monday, January 20, 2014 - 05:27 AM UTC
Michel, thanks, I'll take a look.
I tried to get the hatch to go through it's travel with the crane base mounted, and it interferes. The only way to get the hatch to swing down was to remove the crane base, which can't be accurate. I think Academy mounted the crane too far forward, but it's way too late to correct that now. I'll just have to improvise.
Yes, I think Friuls are worth it, even w/o using PE on the rest of the model. The kit length and link tracks have a sink mark on every single track pad. I think I could have Friuls assembled and painted in considerably less time than I could get the kit tracks corrected and ready to go on. I really don't mind working with Friuls, and I think the results are well worth the effort.
Mr. Trackjam, sir: very nice work.
rfbaer
Posted: Tuesday, January 21, 2014 - 10:51 AM UTC
I ordered some Spade Ace tracks today, never used them before so I'm interested to see how they compare to Friuls.
ptruhe
KitMaker: 2,092 posts
Armorama: 1,607 posts
Posted: Tuesday, January 21, 2014 - 03:36 PM UTC
I've found mention of a Canadian trial vehicle with a CVR(w) Fox turret. Is this true?
Trackjam
KitMaker: 831 posts
Armorama: 614 posts
Posted: Saturday, January 25, 2014 - 12:30 PM UTC
I had not heard that before now and I haven't seen any photos. But its worth investigating.
ptruhe
Posted: Sunday, January 26, 2014 - 03:09 AM UTC
I've got a spare Fox turret from a Sabre conversion set and it had me thinking.
Found this at http://forums.army.ca/forums/index.php?topic=105622.0:
"There were two variants built as engineering and test platforms. I can't remember how many of each type were built but one had the same turret that the Coyote/LAV III family have. The second had a modified FOX armoured car turret. It looked very much like the 30 or so FV 432's that the British Berlin Brigade had. One mounted the 25mm Chain gun and the other had the 30mm Rarden Cannon.
If memory serves there should be one floating around Borden at the Worthington Tank park Museum. It was there in 91 or 92. They may have been returned to FMC or DEW Engineering"
canuck100a
Nova Scotia, Canada
KitMaker: 96 posts
Armorama: 96 posts
Posted: Sunday, January 26, 2014 - 08:04 AM UTC
Well here is what I have done so far on my Wotif M113. It will be a stretched model mounting the BMP-2 Turret modified with an ATGM set-up. The hull will have bolt on armour panels.
I am not sure but contemplating a Digital camo scheme (CANPAT or a Winter Mod.)
Eric
canuck100a
Nova Scotia, Canada
KitMaker: 96 posts
Armorama: 96 posts
Posted: Monday, January 27, 2014 - 02:55 AM UTC
Sorry .... Typing without checking.... CADPAT not CANPAT.
Eric
rfbaer
Posted: Monday, January 27, 2014 - 07:43 AM UTC
I got a little time Friday, and did some exterior detail work, brackets, welds, bolt-heads, stuff like that. I need to nut up and start on the crane, but it's moving along.
I haven't decided on the final position of the rear ramp, so I'm leaving it workable as long as possible.
Trackjam
KitMaker: 831 posts
Armorama: 614 posts
Posted: Monday, January 27, 2014 - 01:44 PM UTC
Depending on how nuts you want to go, here are a couple of drawings of the pivot steer mechanism. I'm putting this detail on my M113A2 with Delco turret.
