Dioramas: Buildings & Ruins
Ruined buildings and city scenes.
4barrels of anti terror
roudeleiw
Luxembourg
KitMaker: 2,406 posts
Armorama: 2,224 posts
Posted: Sunday, June 23, 2013 - 09:18 AM UTC
Just pull it off? LOL! That was probably to easy to try
MOL, that was my first ever expo, that's 6 years ago already!
See you
Claude
turkeyshot
New South Wales, Australia
KitMaker: 138 posts
Armorama: 133 posts
Posted: Monday, June 24, 2013 - 11:31 AM UTC
This is looking great! I like the way that you used skewers to depict the holes torn through the walls by this beast. I look forward to seeing more progress on this build.
wildsgt
Kentucky, United States
KitMaker: 327 posts
Armorama: 259 posts
Posted: Monday, June 24, 2013 - 08:59 PM UTC
I read some ware that misting the paper with water helps it to come off easy
jointhepit
Oost-Vlaanderen, Belgium
KitMaker: 3,829 posts
Armorama: 881 posts
Posted: Monday, June 24, 2013 - 11:49 PM UTC
guess that's possible Bill,but beware the stuff wrapps like crazy when wet,might work if not too we, but I think you are going to get a mess, because the toplayer is a sort of glosspaper then a layer of more fibre cartboardstuff
when tearing it of be carefull to hold it flat , so you don't rip it appart,the 8 and 12 mm are not that much a problem, but the smaller size tends to break if not carefull
also pressure when ripping of may leave marks into the soft foam, and textures varie the way you rip it off... it's all a feelin game
also, use SHARP, I mean like surgical sharp knives to cut it ,if not you will get raffled edges (af course one can afterwards fill'm or sand them down )
but still more work...
also try findin a ruler with a straight back,preff0.5 to a cm high in order to cut somewhat straight into the cardboard/foam (if cardboard still attached,first go over the drawn line, with the scharp point,try to not cut thru, then after 1 or 2 passes, you'll be able to (using the ruler) cut easier thru the thickerpaper underneeth and foam, leaving the backpaper uncut (you can now tear it appart,or go another pass with the blade to cut thru the backside(flip it ove it's easier) beware of not adding... another angle to the side (been there done that )
I leave on side on (back ) so the hting has some strenght while manipulating, and you don't get the back all F'd up with small debris that gets stuck, or rips streaks and holes in the soft foam.
also to watch, when linin' up a wall for bricks (small ones)
it's MUCH easier to calculate an edge on all sides of 0.5 cm or more, to put the points of reff (I use a needle to make a small hole) . it's really, I mean REALLY depressing to notice you're of 2mm, after you've just done 10cm on 20cm bricks of 3mm high,6mm long, you count'm ,I just went aAAARAAAARGHH,you know, and that happens faster then you'll think, measure measure,and check constantly for errors.
but Life is hard ,so mistakes happen, the sooner you see'm the easier they are to fix,especially when building old or destroyed building like we do
need to know more, feel free to ask
jointhepit
Armorama: 881 posts
Posted: Monday, June 24, 2013 - 11:51 PM UTC
This is certainly not quite what I was expecting to see, looking good as usual. Hope to see some more progress soon, this is an excellent use of space and very useful example for me.
holy macaroni ,gettin this from you Jeremy!
thank you !
wildsgt
KitMaker: 327 posts
Armorama: 259 posts
Posted: Tuesday, June 25, 2013 - 12:04 AM UTC
Thank you Pit. I will let you know how it turns out
jointhepit
Armorama: 881 posts
Posted: Wednesday, June 26, 2013 - 08:25 AM UTC
aargh, 3 time I write this, I return buttoned 2 other attemps....
damage by small arms and shilka to second floor, added roof and roofterras border thing, let me know what you think of it...
DSC05595x
DSC05594x
DSC05592x
DSC05591x
jointhepit
Armorama: 881 posts
Posted: Tuesday, July 02, 2013 - 04:36 AM UTC
small update, made balcony guard from wire of a electronic component from a VCR
CA glued,made jig for S part
closed most gaps,added window sill, sprayed grey primer,rest tommorow gotta work tonight
DSC05600x
DSC05609x
DSC05611x
DSC05612x
DSC05616x
jointhepit
Armorama: 881 posts
Posted: Thursday, July 04, 2013 - 07:10 AM UTC
slap some paint on, after priming and looking for defaults,
DSC05626x
DSC05625x
jointhepit
Armorama: 881 posts
Posted: Thursday, July 11, 2013 - 08:10 AM UTC
I see silence is approval
some more pics
DSC05637x
DSC05638x
jointhepit
Armorama: 881 posts
Posted: Monday, July 29, 2013 - 09:24 AM UTC
silence of the modellers?
anyways after a vacation, back to the modelling table, done some damages on the second building, and added the oblicatory unfinnished floor
DSC05061x
DSC05060x
DSC05059x
kurnuy
West-Vlaaderen, Belgium
KitMaker: 1,491 posts
Armorama: 997 posts
Posted: Saturday, August 31, 2013 - 10:46 PM UTC
I'm looking forword to see more of your work Pit !
Greets. Kurt
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Sunday, September 01, 2013 - 01:13 AM UTC
This is coming along nicely for sure. Don't worry about the lack of responses too much,it is pretty common on this site. Just pay attention to the number of"hits" you get to see how it is going over.
J
parrot
KitMaker: 1,607 posts
Armorama: 1,581 posts
Posted: Sunday, September 01, 2013 - 01:37 AM UTC
J
I love the buildings.It will be great to see the finished project.Jerry's right,I've posted some pics and no one replied.
Tom
Snorri23
KitMaker: 514 posts
Armorama: 261 posts
Posted: Sunday, September 01, 2013 - 03:07 AM UTC
A lovely build going on here. I for one do not build such elabourate constructions. Not enough room to house them when done. Though I do obtain some good ideas. Thanks for sharring.
strongarden
KitMaker: 730 posts
Armorama: 624 posts
Posted: Sunday, September 01, 2013 - 05:03 AM UTC
ThaPit- First time viewer, and I like this!
Great idea/story and great craftsmanship as well.
That's one nasty match-up:
Cramped urban setting, concealed RPG runners vs a Shilke!!! You're really capturing the feel of it!
Awesome. Will be following along...
Dave
jointhepit
Armorama: 881 posts
Posted: Sunday, September 01, 2013 - 07:50 AM UTC
thanks all, almost gave up on the project( got that a lot )
have some doubts on how to finnish the road,can't seem to make up what I'm to put, pavement? asphalt?
I also am tryin' to make it work in the "lay out and dimensions" way,meaning, the shilka isn't that awesome,and I don't have any good rebels (need some runnin' away)nor do have I found a suitable AT milan kinda type pointing down from one of the buildings.
next weekend there is KMK (a meeting ) and I hope to find suitable thingies there.
wonder also if I need to destroy my buildings more to satisfy the viewer, or I can leave them like this, untouched, only by shilka,aka, not pierced by AT or T72 shells..?
greets Tha Pit
