T-90A movable barrel rebuild
steeds
Liaoning, China / 简体
KitMaker: 11 posts
Armorama: 8 posts
Posted: Wednesday, October 02, 2013 - 09:11 PM UTC
Hi guys,
I start to built the meng's T-90A with some scratch techniques, first is the barrel protective sleeve ,I used a balloon to build it. I made a ring of about 10mm diameter used a 0.5mm copper wire and put it on the balloon, then I covered the balloon onto a glass injector in order to adjust the shape of the balloon, you can get a fine drape performance if the pressure is correct. After applied the super glue just on the ring, turned over the balloon and sealed the ring in it.
movable mechanism inside the turret
The movable connecting rod mechanism of IR Shtora-1.
I also make a sleeve of condom using same method, and it performed a fantastic effect.
Here is other processions I made, Thank for watching! Next scratch I decided to apply is lighting IR Shtora-1 used optical fiber. Wish I could make it.
spetsnazgru
Lebanon
KitMaker: 655 posts
Armorama: 646 posts
Posted: Wednesday, October 02, 2013 - 10:13 PM UTC
I'll be watching your build, so, you used a condom, now thats something.
great build and great skills.
WARDUKWNZ
Auckland, New Zealand
KitMaker: 1,716 posts
Armorama: 1,638 posts
Posted: Wednesday, October 02, 2013 - 10:38 PM UTC
Brilliant bit of thinking there Andy mate ,,have to admit i'd never think of using a condom for that ..other uses come to mind
Phill
steeds
KitMaker: 11 posts
Armorama: 8 posts
Posted: Thursday, October 03, 2013 - 12:07 AM UTC
Thanks my friend,the balloon is also a good choice,it performs a good efect as well if you can find a thinner one.
steeds
KitMaker: 11 posts
Armorama: 8 posts
Posted: Thursday, October 03, 2013 - 12:13 AM UTC
Phill
you can try it,I sure you it will bring you pleasure.
Jacques
Minnesota, United States
KitMaker: 4,613 posts
Armorama: 4,481 posts
Posted: Thursday, October 03, 2013 - 04:34 AM UTC
Condom use looks good, and brings a whole new meaning to "cover that cannon"!
UGBEAR
Canada
KitMaker: 236 posts
Armorama: 235 posts
Posted: Thursday, October 03, 2013 - 07:44 AM UTC
Condom can also protect your firearm from getting wet crossing swamp&jungles during the pacific&Vietnam war
steeds
KitMaker: 11 posts
Armorama: 8 posts
Posted: Thursday, October 03, 2013 - 02:34 PM UTC
Take care of every kinds of firearm is its job
steeds
KitMaker: 11 posts
Armorama: 8 posts
Posted: Thursday, October 03, 2013 - 02:41 PM UTC
sorry I don't get it,what's the primary meaning of "cover that cannon"!
SDavies
KitMaker: 979 posts
Armorama: 959 posts
Posted: Thursday, October 03, 2013 - 07:29 PM UTC
Very interesting use of materials, when I saw the first picture i thought it was some kind of outlandish drug kit
"cover that cannon" is a pun on the intended use of the condom and the fact that you have used it to cover a canon which may euphemistically refer to a willy
1721Lancers
KitMaker: 1,673 posts
Armorama: 1,640 posts
Posted: Friday, October 04, 2013 - 12:19 AM UTC
Cool ideas Andy, but how do they react to paint?
It's not as if I'd be elevating and depressing the gun all
day, it's just I can't imagine paint sticking to these things
Jacques
Posted: Friday, October 04, 2013 - 02:04 AM UTC
It is a double pun:
1. It refers to condoms and their primary use covering a privates, which many men jokingly refer to as their "cannon", among MANY other things. There are also a lot of sayings associated with getting men to use a condom, like "wrap that rascal" and a million iterations therof, all to help lead to protection, and so the phrase "covering that cannon".
2. It refers to the fact that tank main guns have covers that go over them as well to keep water out of the barrel during stowage or transport. You truly must "cover that cannon". (The mantlet cover is also used to protect from weather, but is a semi-permanent item and, honestly, not as funny).
That you have mixed the two, a mantlet cover made from a STD prevention product, produces all the joke needed.
Have I over-explained it enough yet?
steeds
KitMaker: 11 posts
Armorama: 8 posts
Posted: Friday, October 04, 2013 - 01:57 PM UTC
That was really the problem I was worry about.But after testing with the Mr.Hobby's thinner,it seemed nothing happened,of course the oil must be wash out before paint.but there are many materials of condom,should be tested brofore using.Actually the air is the real killer of my mantlet,aging of rubber must be avoided,I have applied the white glue(mostly used by paper crafter)onto the surface. Move it all day may course the peeling,but I friend of mine had built a similar one used plastic wrap once,the paint is still there for years.
steeds
KitMaker: 11 posts
Armorama: 8 posts
Posted: Friday, October 04, 2013 - 02:07 PM UTC
It is a double pun:
Thanks for your explaination,have learned more.I have almost thought out the answer,but not sure of it.
it makes the topic funny.
Jacques
Posted: Friday, October 04, 2013 - 03:54 PM UTC
No problem on the long winded explanation.
As for the mantlet cover, it almost seems like you need to make a master you like and then make a casting of it out of a different kind of rubber. I believe there should be materials that you can use to mold that also have enough play in them to allow the barrel to elevate and depress.
steeds
KitMaker: 11 posts
Armorama: 8 posts
Posted: Tuesday, October 08, 2013 - 09:39 PM UTC
Today the postman arrived, what the f※ck! I knew VM and Trumpeter are good friends! I would have thought of that before I bought it.Does anyone need this ?I would like to sell it by half price.
Sgt_Pickle
Kaunas, Lithuania
KitMaker: 103 posts
Armorama: 101 posts
Posted: Wednesday, October 09, 2013 - 12:57 AM UTC
The link is broken
JCGabis
Massachusetts, United States
KitMaker: 2 posts
Armorama: 2 posts
Posted: Thursday, October 31, 2013 - 09:23 AM UTC
Try silk,
JCGabis
KitMaker: 2 posts
Armorama: 2 posts
Posted: Thursday, October 31, 2013 - 02:00 PM UTC
I love what your doing. Having the main gun stuck like that for more than 4 hours l think your suppose to call a doctor. I'm building the Zvezda t-90 now. I was going to hack it up to get the profile right,(I've Ben watching some crazy Russian master the kit on panzer54 for about a year) then comes Meng! I decided to just glue Zvezda together and finish it.OOTB still fun to put together! I got my Meng t-90 last week,I had to have it! I pondered lowering the main gun too.I find the t-90 to be a fascinating subject.I love the work you did on the shtora linkage.
vlad_8011
Krakow, Poland
KitMaker: 4 posts
Armorama: 4 posts
Posted: Saturday, September 13, 2014 - 11:43 PM UTC
Man its Amazing, i've created account here specially for reply to you and to say that i have done smillar thing to you Heres Mine workshop
http://www.modelarstwo.org.pl/forum/viewtopic.php?f=83&t=52508
But i've made only movable barrel, not shtora IR lights.... I'm gonna build this model again and i'm writing to meng, for they create some PE parts for it, but look like they ignoring it. It will be preally good to se your guide with better photos, and how you make connections(movable) between two rods? From wire? If yes how is it ending, it must hold those 2 rods.... Please reply
vlad_8011
Krakow, Poland
KitMaker: 4 posts
Armorama: 4 posts
Posted: Sunday, October 19, 2014 - 10:47 PM UTC
How you make connection of this 2 little parts? what is connection for them, so parts are holding to it and dons fall from it, beign movable? Please reply, i will make this model agains, i'm waiting till it be aviailable again in my shop.
vlad_8011
Krakow, Poland
KitMaker: 4 posts
Armorama: 4 posts
Posted: Saturday, October 25, 2014 - 05:03 AM UTC
Hello?!
