Яusso-Soviэt Forum
Three T-55 variant kits by SKIF Finished
1721Lancers
KitMaker: 1,673 posts
Armorama: 1,640 posts
Posted: Thursday, March 27, 2014 - 03:08 AM UTC
Thanks fellas.
Paul, The silicone stuff is sold by ProSeal.
The mold was made by applying several thin coats letting each one cure before the next because it's "air dry" maternal
Thanks, I'll give it a try.
KoSprueOne
Myanmar
KitMaker: 4,011 posts
Armorama: 1,498 posts
Posted: Saturday, March 29, 2014 - 03:40 PM UTC
Cool Paul, this stuff is 1 dollar a tube and you can cast with A+B epoxy glue if needed.
Anyway, the FAVORIT upper hull was warp saggin' on top.
Measured the difference
Cut support pieces from kit sprue
Exhaust system assembly parts fit in place
chefchris
KitMaker: 1,544 posts
Armorama: 1,464 posts
Posted: Tuesday, April 01, 2014 - 12:40 PM UTC
I admire your dedication.... following with interest.
KoSprueOne
Myanmar
Posted: Wednesday, April 02, 2014 - 11:47 AM UTC
Thanks Chris.
The fuel tanks and (storage?) boxes on the fenders are done. Now starting to approach all the kit supplied PE for the hulls
KoSprueOne
Myanmar
Posted: Tuesday, April 08, 2014 - 03:28 PM UTC
Running out of time on this campaign. I'm going to continue by concentrating on the FAVORIT driver training tank. Then finish the other two after that.
The head lights guard is PE so it is square instead of tubular. First I needed to make a form to bend it around. They provide dimensions in millimeters in the iSheet.
Basic geometry made this simple.
Then the fender support PE was cleaned up and arranged for position on the model. The iSheet describes specific locations in millimeters for this.
moving right along
KoSprueOne
Myanmar
Posted: Monday, April 14, 2014 - 01:36 PM UTC
The turret is a simple structure. The turret parts sprue is a different color green and a different plastic.
Some major gappidge needed filling with putty and the kit iSheets describe metal parts included for making grab handles for the sides of the turret. My kit did not include this material
I made my own with stretched sprue
putty in the gappidge
nice weld detail on top
Web searching images in 1/1 compared to the model part, I figured out the dimesions of the grab handles
mark the right side for drilling
mark the left side for drilling
trial and error gets an acceptable result
The Driver Training Instructor hatch needs a handle too
KoSprueOne
Myanmar
Posted: Sunday, April 20, 2014 - 11:25 AM UTC
The FAVORIT is ready to paint. Perfect weather here today so I'll get primer on it and maybe the base coat color
KoSprueOne
Myanmar
Posted: Saturday, April 26, 2014 - 11:02 AM UTC
Painted and weathered. I kept it super subtle because I read that the Czech armor aren't all grimy and thrashed but well kept
I don't know, I might go a little further with this
KoSprueOne
Myanmar
Posted: Sunday, May 04, 2014 - 08:41 AM UTC
the BUBLINA hull is assembled with kit supplied PE and other details.
the tow bar thing'a-ma'jig assembly instructions:
These parts needed cleanup before and after gluing together because of weird alignment issues. Part (3N) was molded solid in the two ends. I cut and sanded open these details with a razor saw and #600 sand paper
the brass detail was some scrap PE frame from this kit, cut to size and glued there to represent detail that I sanded off during parts cleanup
The fender fuel tanks and storage box , tow bar and engine deck are dry fit in place for the picture but will be painted separately
the head light brush guard "bird cage" was assembled around the same wood form that I used for the FAVORIT
KoSprueOne
Myanmar
Posted: Sunday, May 04, 2014 - 09:19 AM UTC
This part (what is this part called?) was very thick and just didn't look right. I thinned it by filing it down on a sanding stick for grip.
This was done for the FAVORIT and the SLA APC. The BUBLINA doesn't get one according to the SKIF instructions
looks a little better but I accidentally dulled my nice file by sanding across the abrasive stick
KoSprueOne
Myanmar
Posted: Sunday, May 04, 2014 - 09:43 AM UTC
The SLA APC-55 was based on a hand me down Tiran T-55 tank from the IDF. A lot of the detail and other profiling comes from that
The i-sheet for the head light brush guard PE assembly. I used the technique that I used for the 'bird cage' of the BUBLINA and FAVORIT by making a wooden form to bend the brass over.
the first bend was made in my bench vise
Then another wooden form was made for the water bottle holder on the left fender
the kit PE for the fording equipment has detail on one side and flat on the other. I searched ref photos and looks to me that this will be glued with the detail on the bottom and flat side up
the hull and details are basically assembled
KoSprueOne
Myanmar
Posted: Sunday, May 04, 2014 - 10:12 AM UTC
the SKIF kit hulls ready for primer.
left - FAVORIT
middle - BUBLINA
right - SLA APC-55
assembly of the turrets next. Thanks for looking
Nito74
Lisboa, Portugal
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Sunday, May 04, 2014 - 11:11 AM UTC
Great work with the PE.
Those SKIF's are coming along great !
KoSprueOne
Myanmar
Posted: Monday, May 05, 2014 - 02:06 PM UTC
Thanks, John
KoSprueOne
Myanmar
Posted: Sunday, May 25, 2014 - 09:56 AM UTC
BUBLINA T-55C1 turret build is complete with some work required and some just added for interest
The company sprues that were added to the FAVORIT, BUBLINA and SLAPC-55 kits are from Master 44 UA.
The casting is rough.
Removal of .5 mm of material from inside of the TC hatch opening is required to fit (part 3G) hatch ring into top of turret. I used a rat tail round file for this operation. I should have used a larger radius half round file or maybe a, sheet metal step drill, that has the perfect diameter cutting step.
https://s3-ap-southeast-1.amazonaws.com/easystore.co/14425/images/products/1493877.jpeg
The method I employed resulted in a very rough shape. Once the hatch ring part fit snugly but without distortion, I glued in place with liquid cement to give me time to position level and correct. After that set and cured over night, I filled with CA and let that run into the remaining space and gaps.
Front turret plugs were also kit supplied parts and were used as instructed and not puttied smooth because I saw reference pictures and those looked like roughly plugged cavities.
Putty filled the gaps left over on the TC hatch ring now
The 2 view scopes on the top of the turret were modified together from parts on the sprue of this kit that were designated as "not to use". I saw more reference pictures on line so I added these to my model for added detail interest.
The kit provided plastic grab handles for the sides of the turret were used but are very fragile. The only way I could clean the seams off of these parts were to cradle them in a piece of neoprene tape while sanding and filing smooth.
The turret ring keys need to be filed down in width to fit into the hull key ways.
This turret is now ready for primer.
KoSprueOne
Myanmar
Posted: Monday, May 26, 2014 - 03:03 PM UTC
The SLA APC-55turret is finished.
Before glueing in part (1d) into turret part (1f), I did some other things. Part (7d) needs to be glued in before part (1f).
This part (7f) lower hatch ring must be glued in after slicing off registration pegs. Position in this configuration but cut off pegs.
I didn't do this and it made a weird oval.
My beautiful assistant saw this and thought I was making her a ring.
Such an imagination in that pretty little head
The TC scope has a sink hole in the cast. This is covered buy the PE part.
There are no registration marks to set the vision blocks onto the turret. I saw reference photos and it looked like the LH side was further back.
There was fit gap issues with this build so I used CA sand putty.
The reference photos I saw placed these vision ports at "about there" and "about there".
The left side is just behind the 90º mark. This is where I glued mine.
These are suppose to be glass so I polished mine here.
trim the PE hooks down to about half. I glued the tracks on first then glued the PE hooks parts into it later.
Stretched sprue was used to make the LH turret grab handle.
The i-sheets describe PE part 22t but for the water bottle rack on the RH rear side, use part (31t).
There PE was bent astound another wooden form for this.
SDavies
KitMaker: 979 posts
Armorama: 959 posts
Posted: Monday, May 26, 2014 - 07:43 PM UTC
Very nice build thread and interesting T55 varients. I will be following with interest
KoSprueOne
Myanmar
Posted: Tuesday, May 27, 2014 - 02:11 PM UTC
Thanks for checkin' in
chefchris
Posted: Tuesday, May 27, 2014 - 03:42 PM UTC
Now to the nitty gritty! How about the blower hole on the turret lower side? And beveling the edge of the turret base? Driver's washer fluid tank on the RHS? Fuel lines? Just messing with you....
I love the work you've put into these kits. It inspiring to those of us that love the T54/55/62 series of tanks!
Chris
KoSprueOne
Myanmar
Posted: Wednesday, May 28, 2014 - 03:08 PM UTC
Hi Chris, Thanks for the comments
BTW, beveling is for wood shop. In steel you chamfer
KoSprueOne
Myanmar
Posted: Sunday, June 01, 2014 - 02:54 AM UTC
The KMT-6 Mine Plow on the T-55C1 BUBLINA assembly.
Some guess work and preliminary dry-fitting is required to assemble the mine plow mechanism assembly.
I should have used parts (19 and 20) instead of parts (9N and 14N) as instructed.
Parts (19 and 20) are cleaner casts and I wouldn't have had to shave off the mounts on the front of the lower hull.
Clean-up of the new parts from the Master44 sprue is difficult. Good news is that they won't be clearly seen.
The 'string' which is to be cut to 40mm in length is not included in my kit. I used sewing thread on this build.
The holes were drilled in the appropriately suggested places and the thread was threaded through.
The bottom of the plow arm assemblies have a sink mark in exactly the right place. I used them to guide my drill for a through hole. This is where I glued one end of the (cable).
The detail on the cylinder is pretty plain. I assume this activates some sort of unlocking device which then allows the plow to drop into the dirt . . . ? . . .
inside view of LEFT plow arm
outside view of RIGHT plow arm
I searched the web for as much ref pictures showing the function and route of the cable. The thread (cable) was guess guided through the mechanism and glued in place.
KoSprueOne
Myanmar
Posted: Monday, June 02, 2014 - 03:37 AM UTC
BUBLINA T-55C1 is ready for primer. I still need to acquire a set of SKIF vinyl tracks for it
The crooked and misaligned, fender fuel tanks and storage boxes are just set up there for the picture
South Lebanon APC-55 also ready for primer.
The crooked and misaligned, fender fuel tanks and storage boxes are just set up there for the picture.
KoSprueOne
Myanmar
Posted: Tuesday, June 24, 2014 - 09:49 AM UTC
BUBLINA T-55C1 under base coat of UN white. Subtle weathering underway. This is my first white military vehicle so this is a learning experience for sure.
Base coat Rust-Oleum gloss white sprayed out of the can. Then light gray pin acrylic washes followed by about 10 sable brush filters so subtle that I couldn't even see the effects each time. I just had to trust that they were working.
A little more grime under the fenders behind the wheels. This was ground down chalks mixed with hobby acrylics wash
1721Lancers
Posted: Tuesday, June 24, 2014 - 06:50 PM UTC
KoSprueOne they are looking fantantasic mate ,
glad to see you are still at 'em
KoSprueOne
Myanmar
Posted: Wednesday, June 25, 2014 - 01:25 PM UTC
Hey Paul, thanks for the comment and for dropping in.
The SLAPC goes under primer in a few minutes
