Hosted by Richard S.
Civil War/ Proxy Super Power War Part II
Tanksami
Victoria, Australia
KitMaker: 1,292 posts
Armorama: 1,203 posts
Posted: Friday, January 02, 2015 - 01:14 PM UTC
Hi Alex,
I believe that you are the first to break plastic & get us away from the starting line!! Thank you sir!!
On a personnial note I must say i am stoked that you did in the end decide to do the Argie LTVP-7.
Cheers Mike
BigSmitty
Minnesota, United States
KitMaker: 597 posts
Armorama: 439 posts
Posted: Saturday, January 03, 2015 - 08:45 AM UTC
Got the M-41 started. Simple kit, not much detail, so I don't see this build taking more than a week. After a couple of hours last night, here's the progress:
I plan on using .010" sheet styrene to cover the bottom of the hull motorization holes, etc.
I just need to find some aftermarket decals. I might spend a little and pick up some workable tracks, even though the kit vinyl tracks aren't too bad, considering the kit molds date to 40 years ago (1975). Pretty crazy.
Tanksami
Victoria, Australia
Posted: Saturday, January 03, 2015 - 12:48 PM UTC
Hi Matt,
Looks like you are off to a very good start with your walker bulldog
Mike
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Saturday, January 03, 2015 - 12:59 PM UTC
I've decided to go with Verlinden's M50 turret, if I can source the suspension.
Tanksami
Victoria, Australia
Posted: Saturday, January 03, 2015 - 01:39 PM UTC
Hi Matt,
Sounds good the more variety the better I say!! Lol
Mike
BigSmitty
KitMaker: 597 posts
Armorama: 439 posts
Posted: Sunday, January 04, 2015 - 06:32 PM UTC
So this is what happens when you build a Tamiya kit with only two sprues and a single A4 sheet and the weather is "chilly" outside...
I've seen photos of the M-41s with the pintle mount and no MG, which is how I've got this one set up. Also, only the rear antenna was fitted to the example I'm doing, so I deleted out the front antenna near the commander's cupola.
This is just dry fit, the upper/lower hull haven't been joined, the wheels are not fixed, and the turret is loose. Lots of clean up work yet to do, including filling in the driver vision ports with clear tinted styrene. Archer Fine Transfers make a nice Lebanese Civil War (1976-1978) set with Arabic sayings (and translations) for vehicles so I'll probably pick it up for the build.
Tanksami
Victoria, Australia
Posted: Monday, January 05, 2015 - 11:39 AM UTC
Hey Matt,
Some very nice progress there, she is coming along nicely
Mike
BigSmitty
KitMaker: 597 posts
Armorama: 439 posts
Posted: Monday, January 05, 2015 - 06:38 PM UTC
Thanks Mike.
Lots of clean up still left to do. For some reason Tamiya didn't mold the stowage box sides on the upper hull, so I'm going to make them up with strip styrene as best I can. Also the rear idlers show lightening holes on the box art and in some examples, but the idlers in the kit are solid, so I'll probably drill them out to be a bit more accurate. Quite a bit of extra work to do, but then again, the kit was less than $15.00 so I'm okay with it.
retiredyank
Posted: Tuesday, January 06, 2015 - 09:22 PM UTC
On examining the kit, some pieces are missing and the hull has had a very poor attempt at being built. I have a couple of other kits, in my stash. I'll see what I can come up with.
hofpig
KitMaker: 1,329 posts
Armorama: 1,016 posts
Posted: Saturday, January 10, 2015 - 09:52 PM UTC
Finally getting around to start this one.
Not sure if I am going to use the figure set or try to cobble something together from the spares. Also not sure if I am going to use all of the Dshkm set I have the old zevezda AA set to use as a fall back if it does not work out.
SGTJKJ
#041
Kobenhavn, Denmark
KitMaker: 9,912 posts
Armorama: 4,633 posts
Posted: Sunday, January 11, 2015 - 06:02 PM UTC
Some interesting builds here. I could not resist joining yet another campaign. I hope I can finish it in time.
I have no idea what I will build, but research starts now
Tanksami
Victoria, Australia
Posted: Sunday, January 11, 2015 - 11:38 PM UTC
Hi Jesper,
Welcome on board!!! Thanks for joining us!!
Cheers Mike
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Monday, January 12, 2015 - 02:20 AM UTC
I am joining with a Dragon 1/35 IS-2m tank from the Korean War. The markings are for Chinese "volunteers". I guess the Korean war both qualifies as a civil and proxy war.
More to follow when I get started.
retiredyank
Posted: Monday, January 12, 2015 - 05:27 AM UTC
Good news. I managed to break down the Sherman. It came with everything to build a Firefly and that is the route I will go.
Tanksami
Victoria, Australia
Posted: Monday, January 12, 2015 - 07:02 AM UTC
Matt,
Very glad to hear it :-)
Mike
RuloMxy
District of Columbia, United States
KitMaker: 154 posts
Armorama: 137 posts
Posted: Thursday, January 29, 2015 - 08:34 AM UTC
Hi all,
I will be building a T-34/85.
Tanksami
Victoria, Australia
Posted: Friday, January 30, 2015 - 10:30 AM UTC
Hi Raul,
Welcome on board & thanks for joining us!! So what thearte will your tearoom be joining us from??
Cheers Mike
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Saturday, January 31, 2015 - 09:46 PM UTC
Great that you join us, Raul. Will you make it a Korean War "buddy" to my IS II or choose another conflict? The T-34 and T-54/55 seem to have fought in almost all the post WWII conflicts.
Looking forward to see more!
RuloMxy
KitMaker: 154 posts
Armorama: 137 posts
Posted: Monday, February 02, 2015 - 08:09 AM UTC
Hi Mike and Jesper,
Thanks for the warm welcome! The T-34 will most likely be a Chinese/North Korean in the Korean War (Jesper, it seems that your JS-2 will have a "buddy").
Here is an update. If it continues snowing like it has so far, I will finish it soon .
medicosmp
Belgrade, Serbia & Montenegro
KitMaker: 15 posts
Armorama: 10 posts
Posted: Monday, February 02, 2015 - 06:20 PM UTC
Finally I broke my plastic, it is going to be in Libyan rebel markings !
After two quiet 12 hours night shifts (in my local IR) I done this much, I decided to do it OOB except maybe to replace barrel with brass/plastic tube...
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Monday, February 02, 2015 - 08:36 PM UTC
Sounds cool, Raul. Nice progress already.
Alexander, nice choice. I always expected this kit to be crap based on the ugly and old school box. It actually looks quite desent and with crisp detail based on the pictures. How is the overall Fit?
medicosmp
KitMaker: 15 posts
Armorama: 10 posts
Posted: Monday, February 02, 2015 - 11:29 PM UTC
Jesper,
I was sceptical at first but this kit assembles like dream, there are 235 parts and it is FUN ! Overall fit is excellent, Trumpeter however was carried away with small parts and they intend to break when cutting them from a sprue !
retiredyank
Posted: Tuesday, February 03, 2015 - 01:28 AM UTC
I'm changing my entry. I will be building the GAZ Tiger, as it appeares(d) in the Ukraine. I hope the Crimea is considered a civil war?.
Bluestab
South Carolina, United States
KitMaker: 2,158 posts
Armorama: 1,906 posts
Posted: Tuesday, February 03, 2015 - 11:14 PM UTC
I've been taking my time with the Hobby Boss LVTP-7 in Argentinian Markings. It's got a pretty nice interior and I want to get it right. Anyway, blah, blah, blah...update time.
I got things rolling with the road-wheels, drive sprockets, and idler wheels. Pretty standard assembly. I did go ahead and prepaint the insides of the wheels with green.
Jet thruster units...parts and then assembled. Definitely a long way from Academy's old LVTP-7.
Suspension arms and the drive shaft and driveshaft guard for the jet thruster units.
I decided to go ahead and pre-paint the lower hull and wheels.
Out of paint. Added the front headlights. HB does this with a recessed insert and the lights are individually molded. Adding the lights is a bit fiddly.
Stepped back to work on the tracks. They are individual track links with separately molded rubber pads. They require a bit of cleanup. I staged out clean-up and assembly over a couple nights. The links appear to be semi-workable as they can click together. I'm not sure how well they'll stay together without cement.
Road-wheels painted up and mounted. Also added the thruster units guards. Those shaft units won't really be noticed once the outer cover pieces are added.
Time to start on the interior. I decided to pre-assemble a lot of the interior and paint as much of it as possible before installing them in to the hull. I dry-fitted the parts and some will require some work to fit.
And that's where I am now. I'll probably start with a base coat on the interior tonight or tomorrow.
medicosmp
KitMaker: 15 posts
Armorama: 10 posts
Posted: Wednesday, February 11, 2015 - 04:56 AM UTC
it is finally assembled, replaced some pasts with styrene rods, now ready for primer:
test fit :
cheers
Aleksandar
www.medicisdetails.com
