Armor/AFV: Contests
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 1,387 posts
Armorama: 1,346 posts
Posted: Thursday, September 14, 2017 - 01:29 PM UTC
I see, Robert.
Am doing quite the opposite-almost no painting during winter, mainly construction.
During spring,summer and autumn I do both construction and painting, providing temperatures allow it.
Which was not always the case this summer with it's hot waves (40 grad Celsius)-particularly when I was building the Backanhaenger.
Then-as Mike suggested in one of his posts- very often I felt almost like a reenactor-building and painting an oven in a hot oven.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Thursday, September 14, 2017 - 01:53 PM UTC
My next scratchbuilding project:
RRH auf Sd.Ah.104.
It was in use with Bulgarian Royal Army during WWII:
I will use an excellent refference on German Flak and Flak apparatus:
And some pictures found on the net-among them a superb walkaround from a French museum(ASPHM), whose site I highly recommend.
My starting point will be the frame:
Picture courtesy of ASPHM
165thspc
#0
Kentucky, United States
KitMaker: 9,205 posts
Armorama: 8,439 posts
Posted: Thursday, September 14, 2017 - 08:19 PM UTC
Clearly Angel you love a challenge!
pgb3476
KitMaker: 969 posts
Armorama: 968 posts
Posted: Thursday, September 14, 2017 - 08:24 PM UTC
Have you looked at the carriage to the "Alan" models 88. They look very similar to your photo. It would be a good starting point I think.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Thursday, September 14, 2017 - 08:57 PM UTC
Mike,
the biggest challenge will be finding suitable tires.
What I found sofar unfortunately requires a compromise in accuracy
Greg, thanks for the hint!
I am affraid Alan's-nowadays Ark Model's-88(8.8 cm. PAK 43/41) won't suit because it was transported on Sd.Ah.204.
104 and 204 do really look similar, but 204 carried bigger payload.
165thspc
#0
Posted: Thursday, September 14, 2017 - 09:15 PM UTC
This probably WON'T be a viable suggestion but someone (I believe either Plus Models, Real Models or Azimut) makes the large searchlight in resin on the 104 trailer.
I suspect they would be willing to sell the trailer seperately. However between the trailer and the listening equipment the trailer I think, would be the easier portion to scratch build. Maybe just try to purchase the wheels/tires.
165thspc
#0
Posted: Thursday, September 14, 2017 - 09:46 PM UTC
This is probably a real stretch but both Blast Models and Azimut make resin replacement wheel sets for the AHM truck. You might have to buy two sets to get what you need but any possibility these would work for you?
165thspc
#0
Posted: Thursday, September 14, 2017 - 10:07 PM UTC
I know this is a bit of a drive but if you need a hands-on reference there is the new museum: MM PARK MUSEUM, LA WANTZENAU, ALSACE, FRANCE has two 104 trailers one carrying the 150cm searchlight and one with the accompanying generator.
120+ beautifully unusual off-road and military vehicles. The web link follows:
http://www.unusuallocomotion.com/pages/museums-and-exhib-iii/mm-park-museum-la-wantzenau-alsace-france.html
165thspc
#0
Posted: Thursday, September 14, 2017 - 10:42 PM UTC
Frenchy - You really should check out this Museum if possible. I certainly wish I could make the trip!!!!!!!!
ayovtshev
#490
Sofiya, Bulgaria
Posted: Thursday, September 14, 2017 - 11:12 PM UTC
Mike,
DesKit of France is doing both the 150 cm. Flakscheinwerfer and the Maschinensatz for it.
About the tires-my options curently are resin sets of tires either for Henschel 33D1 or Krupp L3H163.I've build the Renault AHN of ICM(it was the second most important truck in Bulgarian Royal Army-after the Blitz), but I totally missed to consider it as a possible vendor...Unfortunately AHN tires show same problem-they are too narrow(approx. 1 mm less width).
Tomorrow I'll check whether the tires of Sd.Kfz.7 are not a better solution.
Then I'll buy and ask a friend of mine to cast me some copies-at least 10, because I have plans for 2 additional scratchbuilds on Sd.Ah.104 trailer.
This newly opened museum in France is a real treasure.
Last weekend I found a wonderfull walkaround of the vehicles on Sd.Ah.104 there and have put Wantzenau on my to-visit list.
165thspc
#0
Posted: Thursday, September 14, 2017 - 11:33 PM UTC
Relative to the size of the Sd. Kfz. 7 wheels and tires please know that the tires that came with the old Tamiya 8 ton and the Flak 88 were much smaller in diameter than the currently available resin replacements. I bought some civilian replacement tires for one of my old Tamiya Sd. Kfz. 7's and for a moment I worried the new tires might not fit under the fenders.
I could probably locate a set of four old Tamiya tires and rims if you are interested in giving them a try. (Finding one would be no problem at all if you want to try and cast them.)
165thspc
#0
Posted: Thursday, September 14, 2017 - 11:50 PM UTC
Here is a comparison photo of the smaller diameter, old Tamiya rubber tire and the new Voyager resin AM offering.
Please also consider that in this photo I have already sanded a flat into the bottom of the resin tire AND sanded off the rather sharp shoulders of the Voyager cast tire in order to make it look smaller when installed on my old Tamiya kit.
I have some concern that the old Tamiya tire might still be too large for the 104 trailer which is why I suggested the AHM tire.
165thspc
#0
Posted: Friday, September 15, 2017 - 12:00 AM UTC
The Tamiya tire measures 1 - 3/16 inches or 28mm in diameter.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Friday, September 15, 2017 - 07:52 PM UTC
Mike, thanks for the effort.
I think I have a winner, and it is the 8.8 cm Flak tire size.
The Henschel and Krupp tires mentioned in my previous posts are too narrow(170 mm true size vs. 210 mm true size by Sd.Ah.104).
Sd.Kfz.7 tire is also not suitable, because it is wider(235 mm. in real life).
Sd.Ah.202, that carries the 8.8 cm. Flak 36/37, had tire width of exactly 210 mm.Armorscale of Poland is offering a resin wheels set for Dragon's Flak that includes 8 tires.
I'll go for it!
165thspc
#0
Posted: Saturday, September 16, 2017 - 01:44 AM UTC
Angel what is your plan for making the fenders for the 104? I just cut up a set of old Tamiya Flak 37 fenders to use on another "farm wagon". If I had it to do over I would narrow them and try to build a 104.
Don't really want to invest that much money but I may have to spring for the 150 cm. Flakscheinwerfer and the Maschinensatz from DES. Have wanted these two items for a long, long time.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Saturday, September 16, 2017 - 02:32 AM UTC
Mike,
The fenders are the next big challenge.
Sofar I've considered:
-forming them with burnishing tip from thin copper sheet.Tried today, it is doable, but due to the complex curvature each fender must be split into 2 separate pieces, joined by soldering.
-doing masters from wood and sort of vacuum-forming them from styrene."Sort of" because I don't have vacuum former.
-forming them with Miliput on wood masters.Not sure wouldn't they break easily once curred.
Each approach has it's pro's and con's.And for sure there are other ways.
Des Kit products are really good- and not so expensive when compared to recent plastic releases of some particular brands.
165thspc
#0
Posted: Saturday, September 16, 2017 - 04:03 AM UTC
From the shape of the fenders it sounds like Vac-Forming would be the way to go. That process most resembles the stamping process that made them way back when in the first place.
Home built Vac-Former??? Sheet styrene, hair dryer and the intake side of a fairly good air compressor????
165thspc
#0
Posted: Saturday, September 16, 2017 - 04:18 AM UTC
YouTube video on building your own small Vac-Forming frame. Uses your home vacuum cleaner for suction and he uses his kitchen stove to pre-heat the plastic !!!!!!
https://www.youtube.com/watch?v=2BR9aayq-tw
Stickframe
#362
KitMaker: 1,591 posts
Armorama: 1,201 posts
Posted: Monday, September 18, 2017 - 12:34 AM UTC
Guys - - you are doing pretty unbelievable work on those trailers - in terms of construction (beautiful) and research! The mobile spotlight will be a fun build to watch!
I'm still moving along with my cast of characters for an upcoming diorama - first up, the, T-55 AMV is ready for paint. This has been a very challenging build, that I've enjoyed quite a bit - a key challenge:
No, the optivisor never came off of my head! these parts are small...!!!
I am by no means remotely any sort of T-55 expert - but I can say, I have really enjoyed this build - went together pretty well - getting the ERA block brackets to work in a few cases was as hard as the tiniest bits of etch - but, so far so good - now on to some paint - and, yes, in this case obviously, some heavy weathering.
Next up - a 6x4 tractor. This tank came as a package deal from Takom, along with a tractor an trailer. As I recall the tractor is a Ural - which is really nice - but, in looking for this tank, in the area I'm planning for my dio - I didn't find a single image of a Ural being used - instead almost all other brands - but no Ural -in fact, most in the pics are cabovers - likely used for hauling around containers. So, i found a 1/32 scale 4x4 tractor kit, and converted it to a 6x4. This isn't done yet, but you can clearly see what I did - frame extension (shockingly all six tires touch the ground and the frame is straight!), extra axle etc etc - please have a look:
So -there you have it -
happy model building -
Nick
JSSVIII
Massachusetts, United States
KitMaker: 1,169 posts
Armorama: 1,067 posts
Posted: Monday, September 18, 2017 - 03:59 AM UTC
Love your t-55 Nick, that's a ton of work! Looking forward to the painting process. Truck looks good also, nice work getting all those wheels to sit right.
SpeedyJ
Bangkok, Thailand / ไทย
KitMaker: 1,546 posts
Armorama: 1,110 posts
Posted: Tuesday, September 19, 2017 - 06:11 PM UTC
Hi everyoe.
Just wanted to share this link.
http://www.militarymodelling.com/forums/memberpostings.asp?c=39462&p=110
Shows a lot of basic, but also very high level scratch building. Read it, nice subjects!
Kind regards,
Robert Jan
165thspc
#0
Posted: Wednesday, September 20, 2017 - 12:01 AM UTC
Good stuff. Thanks for sharing.
SpeedyJ
Posted: Saturday, September 23, 2017 - 03:46 PM UTC
Hello all.
Been working on the Feuerleitpanzer the last two week. A lot of dry fitting and giving strength to the body of the Panzer. Made the swing door, roof and visors. Now the roof can be my lead for the final fix, that was my thinking in short.
That turned to be a good idea, but the backside gave me lot of trouble. Backside is almost ready and to cut away sides would throw me back in the build. Finish of the backside including the inner walls will be my next step and try to get some paint on.
Photos...
Lots of work to do. Noticed that one cabinet is totally of the hook now. So surgery to be done.
Also worked on some Sd.Kfz. 7/3. Link I provided one post earlier is a treasure for halftrack builds in the future.
Hope you all like it so far.
Kid regards,
Robert Jan
165thspc
#0
Posted: Saturday, September 23, 2017 - 08:07 PM UTC
Look'n good!
Stickframe
#362
Posted: Tuesday, October 03, 2017 - 04:50 AM UTC
Nice work going on here as always! At this point, I'm a bit embarrassed to be showing this - while it involves lots of modifications and was adequately frustrating, maybe not up to what you guys are doing otherwise!
So, for today, I'm calling the truck, trailer and tank done! or, almost, done! The trailer needs some attention - but, it's close.
First up, you'll see some pics of cargo tractors pulling tanks on trailers - I include these, as on another thread, there has been quite a bit of discussion in regard to what can and can't pull the T-55....I'm satisfied my tractor can pull this trailer!
First up, some examples:
I found many pics of commercial trucks pulling these tanks, but none like the one in the kit - so, please see below:
So, not the same, but I will live with it!
On to the load:
And there you have it - again, I'm calling it mostly done - some grime etc to be added here and there. Next, I'll start a log over on the dio forum to bring these odds and ends together-
thanks for checking it out
Nick
