caragd
Torino, Italy
KitMaker: 50 posts
Armorama: 43 posts
Posted: Sunday, August 07, 2016 - 07:18 PM UTC
Good subject and good work, I was struggling with it in the past there are many mistakes even in front axle and everywhere some missing in driveline and brakes.
I guess my built can help you.
http://www.cmtonline.it/cmtonline.it/VTR-DARIO_CARAGLIO/Pagine/HEMTT_977.html
Dario
165thspc
#521
Kentucky, United States
KitMaker: 9,465 posts
Armorama: 8,695 posts
Posted: Sunday, August 07, 2016 - 10:00 PM UTC
Dario - that is going to be an invaluable reference! I am going to be looking at your photos A LOT!
Missed the bit about the steering connector rod being BEHIND the #1 axle. I did think it was strange for a heavy vehicle to have it out there in front of the first axle where it could get bent and knocked around.
Thanks for the contribution!
Taylornic
Tennessee, United States
KitMaker: 337 posts
Armorama: 332 posts
Posted: Monday, August 08, 2016 - 07:53 AM UTC
Thanks for the info, Mike. Looking fantastic!
caragd
Torino, Italy
KitMaker: 50 posts
Armorama: 43 posts
Posted: Monday, August 08, 2016 - 07:36 PM UTC
Mike if you need I'll upload some other photos
Missed the bit about the steering connector rod being BEHIND the #1 axle. I did think it was strange for a heavy vehicle to have it out there in front of the axle where it could get bent and knocked around.
165thspc
#521
Posted: Monday, August 08, 2016 - 08:45 PM UTC
Dario, I would love to see ANY additional photos especially any under body photos that show the brake actuators and/or the torque control rods attached to the differentials!
I am about to the point where I am thinking maybe I should follow Gino's train of thought and just buy the new Trumpeter HEMTT and add the Italeri LHS parts to it!
For now I am keeping the faith and continuing on with this project but I am beginning to question this course.
p.s. As to detail photos of the HEMTT I am finding that it was easier to find detailed reference photos of the Russian MAZ 8x8 trucks I built a few years back than it is to find decent info on the HEMTT. Even the HEMTT TM manuals show very few (read none) overall images and everything is in the form of line drawings which are so close up to the part in question it is difficult to orient yourself to what you are actually looking at without the real vehicle in front of you for reference.
Hate to say it but I think the Russians do a much better job on their maintenance manuals! At least for our purposes.
165thspc
#521
Posted: Monday, August 08, 2016 - 11:46 PM UTC
Still trying to come up with a solution for the outboard differentials. I fear anything I do will end up looking like a botch job.
This is as far as I have gotten. Whatever I produce at least it will look smaller than the other diffs, WITHOUT the gear reduction head and the drive shaft entry bearing will be more centered than it was.
( I will throw in the comment that the Russians just put a single reduction gearbox between the engine and transmission of their monster 8x8's and the entire drive line then gets to run at a reduced rpm, which I'm guessing also improves the operational life of all the bearings and U-Joints in the system! )
165thspc
#521
Posted: Tuesday, August 09, 2016 - 04:32 AM UTC
Not some of my best work but I am going with it!
A pyramid of rough cut plastic circles. Plus a lot of sanding, some body putty and a lot of primer.
165thspc
#521
Posted: Tuesday, August 09, 2016 - 05:11 AM UTC
Cool info on 20 and 40 foot shipping containers plus some new cool trucks coming our way at:
http://armorama.kitmaker.net/forums/250266
Taylornic
KitMaker: 337 posts
Armorama: 332 posts
Posted: Tuesday, August 09, 2016 - 05:53 AM UTC
A pyramid of rough cut plastic circles. Plus a lot of sanding, some body putty and a lot of primmer.
Looks good. I had been thinking about your post. I was going to suggest possibly cutting the domes off the axle housings from an m35 or m923 kit to use as the third member housing on your axle housings.
165thspc
#521
Posted: Tuesday, August 09, 2016 - 06:54 AM UTC
Hot Dawg! Three axles on the ground!
165thspc
#521
Posted: Tuesday, August 09, 2016 - 07:29 AM UTC
165thspc
#521
Posted: Tuesday, August 09, 2016 - 10:03 AM UTC
Can anyone direct me to a site that would give me some idea what radio would be proper for this rig? Again I am a newbie to anything past 1945.
Epi
KitMaker: 3,586 posts
Armorama: 2,556 posts
Posted: Tuesday, August 09, 2016 - 10:09 AM UTC
A single SINCGAR or ASSIP set up would work perfect.
Check out the pic I took for Primeportal on the radio setup.
My radio walk around on Primeportal
Check out these Trumpeter instructions on where to mount the antenna and radio.
M983 Instructions
Removed by original poster on 08/10/16 - 09:41:13 (GMT).
165thspc
#521
Posted: Tuesday, August 09, 2016 - 07:21 PM UTC
As we all know, once completed this LHS assembly has to move through almost a full 90 degrees to function. (Or at least be posable.)
I just wanted to recommend a thorough clean up of any mold lines or burrs in the area of the main hinges. I you don't succeed in getting this hinge to move freely you will end up breaking off either the hinge pins of the hinge tabs on that big main strut.
Problem: Italeri intends that this be a snap together hinge but once a proper clean up in done chances are the hinge will loose this "snap on" quality.
I recommend adding some hinge retainers below the main strut once you are happy with your clean up work and the hinge is moving freely. (Of course use caution not to get any glue muddled into the hinge itself.)
Just a suggestion.
165thspc
#521
Posted: Tuesday, August 09, 2016 - 07:39 PM UTC
More cool stuff on Military Forklifts and Container Handling at:
http://armorama.kitmaker.net/forums/128796
165thspc
#521
Posted: Tuesday, August 09, 2016 - 07:46 PM UTC
Thanks Taylor for backing me up, still I wish I could have done a better job on the face of that simple differential on axle #4.
I still have axle #1 yet to do maybe I will do a better job there. At least the back side of the diff is looking good with all that added bolt head detail, plus the oil check and drain plugs - that is what is really going to show under the front of that cab.
Today's assignment: working on the many torque struts (two per axle) needed for this rig!
165thspc
#521
Posted: Tuesday, August 09, 2016 - 07:58 PM UTC
Also my thanks go out to Epi for his info on the SINCGARS radios. It is going to take me awhile to digest that. WWII tank radios were bad enough - WOW!
I think Mikeybugs is working on doing those radios right now. Looks like I will be placing another order with Shapeways or Click2Detail!
165thspc
#521
Posted: Tuesday, August 09, 2016 - 08:49 PM UTC
Slightly off topic as this is a 10x10 PLS (but a tempting build none the less.)
One of my favorite photos of modern US equipment.
The last axle is also powered. (I think that is a bit of over kill.) The axle uses radius rod suspension linked to air bag springs.
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Tuesday, August 09, 2016 - 08:55 PM UTC
Your detailing of the M1120 LHS is looking good. It will be really nice when done. Are you also planning on putting a container on the back. If so, the Trumpeter one looks better than Italeri's offering at about the same price.
Slightly off topic as this is a 10x10 PLS...
Yup, an M1074 PLS, which is exactly what I plan on kitbashing together from the Italeri M1120 LHS parts; Trumpeter M983 for the cab, chassis, and main running gear; the additional axle and suspension parts from Accurate Armor's M1070 HETS, and wheels/tires from the Hobby Boss M1070 HETS. The center axle is actually the one with the radius rods and air bags. As you can see below, the last two axles are the standard HEMMT style, with the middle one w/the air bags.
On an M1070 HETS, but the setup is the same.
It should be a fun build...eventually...
Hisham
Al Qahirah, Egypt / لعربية
KitMaker: 6,856 posts
Armorama: 6,363 posts
Posted: Tuesday, August 09, 2016 - 09:15 PM UTC
Michael.. you're doing a nice job on this kit.. it'll be a good reference if I decide to do one.
Hisham
165thspc
#521
Posted: Wednesday, August 10, 2016 - 12:02 AM UTC
Gino - That's what I get for taking (or giving) reference to/from a fellow modeler on the Internet. I am sure in the photos of his model he was adding the extra axle in the rear position. I know his extra axle was definitely powered but perhaps I misunderstood it's location.
Is that center (extra) axle on the PLS also driven? In my design world it wouldn't be. Hey when you already have an 11 ton capacity 8x8 and need more load capability you probably don't need the extra traction of a 10x10. But this is the US Government we are talking about; so why have just one when you can have two at twice the price.
165thspc
#521
Posted: Wednesday, August 10, 2016 - 12:04 AM UTC
Hisham, coming from you that is high praise. Thank You Sir!
Thirian24
Oklahoma, United States
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Wednesday, August 10, 2016 - 12:23 AM UTC
With Trumpeter and Italeri putting out new/newer HEMTTs, I wouldn't be surprised if we see an actual kit of the M1074 PLS. At least that's what I'm hoping for.
165thspc
#521
Posted: Wednesday, August 10, 2016 - 12:39 AM UTC
Dustin, given the commonality of so many of the vehicle parts and the market's current willingness to produce almost everything under the sun I feel it is just a matter of time until we get a PLS.
We can thank the current state of the CAD design industry and the ease of digitally printing masters and proof/check copies of the model designs for the bounty of models we are seeing coming to the market.
