Hosted by Richard S.
Landships Campaign
SGTJKJ
#041
Kobenhavn, Denmark
KitMaker: 10,069 posts
Armorama: 4,677 posts
Posted: Saturday, June 10, 2017 - 02:09 AM UTC
A little more progress on my beast. The filling, sanding, and reconstructing with plastic card continues. Never ending story apparently.
To break the monotony I have constructed some of the weapons. the barrels on the two gatling guns needed replacement. Looking at the picture I still need to align a few things.
More to follow as I progress
Hudson29
#460
KitMaker: 1,156 posts
Armorama: 1,024 posts
Posted: Monday, June 12, 2017 - 10:55 PM UTC
Steve - I agree with Karl, it sure looks terrific so far. Is this the Dragon kit?
Hudson29
#460
Posted: Monday, June 12, 2017 - 10:58 PM UTC
Shalta - We are scheduled to complete September 1 so there is still time left. Should some of us need extra time we might apply for and be granted an extension.
Hudson29
#460
Posted: Monday, June 12, 2017 - 11:07 PM UTC
Jesper - Your beast is coming along nicely. Do you know how you are going to finish it?
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Friday, June 16, 2017 - 01:18 AM UTC
Thanks, Paul. I have not decided yet. I am learning towards the space wolves chapter or the Ultra marines. Not sure yet.
I have finished all the weapons now with the exception of the multi melta guns on the front.
Still a lot of sanding and filling remains. Hope to get some done over the weekend.
Mrclark7
KitMaker: 503 posts
Armorama: 477 posts
Posted: Sunday, June 18, 2017 - 01:09 AM UTC
once I get home tonight I would like to join this with my entry, from Academy, the M3 Lee.
Ramanathan
#477
Pest, Hungary
KitMaker: 133 posts
Armorama: 131 posts
Posted: Sunday, June 18, 2017 - 02:41 PM UTC
Hello gentlemen,
Jesper, that beast is looking really cute Some refreshing new look...
My T-35 progresses slowly, I've drilled all the friul track links (there is A LOT) and constructed the track - this time without CA glue and it works! And spares a lot of time...
cheers,
Zsolt
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Monday, June 19, 2017 - 01:51 AM UTC
Thanks, Zsolt.
The tracks look really nice. Did you have to drill each link?
My Mastodon is now ready for primer. I am sure more sanding will follow as primer always reveal a lot of missed areas.
More to follow
Hudson29
#460
Posted: Monday, June 19, 2017 - 05:07 AM UTC
Zsolt - Your T-35 is looking great! I really like Fruils and have a set for my own T-35 should the kit tracks turn out poorly. How did you build them without CA glue? Do you remember how many links you ended up using? Your track tension looks just right.
Hudson29
#460
Posted: Monday, June 19, 2017 - 05:08 AM UTC
Jesper - Good solid progress on your Mastodon. It looks like it needs plenty of putty. Are you using Green Stuff or something else?
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Monday, June 19, 2017 - 09:27 AM UTC
I am using a standard mix of 50% milliput and 50% greenstuff. I find greenstuff adds a good flexibility while you work with the putty, while the milliput ensures it dries up real hard so it can be sanded after it has dried.
Requires some more work to first mix milliput, then mix greenstuff, then mix the two together, but I think it is worth it.
And yes it requires a lot of work and putty!
Ramanathan
#477
Pest, Hungary
KitMaker: 133 posts
Armorama: 131 posts
Posted: Monday, June 19, 2017 - 02:01 PM UTC
I've read on some of the forums (don't really remember, where) that in case of the longer, heavier Friul tracks it is enough to put in the wire "pin" and the weight of the track itself holds it in place.
My technique was to cut 1-2mm shorter wire pieces than the full length and put them in the hole fully with the end of the tweezer.
In this case I had no work with cutting the too long wires after gluing - once the shorter wire slipped fully into the hole, it doesn't fell off. Tadaaaammmm
Regarding the link numbers: I have no idea, I've made two equal lenght just a little shorter than the final and the last 4-5 links on both were attached with constant checking on the running gear to look right. But my son is just learning the numbers so I can offer him something chocolate-like to do the counting for you
@Jesper: yes, all of the links has to be drilled but carefully not to drill fully 'cause the links are separated to left and right side tracks and the track pin is molded on.... my bad luck was that I had two bags of left hand side tracks and I bought it second hand so haven't tried to contact the producer - the difference is hardly visible. Especially after weathering.
cheers,
Zsolt
Hudson29
#460
Posted: Wednesday, June 21, 2017 - 01:28 AM UTC
I have noticed on several sets of Fruils lately that they came with two sets just the same rather than being handed. The Churchill & Panther tracks stand out in my mind. Once assembled and glued with paint & weathering the difference has not been noticeable. I wonder if Fruil found out that few notice? I do prefer the handed sets.
JSSVIII
Massachusetts, United States
KitMaker: 1,169 posts
Armorama: 1,067 posts
Posted: Wednesday, June 21, 2017 - 03:52 AM UTC
I did not realize that Fruils ever came with handed sets, anybody know which sets included right and left handed tracks?
dtniedert
Kentucky, United States
KitMaker: 152 posts
Armorama: 139 posts
Posted: Wednesday, June 21, 2017 - 04:17 AM UTC
I believe they are referred to as mirrored tracks. I know some Tigers have a set from them.
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Wednesday, June 21, 2017 - 04:22 AM UTC
Ok, i'm actually getting a 'compatible' entry that isnt idiotic at best (Ah, M60 = Landship... Such a technicality)
I've got a Takom St. Chamond on order for next month that I'll be able to work on, as the Chi-Ri went nowhere yet.
Ramanathan
#477
Pest, Hungary
KitMaker: 133 posts
Armorama: 131 posts
Posted: Wednesday, June 21, 2017 - 11:23 AM UTC
My latest build was the Tamiya Jagdpanzer IV L/70 and that Friul set was this right-left handed track type. The most important feature of them is that you should not drill the "outer", bigger hole of the links fully as Friul molded the track pin ending on them - according to the side.
Hudson29
#460
Posted: Friday, June 23, 2017 - 05:14 AM UTC
All of these would be great, the important point is that you find a Landship that pleases you to build.
Hudson29
#460
Posted: Friday, June 23, 2017 - 05:20 AM UTC
As far as I know ALL Fruil sets are supposed to be handed. It even mentions on the box that they have a set for each side. They are packaged in two different bags to keep them sorted. Lately several of my sets have had the two bags but both bags contained sets for only one side. I haven't beefed about it, just muddied up the tracks so the lack isn't obvious.
I'm building a set of Soviet T-26 tracks for a Polish 7TP kit for the POLAND 1939 campaign. I'll soon find out if they are handed or not . . .
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Friday, June 23, 2017 - 05:59 AM UTC
Yup, I'm pretty sure I've found my entry! I've been on a slight WW1 obsession lately, So... Timing, lol.
Only problem is that I'll have it halfway through next month, and, a bit embarrasingly, I've yet to try weathering at all (In fairness, Life decided to be problematic just after I painted my first model!)... So, It's pretty likely that I'll have it built + painted, but I'll have to learn quick to get that done before the end date!
And getting/uploading pictures is liable to be 'funny', Though I shouldnt have any issue there.
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Friday, June 23, 2017 - 08:57 PM UTC
Random question, would a FT-17 be valid for this campaign? I picked one up a few weeks ago, and I'm probably going to build it as soon as I finish the Challenger I'm working on (For the last 6 months...).
It seems like it'd be stretching 'landship' a bit far though.
Either way, Still getting the Chamond next month as it looks like a pretty simple build (No PE!)
Hudson29
#460
Posted: Saturday, June 24, 2017 - 12:01 AM UTC
Sorry, the FT-17 is a bit too far of a stretch.
This is a great place to learn weathering. It is quite an art, one I have only just started myself. Make it easy on yourself and do just the amount that strikes you as right. Look at the models others have build for inspiration. If it looks right to your eyes, it will be right. The big thing is to start and not be too worried about making mistakes. You will learn by trial & error and we are all here to support you.
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Saturday, June 24, 2017 - 12:35 AM UTC
I assumed that myself, just had to make sure. Still might drop a few progress pics here as a test though! As old as the FT is, it's a bit too 'modern' looking. It's not going to stop me from making sure I get it right and enjoy the build
(... It cant possibly take over a month to build, I hope!)
Fair enough though, my 'goal' for the Chamond is weathered enough that it looks done (Light dust, a bit of mud on tracks / lower hull), and maybe go a bit crazy on it later. Overall I'm not looking for an insane amount of wear anyway, Really hard to estimate though.
But hey, Good excuse to figure it out!
ltb073
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Friday, June 30, 2017 - 06:40 AM UTC
Ok so here is my start photo
Was able to get a start this morning and this is what it looks like tonight
JSSVIII
Posted: Friday, June 30, 2017 - 09:18 PM UTC
Sorry Sal but your the newest victim of the new Photobucket policy.
