Armor/AFV: Axis - WWII
Sd. kfz 7/1 z 2 cm Flak 38 - Dragon 1:35
Stojkovic1987
Wojewodztwo Slaskie, Poland
KitMaker: 255 posts
Armorama: 254 posts
Posted: Friday, May 19, 2017 - 01:45 PM UTC
Hello,
Another weathering steps was completed
The platform
Platform with the mounting of the Flak
And with the Flak itself
At the moment the rear part of the vehicle looks like that:
Stojkovic1987
KitMaker: 255 posts
Armorama: 254 posts
Posted: Monday, May 22, 2017 - 01:16 AM UTC
And the last glance at the model before galery photos
Thanks for watching!
GazzaS
#424
KitMaker: 4,648 posts
Armorama: 2,248 posts
Posted: Monday, May 22, 2017 - 02:03 AM UTC
Wow, just fantastic!!
Stojkovic1987
KitMaker: 255 posts
Armorama: 254 posts
Posted: Monday, May 22, 2017 - 12:31 PM UTC
Thanks!
erichvon
KitMaker: 1,694 posts
Armorama: 1,584 posts
Posted: Monday, May 22, 2017 - 03:15 PM UTC
That is a lovely build. Just the right amount of weathering and really nicely done. I built the Tamiya version with the Flak 37 and really enjoyed building it as it's an interesting vehicle. Any plans to install a crew?
Stojkovic1987
KitMaker: 255 posts
Armorama: 254 posts
Posted: Wednesday, May 24, 2017 - 11:15 AM UTC
Not sure I'll do any crew or vigniette with this veicle.
Dioramartin
New South Wales, Australia
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Thursday, May 25, 2017 - 08:53 AM UTC
Hey Lukasz hope you’ll reconsider not adding figures – this is an excellent-looking vehicle, a crew standing around will bring it alive even more. Incidentally the top-right barrel (looking from the front) seems mis-aligned, you’ll need to fix that.
Stojkovic1987
KitMaker: 255 posts
Armorama: 254 posts
Posted: Thursday, May 25, 2017 - 11:23 AM UTC
Hello Tim,
I just fixed this and a left side armor plate which was little too far from the main gun.
Stojkovic1987
KitMaker: 255 posts
Armorama: 254 posts
Posted: Wednesday, June 07, 2017 - 12:27 PM UTC
The Final effect as below. Thanks for the suport during the building proces.
165thspc
#521
Kentucky, United States
KitMaker: 9,465 posts
Armorama: 8,695 posts
Posted: Wednesday, June 07, 2017 - 06:07 PM UTC
Beautiful build all-in-all. Great camo and weathering effects!
However hood still looking uneven. Rear driver's side corner of hood is higher than on co-driver's side. Seams are uneven between hood and radiator cowl also between hood and engine side panel.
165thspc
#521
Posted: Wednesday, June 07, 2017 - 06:27 PM UTC
Another question: Why do you have the spare tire mounted to the back wall of the cab? I admit it looks great as you have it there, but there is already a bracket frame located under the rear end of the gun deck that is intended to hold the spare. The area behind the cab actually has, I believe, a fold down bench seat. Which provides a small, somewhat sheltered area for the gun crew for rest, shelter from the elements as well as some shelter from flying shrapnel.
This area is necessary to be clear and open for proper operation of the ammo loading crew when firing the guns to the rear of the vehicle. Feeding this beast is quite a job when firing at the maximum rate. Adiquate clearance for movement of the gun crew can be an issue here.
All_You_Can_Kit
Jakarta Raya, Indonesia
KitMaker: 599 posts
Armorama: 527 posts
Posted: Wednesday, June 07, 2017 - 06:55 PM UTC
Nice touch on the interior and engine detail, keep up the good work, mate! Can't wait to see the completed applied camo
Warm regards from Indonesia,
Garry
165thspc
#521
Posted: Wednesday, June 07, 2017 - 07:36 PM UTC
Crew seat in folded position on un-armored Sd.Kfz. 7 Flakvierling: (Modified Tamiya model)
Spare tire stowage on Sd.Kfz. 7 MWS:*
______________________________________________________________________________________________________
Below is your photo of underbody detail showing spare tire mounting bracket:
* Exact mounting means of spare tire, to my knowledge, may have varied but tire always carried in this general location, out of the way, not taking up valuable crew space.
165thspc
#521
Posted: Wednesday, June 07, 2017 - 08:10 PM UTC
By the way, your model photography is excellent!
vettejack
KitMaker: 1,277 posts
Armorama: 1,254 posts
Posted: Wednesday, June 07, 2017 - 09:47 PM UTC
Nicely done indeed!
bill_c
MODEL SHIPWRIGHTS
KitMaker: 10,553 posts
Armorama: 8,109 posts
Posted: Wednesday, June 07, 2017 - 10:44 PM UTC
Excellent. My only improvement would be PE tool clamps, especially on the hood where they are so prominent.
Stojkovic1987
KitMaker: 255 posts
Armorama: 254 posts
Posted: Thursday, June 08, 2017 - 11:37 AM UTC
Thanks for Your comments.
The hood gave me some troubles. I noticed that it is not even after painting so I decided to not remove it as it would cause extra damage.
as for the spare tire, I know about storage bracket under the platform but decided to make it some more interesting showing it just on the top of the platform in this sheltered section. Also there is a wooden bench in closed position (see previous posts with foto during my build).
