Armor/AFV: Modern Armor
Modern armor in general.
Building a Scud on Tracks
OldWarloke
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Friday, September 22, 2017 - 09:25 PM UTC
Primed and installed.
A little touch up paint, the Decals and this part will be finished.
Donald
OldWarloke
Posted: Sunday, September 24, 2017 - 05:10 PM UTC
I'll be working on the Missile and its Launcher next.
Donald
pgb3476
KitMaker: 977 posts
Armorama: 976 posts
Posted: Sunday, September 24, 2017 - 06:22 PM UTC
Looking great and those light guards came out looking very nice. Question, are there wipers for those big front windows? I assume you going to add them at the last minute to prevent breakage.
OldWarloke
Posted: Monday, September 25, 2017 - 09:13 PM UTC
I just added them, I almost forgot them (Thanks for reminding me)
Donald
OldWarloke
Posted: Monday, September 25, 2017 - 09:15 PM UTC
I started the frame for the Missile .
There's a lot of clean up on these parts.
The instructions are slightly vague on exactly where the parts go.
OldWarloke
Posted: Monday, September 25, 2017 - 09:21 PM UTC
Part # K9 will fit either way, be shure to have the side with the 4 D shape indents facing toward the end
OldWarloke
Posted: Wednesday, September 27, 2017 - 08:26 PM UTC
Some more assembled.
Both sides of the hold down clamps have to be assembled on the frame, they are movable so be careful with the glue.
In the closed position
OldWarloke
Posted: Wednesday, September 27, 2017 - 08:30 PM UTC
The front Guard / Ladder installed.
Finished for now.
Donald
27-1025
KitMaker: 1,281 posts
Armorama: 1,222 posts
Posted: Wednesday, September 27, 2017 - 11:55 PM UTC
The guard and ladder assembly look very good. Nice work so far.
OldWarloke
Posted: Thursday, September 28, 2017 - 10:32 PM UTC
Now the base of the Missile support .
I'll glue them together after painting them.
Finished for now.
Donald
OldWarloke
Posted: Monday, October 02, 2017 - 06:34 PM UTC
I have the Missile assembled and puttied I had to cut off the pins as there was too big a step between the halves .
Be shure to install the engine exhaust nozel when joining the halves together.
The detailing is a combination of raised and engraved panel lines.
The metal pins from the base don't line up too good with the holes in the traling edge of the missle fins.
That's why I glued the missile to the base.
Of course I could have screwed up on installing the fins.
OldWarloke
Posted: Monday, October 02, 2017 - 06:43 PM UTC
Now to paint it all.
Regards.
Donald
OldWarloke
Posted: Wednesday, October 04, 2017 - 10:38 PM UTC
The Missile & the Erector is painted & decaled .
Finished for now.
Donald
Hederstierna
#247
Nordjylland, Denmark
KitMaker: 1,102 posts
Armorama: 1,018 posts
Posted: Wednesday, October 04, 2017 - 10:42 PM UTC
It's really coming along nicely. Looking foreward to see the SCUD mounted on the vehicle.
Jacob
OldWarloke
Posted: Wednesday, October 04, 2017 - 10:43 PM UTC
Jacob
That's next.
Donald
alchemymike
KitMaker: 208 posts
Armorama: 192 posts
Posted: Wednesday, October 04, 2017 - 11:04 PM UTC
So glad to see some post war missiles... your build info is great! Have this kit and their Ganef and want to get on these... this forum will help.
I am building the Takom V-2 and Meiller Wagon... this is a great build by the way
Mike
OldWarloke
Posted: Sunday, October 08, 2017 - 01:21 AM UTC
I have some more done.
The hinge pin is inserted from the inside like so.
It should look like this.
Here it is test fitted to the Hull.
OldWarloke
Posted: Sunday, October 08, 2017 - 01:28 AM UTC
The two parts that attach the upper parts of the raising pistons don't fit together.
Here is how I fixed them, simply carve off part of the receptor for the pin until it fits.
It should look like so.
I'm using the ones to have the Missile in the lowered position, The kit gives you the parts to place it in the raised position, but then you need all the Hoses and other plumbing that attach to the end of the Missile.
I'm finished for now.
Donald
babaoriley
KitMaker: 195 posts
Armorama: 179 posts
Posted: Sunday, October 08, 2017 - 02:11 AM UTC
Here's the one from Jacques Littlefield's collection. Apparently he had some trouble getting it into the country and eventually had to use his connections to point out to Customs that the missile was entirely empty, inert and non-functional. It seems that having hundreds of millions of dollars makes a lot of things possible, or at least easier, LOL.
" BORDER="0">
OldWarloke
Posted: Monday, October 09, 2017 - 01:23 AM UTC
Here is how I installed the Missile Cradel to the Hull.
First glue the lower hydralic parts to the hull like so.
Next install the upper parts to the Cradle like so.
OldWarloke
Posted: Monday, October 09, 2017 - 01:28 AM UTC
Line up the front lock downs on the Cradle with the mounts as shown.
Insert the upper lift parts into the lower ones as shown.
Glue the rear Hinge mounts to the Hull as shown.
OldWarloke
Posted: Monday, October 09, 2017 - 01:33 AM UTC
The Missile can be positioned in the launch position with the Cradle lowered.
I'm not using this position as there aren't any Fueling hoses or other detail that should connect the end of the Missile to the Vehicle.
More to come later.
Donald
Thirian24
Oklahoma, United States
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Monday, October 09, 2017 - 04:10 AM UTC
Looking good. How big is the overall kit with the missile laid down?
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 921 posts
Armorama: 919 posts
Posted: Monday, October 09, 2017 - 12:45 PM UTC
Very impressive model. Sharing your experience with the build is much appreciated.
OldWarloke
Posted: Friday, October 13, 2017 - 06:24 PM UTC
Measuring end to end it's 14 3/8" or 365mm Long
