Hosted by Richard S.
Dragon Campaign 2018
d6mst0
#453
KitMaker: 1,925 posts
Armorama: 601 posts
Posted: Monday, May 07, 2018 - 04:27 PM UTC
Richard,
I have to ask...how did you hollow out those guide horns and how long did it take. You work looks spot on, so I would like to give it a try.
Mark
d6mst0
#453
Armorama: 601 posts
Posted: Monday, May 07, 2018 - 04:28 PM UTC
Darius,
Nice progress.
Mark
McRunty
#491
Missouri, United States
KitMaker: 602 posts
Armorama: 191 posts
Posted: Tuesday, May 08, 2018 - 03:34 AM UTC
My entry will be a 1/35 Sherman Firefly VC done almost 100% OOB though I have opted to use aftermarket AFV Club Tracks.
LikesTanks
Wales, United Kingdom
KitMaker: 242 posts
Armorama: 234 posts
Posted: Tuesday, May 08, 2018 - 04:07 AM UTC
Richard,
Mark
Tool of choice was a 0.9mm drill bit and the tracks took 4 evenings at a couple of hours each time. It was very tedious, but I'm in no hurry with this. I drilled them out on the sprue and then cleaned up with my trusty Stanley knife.
slayer
KitMaker: 96 posts
Armorama: 95 posts
Posted: Wednesday, May 09, 2018 - 06:00 AM UTC
Heres a test shot of my Dragon M1A1 AIM. Hope it works.
https://www.flickr.com/gp/141843761@N08/evT112
Charlie-66
#186
KitMaker: 771 posts
Armorama: 750 posts
Posted: Sunday, May 13, 2018 - 02:24 AM UTC
Calling this one done. decided to do something different and take the final pictures with a 4 man Infantry set I finished recently. I plan to fill the hatches with crew figures at a later date.
Bluestab
South Carolina, United States
KitMaker: 2,160 posts
Armorama: 1,906 posts
Posted: Sunday, May 13, 2018 - 09:15 AM UTC
Update on the Sd.Kfz 250.
Assembly is mostly done. The figure is added for size comparison.
dragon-sdkfz250_12
dragon-sdkfz250_13
For the paint, I went with base dark yellow. The kit comes with PE doors for the stowage boxes. They are okay, but the thickness doesn't help give the recessed handles any depth. And if you pose them open you will still have to scratch up the inner latchworks.
dragon-sdkfz250_14
I added the second color...olive green...using a stiff brush. Drybrushed and a light wash.
The kit's markings are both for vehicles from SS Wiking in Hungary. I plan on using this for something else so I used vehicle numbers for an Army vehicle that I found in the decals spares box.
dragon-sdkfz250_15
dragon-sdkfz250_16
dragon-sdkfz250_17
dragon-sdkfz250_18
dragon-sdkfz250_19
dragon-sdkfz250_20
And I'm calling this one done. It wasn't a bad build. It wasn't a great build. Fit was tricky and were cumulative due to the many hull sections. Other problems can be overcome fairly easily. The tracks aren't as bad as you would think. The detail is pretty good and there's room for more additions. That said, I'm glad to be done with it.
I plan on using my SdKfz250 as part of another project. I'll probably add some more gear and figures for that.
McRunty
#491
KitMaker: 602 posts
Armorama: 191 posts
Posted: Sunday, May 13, 2018 - 08:31 PM UTC
The Firefly is built. I had originally wanted to do this OOB except for the tracks but after looking at the 17lb'er barrel I opted to get an aftermarket one.
Kit was fairly straight forward to build. Had some issues with the photo etch since it was done in steel and was very hard to bent and keep in shape but I got there in the end.
Did some minor modifications. I added a weld seem to the cheek armour, the machine gun plug and to the box added to the back of the turret. I also scratch built a rack on the front of the tank for stowage.
I will be doing this in the markings and colours of the South African 6th Armoured Division which was operating in Italy.
Suspension has been built but isn't shown in the picture. I will be adding after painting.
k_mero4
Sofiya, Bulgaria
KitMaker: 393 posts
Armorama: 369 posts
Posted: Monday, May 14, 2018 - 12:43 AM UTC
Alex, the model is great. Strange camouflage. How did he achieve it? It's interesting.
Rory, a very good job. The model looks impressive.
d6mst0
#453
Armorama: 601 posts
Posted: Sunday, May 20, 2018 - 06:25 AM UTC
Finished with my entry for this group, Dragon kit #6854; IJA Type 4 Light Tank "KE-NU".
I decided to make this one look brand new right out of the paint shop with no weathering. This tank wasn't produce until very late 1944 - early 1945 and most of them were kept in the home islands in preparation of the expect invasion by the allies.
So I doubt if this vehicle got much use with the shortage of fuel that was being felt within the empire.
This one was a fun build, no fit issues and even the DS tracks were long enough to get the proper sag in them while the vehicle was stopped.
Off to the next group build.
Mark
McRunty
#491
KitMaker: 602 posts
Armorama: 191 posts
Posted: Sunday, May 20, 2018 - 08:19 PM UTC
Mark
Looks great! Lovely work on the painting.
d6mst0
#453
Armorama: 601 posts
Posted: Sunday, May 20, 2018 - 11:47 PM UTC
Rory,
Thank you.
Mark
LikesTanks
KitMaker: 242 posts
Armorama: 234 posts
Posted: Wednesday, May 23, 2018 - 02:34 AM UTC
The building is done
Now to painting
JMartine
KitMaker: 1,698 posts
Armorama: 45 posts
Posted: Thursday, May 24, 2018 - 06:58 PM UTC
Here is my entry for this Campaign: 1:700 USS Spruance DD-963, Dragon # 7084. Have not built anything in awhile, so this one will be OOB, skipping PE for this one.
Charlie-66
#186
KitMaker: 771 posts
Armorama: 750 posts
Posted: Saturday, May 26, 2018 - 09:56 PM UTC
mark,
That IJA Type 4 looks great. Nicely done!
Kaktusas
Vilnius, Lithuania
KitMaker: 196 posts
Armorama: 196 posts
Posted: Sunday, May 27, 2018 - 11:43 AM UTC
Basecoat + camo on.
I have added engine cover panels, and driver gear shift lever. I have also decided to put some camo on fighting platform, as it stands out too much otherwise.
Soojet
Ohio, United States
KitMaker: 22 posts
Armorama: 20 posts
Posted: Monday, June 11, 2018 - 06:20 AM UTC
I've learned my lesson when it comes to over complicating a build, my OT-34 with PE and resin proved to be too much for me. So alas I had to shelve it for a while.
I'd like to enter a new model instead, Dragon 6048 M4A1 75mm Early Version. This is much simpler and nerve racking. I'm sorry for the inconvenience mods of this campaign.
d6mst0
#453
Armorama: 601 posts
Posted: Monday, June 11, 2018 - 07:02 AM UTC
Matt,
It happens to us all. Nice choice for a back up.
Mark
Chaman911
KitMaker: 319 posts
Armorama: 308 posts
Posted: Sunday, June 17, 2018 - 03:19 AM UTC
Hi everyone. I'm in with Dragon's Stug III G initial production. This will be the second Dragon kit I have ever build (the first is built but not painted yet). Really looking forward to the build and campaign.
Bryan
Kaktusas
Vilnius, Lithuania
KitMaker: 196 posts
Armorama: 196 posts
Posted: Sunday, June 17, 2018 - 08:06 PM UTC
Some progress on mine: filters + pin wash + dunkelgelb chipping + general chipping + flat coat. Now its time for some dirt and grime on fighting platform.
Soojet
Ohio, United States
KitMaker: 22 posts
Armorama: 20 posts
Posted: Wednesday, June 27, 2018 - 02:07 PM UTC
Some work in progress pics, clear coat and decals are applied. The colors used are Tamiya Olive Drab and a mix of Tamiya Desert Yellow and Buff. This is a super enjoyable and easy kit, that is, for a Dragon kit.
Soojet
Ohio, United States
KitMaker: 22 posts
Armorama: 20 posts
Posted: Friday, July 06, 2018 - 02:48 AM UTC
I've finished my M4A1 75mm (kit 6048), it is an easy build with not problems, including the DS tracks. I wanted to do a light weathering to save time, since this will be presented at my local IPMS meeting this month. Comments and critiques are welcome, this isn't my best work, but I believe it is good enough. Thanks for looking.
oldbean
KitMaker: 769 posts
Armorama: 461 posts
Posted: Monday, July 09, 2018 - 03:16 AM UTC
Just joined this campaign. I've been hanging on to Dragons Elefant and I have the Cavalier zimmerite and Friul's.
Jesse
McRunty
#491
KitMaker: 602 posts
Armorama: 191 posts
Posted: Tuesday, July 10, 2018 - 02:38 PM UTC
Haven't updated since May. Here is my progress since then.
Base coat, decals, clear coat and pin wash are down. There is a small amount of silvering on the decals which I havent been able to get rid of. I am hoping another coat of clear will help.
Decals are from Star Decals and is for a vehicle of the South African 6th Armoured Division in Italy 1945.
Still have weathering, stowage and the TC to do.
johhar
Alabama, United States
KitMaker: 476 posts
Armorama: 447 posts
Posted: Monday, July 16, 2018 - 07:57 AM UTC
I just can't seem to get this camo for the uniforms, so I'm thinking of just finishing the vehicle. Vision is part of the issue, as is the crazy irregular pattern. This is where I'm at with my latest attempt. Way off in proportion of colors, etc.
