Figures
US Navy SEAL "Duck feet" Vietnam, 1/35
Klaus-Adler
MODELGEEK
Scotland, United Kingdom
KitMaker: 1,505 posts
Armorama: 840 posts
Posted: Saturday, July 20, 2019 - 09:41 AM UTC
fabulous work on the ERDL camo mate, it looks amazing.
Vicious
KitMaker: 1,517 posts
Armorama: 1,109 posts
Posted: Saturday, July 20, 2019 - 10:03 AM UTC
WoW...awesome Job Mate!...
maybe enlarge the parts in black to make them stand out a little more but still so beautiful!!....
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Sunday, July 21, 2019 - 05:11 AM UTC
Thanks!
I have some finishing sanding on the sides of the base and will continue with the terrain
Cheers!
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Sunday, July 21, 2019 - 11:28 PM UTC
I made several thin washes with acrylic paints to break the uniformity of the base color and then drybrushing the pigment for variety. Rocks are painted with different colors also. I used thinned oil paint for the slime on the river bed.
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Tuesday, July 23, 2019 - 01:23 AM UTC
I sprinckled some tea for scatter and adding tufts of static grass:
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Wednesday, July 24, 2019 - 05:58 AM UTC
Proceeding with more vegetation, I sprayed the grass with Vallejo Olive green for more fresh look. Other plants are from JS Work.
There will be water lilies and bulrush, but after pouring the resin
Cheers!
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Friday, July 26, 2019 - 07:54 PM UTC
I decided to glue the dam with superglue, just in case, and applied lquid mask at the edges.
First checking with water for any leaks and to measure the needed resin.
Th resin dried nicely, but...bubbles. It appeared that, because of the hot weather, the resin started to dry very fast and the bubbles had not have enough time to get to the surface and disappear. But it is looking very nice that way
Final putty and sanding is needed on the sides of the base, and I will continue with the water ripples and other vegetation:
Cheers!
Tank1812
KitMaker: 1,112 posts
Armorama: 886 posts
Posted: Saturday, July 27, 2019 - 03:32 AM UTC
I had envisioned not as much water and figure standing in the water. Double curious to see how it turns out now. You doing a video for this as well?
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Saturday, July 27, 2019 - 03:45 AM UTC
Water is not as much as it seems-only about 2cm at the deepest.
I was considering putting the figure in the water, but I was afraid not to ruin something
Yes, there will be video later
Cheers!
justsendit
KitMaker: 3,033 posts
Armorama: 2,492 posts
Posted: Saturday, July 27, 2019 - 06:16 AM UTC
I like how the sand at waters' edge is moist. Looking really good!🍺
...I was considering putting the figure in the water, but I was afraid not to ruin something
Can be awesome when it works, but I've heard nightmare stories about models being submersed in water effects with disastrous results. I'm convinced you'll make this guy look badass no matter where he stands.
—mike
deerstalker36
KitMaker: 232 posts
Armorama: 218 posts
Posted: Saturday, July 27, 2019 - 12:22 PM UTC
your work looks awesome Venelin, both the figure and groundwork are very impressive
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Saturday, July 27, 2019 - 05:28 PM UTC
Thanks, guys!
Can be awesome when it works, but I've heard nightmare stories about models being submersed into water effects with disastrous results. I'm convinced you'll make this guy look badass no matter where he stands.
—mike
Mike, the moisture is because the resin creeps along the edges, it even got between some of the grass. It's nice effect though
Problem will occur, if the resin reacts with the material of the figure. And when it's curing the resin produces heat, I don't know if this is dangerous for the figure.
If someone tried putting resin figure in epoxy resin water, please share the experience.
Venelin
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 1,432 posts
Armorama: 1,390 posts
Posted: Sunday, July 28, 2019 - 06:04 AM UTC
Another fine piece of Art,Venko!
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Sunday, July 28, 2019 - 06:16 AM UTC
Благодаря!
Thanks!
strongarden
KitMaker: 730 posts
Armorama: 624 posts
Posted: Sunday, August 11, 2019 - 02:16 AM UTC
Looks great Venko, all the planning and preparation has paid off!
Dave
Venko555
Bulgaria
KitMaker: 908 posts
Armorama: 698 posts
Posted: Tuesday, August 13, 2019 - 01:49 AM UTC
Thanks, Dave!
But I decided to make second attempt with this one
This time the SEAL will be in the water and I put the bulrush first, before pouring the water.
I think it will be more interesting that way and that was my first idea, but I was afraid not to damage the figure, because the resin produced much heat during cure.
But I tested a new resin from local brand, much cheaper than Pebeo and doesn't produce heat
Cheers!
marcb
Overijssel, Netherlands
KitMaker: 1,244 posts
Armorama: 1,226 posts
Posted: Wednesday, August 14, 2019 - 08:29 AM UTC
That looks really good. You could add some fishes.
Mantis miniatures makes two different sets:
https://www.mantisminiatures.pl/PL/22,0,Zwierzeta.html
