Modeling Questions?
enamell paint
bat-213
Canada
KitMaker: 869 posts
Armorama: 757 posts
Posted: Wednesday, November 08, 2017 - 06:06 AM UTC
hi guys ,I am wanting to use model master enamel paint over a water base paint ,my q is can I do that? all ideas are wellcom thanks .
Vicious
KitMaker: 1,217 posts
Armorama: 900 posts
Posted: Wednesday, November 08, 2017 - 06:27 AM UTC
never try the MM but i use the Humbrol enamel,never have any problem between acrylics and enamel if they are completely cured
The problem is not the paint but what thinner you use,i go with turps,white spirit or Humbrol thinner,but thinner and names change between cuontry...test on some scrap piece before
RobinNilsson
Staff MemberTOS Moderator
KITMAKER NETWORK
Stockholm, Sweden
KitMaker: 3,858 posts
Armorama: 3,319 posts
Posted: Wednesday, November 08, 2017 - 03:31 PM UTC
Note that some paints which seem to be water based are not.
The water is simply used as to dilute the paint but the paint, or actually the "glue" that makes the pigment stick to the surface and form a durable layer, is solvent based.
These solvents for "water" based paints are usually not sensitive to the thinners/solvents used for enamels.
The advice by Vicious above is very good.
Don't trust what you read or hear, test with Your paints and Your solvents.
/ Robin
bat-213
Canada
KitMaker: 869 posts
Armorama: 757 posts
Posted: Thursday, November 09, 2017 - 03:24 AM UTC
thanks guys for your input , I think I will do just that .
