Dioramas
Survival in the Vidda
Jberardi
Georgia, United States
KitMaker: 95 posts
Armorama: 88 posts
Posted: Sunday, January 20, 2019 - 02:31 PM UTC
Some update photos to share after a bit of a hiatus...
Fleshing out the interior with some initial placements. Table and one of the chairs is painted. Added a homemade map and a wireless radio. Airborne container is in the background.
I wired a small orange led light that will feed into the wood burning stove. The test fit threw off a nice warm glow in the cabin.
First two figures primed and ready for some paint. A wireless operator and the other guy will be testing the heat of the stove. Both are largely scratch built with the exception of heads, hands and a couple of accessories.
A question for the group. I'm thinking of lopping off the main roof beam where the X's indicate that way the roof will cover roughly up to the fireplace. I'm thinking this will provide a less obstructed view into the cabin from above and behind. Question is will this look wonky with a half roof? Thoughts?
Enjoy,
JB
RobinNilsson
Staff MemberTOS Moderator
KITMAKER NETWORK
Stockholm, Sweden
KitMaker: 6,693 posts
Armorama: 5,562 posts
Posted: Sunday, January 20, 2019 - 09:34 PM UTC
Any type of opening in the roof will look as if the opening is there only to allow the viewer to have a look inside
If I were you, which I am obviously not, I would cut the roof at an angle. Maybe from where the main beam meets the wall (keep all of the x-ed out part). It is already too short so don't remove any more of it. The other corners of the triangle would be the corner of the cabin and two thirds to three quarters along the long side of the cabin, past the red beam you have drawn in.
An option is to keep all the roof beams and just leave out the covering on parts of the roof.
There should also be more roof beams to support the roof, snow can get really heavy ....
I would say three, maybe even four, on each side.
On the chimney side the beams should be close too, but not touching, the chimney.
With a smaller opening, or maybe even make two openings, you make it more interesting for the viewer since she/he has to change their viewing direction to be able to see everything
/ Robin
dioman13
Indiana, United States
KitMaker: 2,184 posts
Armorama: 1,468 posts
Posted: Monday, January 21, 2019 - 04:15 AM UTC
Hi Jim. Very good dio you have going on. I like every thing you have accomplished. As to the roof, personaly I would have the roof structure as is and only put the actual roofing material on up to the point where you wanted to cut off. The end result being a cut away like on AFV's or planes. Once done if you don't care for the results you can remove it as you were thinking. The exposed part would act as a continuation of the roof but without the obstruction of the view. Hope this helps you with your question. Keep up on your good work and I will follow your build. Bob d.
dioman13
Posted: Monday, January 21, 2019 - 04:31 PM UTC
Hey Jim, a thought that crossed my idea pattern. If you have a hobby loby or the likes, check out the flikering votive candles that work on watch batteries. They might work for your stove or fire place. If size permits a fit of 2 bulbs you could use tamiya clear red and yellow to get that colored flame effect.
Dioramartin
New South Wales, Australia
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Monday, January 21, 2019 - 10:00 PM UTC
Very nice interior JB – I’d be inclined to keep the long beam and support it at the open end with a final pair of cross-beams for the sake of rigidity. Then, either construct a removable section of roofing as Robert suggests or cut in a piece of clear glass or Perspex of whatever dimensions necessary to allow enough light inside. You could still keep the cross-beams in place under the glass. It depends on your view of “realism” but I’d think most viewers would be too interested in the now-visible interior to notice they’re looking through an unrealistic skylight
strongarden
KitMaker: 730 posts
Armorama: 624 posts
Posted: Sunday, January 27, 2019 - 02:54 PM UTC
Jim this is great progress, but first let me say thanks for staying the course! You're very skilled my friend.
Have you attempted wintry scenes before, or any experience with laying down snow?
Really look frwd to the next installment!
Regards
Dave
Bodeen
#026
KitMaker: 1,744 posts
Armorama: 1,359 posts
Posted: Sunday, January 27, 2019 - 04:24 PM UTC
I like this diorama subject very much. The cabin and furnishings are very well done. Thanks for sharing.
Jberardi
KitMaker: 95 posts
Armorama: 88 posts
Posted: Monday, January 28, 2019 - 04:50 AM UTC
Robin, Bob & Tim:
Thanks for the ideas regarding the cabin roof. After some consideration I'm inclined to keep the ridge beam at the full length. I'll roof up to the fireplace and show exposed rafters from that point back. That should give the viewer an open view while still inferring a full roof.
Dave & Jeff:
Thanks for the kind words of encouragement. This will be my first attempt at winter, so any tips would be greatly appreciated. After some research, my plan is to lay down a base (probably Celluclay) to form the general topography. Woodland Scenic snow on top of the base. Lastly some flex paste to form up drifts and irregularities followed by more snow. This won't be a dusting, but a full-on snowstorm. Of course, I'll test all this out on a spare base so I don't screw it up in the end.
For the roof, my plan is to create the shape of standing snow with balsa foam, paint it white then apply some snow for the texture.
Thoughts on these approaches?
Jim
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Monday, January 28, 2019 - 05:08 AM UTC
Hi Jim,
Remember to avoid using straight lines for the cutout in the roof
No real opinion on how to make snow.
When snow has packed itself together for a few weeks with temperatures going up and down it isn't fluffy anymore.
If you cut it with a showel you get smooth and almost solid surfaces.
My first try would be to cast a slab of white plaster and then saw out the shape of the hole with a coping saw or fretsaw.
I have zero experience of the balsa foam but if it has a fine grained porous structure it should work.
/ Robin
cheyenne
KitMaker: 2,185 posts
Armorama: 1,813 posts
Posted: Tuesday, January 29, 2019 - 02:33 AM UTC
JB , love the interior especially the fireplace .
My two cents , Id say if you were entering this in a show , yeah do some sort of cutaway . If not make a full [ removable ] roof . You can take all the pictures you want of the interior to show but when you put the roof back on you'll have a complete visual of the rest of the dio .
Like I said just my thoughts , and I've never done snow so no help there but your foam idea sounds good , I'd like to see how you make out .
dioman13
Posted: Tuesday, January 29, 2019 - 04:34 AM UTC
Woodland snow works great. Has that sparkle when the sun hits it. If you want some icicles you can use some artist medium gel. Dries clear and you can drag it dowm and build it up in layers.
Jberardi
KitMaker: 95 posts
Armorama: 88 posts
Posted: Sunday, February 03, 2019 - 02:20 PM UTC
Not much progress in the last week, but did have time to paint the wireless operator. I'm happy with the result, but could always improve on the blemishes.
JB
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Monday, February 04, 2019 - 02:22 AM UTC
Great progress!
J
SRAMSEY
South Carolina, United States
KitMaker: 28 posts
Armorama: 27 posts
Posted: Monday, February 04, 2019 - 04:23 AM UTC
Jim
Glad I found this build. I myself have a weakness for winter dioramas, so I will be following for sure. Everything is great. The details in the house is amazing, as is everything else.
I was trying to get motivated last year to build a winter diorama for this years AMPS convention, but it did not happen. I am hoping to go, but time will tell.
Shawn
strongarden
KitMaker: 730 posts
Armorama: 624 posts
Posted: Saturday, February 09, 2019 - 05:54 AM UTC
The radio operator came out perfect Jim, nice job! Everything is looking good.
Thanks for the snow tips,this approach sounds good to me. Haven't attempted a winter scene yet but def on my bucket list of dios.
Shawn, I was hoping to visit this year's show too but won't be going. It's in Buffalo in May and just too soon for me.
Regards
Dave
Jberardi
KitMaker: 95 posts
Armorama: 88 posts
Posted: Sunday, March 17, 2019 - 02:47 PM UTC
A couple more progress photos from over the weekend.
Radio operator mocked up...
...and in context
The interior is now complete (and warm).
Started working on the rafters and roofing. After some back and forth, I decided to just roof the whole damn thing so the snow pack doesn't look wonky with a hole in the roof. The majority of the interior will still be in view at eye level.
Enjoy and as always, comments welcome.
JB
callmehobbes
KitMaker: 751 posts
Armorama: 740 posts
Posted: Tuesday, March 19, 2019 - 05:05 AM UTC
It 'feels' right so far. I think the key to this will be making the room feel warm in a very cold environment. Maybe wet boot/clothes drying by the fire. Keep updating. I want to see how this turns out.
jrutman
Posted: Wednesday, March 20, 2019 - 01:31 AM UTC
Nice progress all around. The radio and operator are looking good. I wonder if there would be a piat there? are they expecting a tank attack up there?
J
Jberardi
KitMaker: 95 posts
Armorama: 88 posts
Posted: Wednesday, March 20, 2019 - 05:54 AM UTC
J
I had read that there were armored vehicles patrolling the Vemork plant; however, the PIAT didn't come into service until 1943. I have a bit of a continuity problem so I'll probably sub the PIAT out for something else. Nothing gets by you Jerry.
JB
timcc2008
KitMaker: 139 posts
Armorama: 135 posts
Posted: Wednesday, March 20, 2019 - 05:58 AM UTC
Very nicely done! I believe you made the right choice in closing up the whole roof. Looking forward to future installments.
vr
Tim
Jberardi
KitMaker: 95 posts
Armorama: 88 posts
Posted: Sunday, April 07, 2019 - 09:44 AM UTC
Roof is closed in.
I did a mock-up of the snow on the roof. I started with balsa foam, carved some layers and rounded the edges. Primed, shaded and painted. Finished up with some Woodland Scenics Snow to provide for a fresh dusting effect. I think for the real thing I'll go with fewer "layers" and probably undercut it more. Since the snow on the roof is a prominent part of the overall piece, I'd love some feedback and thoughts.
Jim
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Sunday, April 07, 2019 - 10:14 AM UTC
I think you should cover the roof with tar-black paper or at least narrow strips hanging over the edges (something like 5-10 mm in 1:1 scale). Otherwise that roof will be leaking water like crazy.
The probable roof covering would probably be tarred boards covered with soil and vegetation. Another type was shingles made from small wooden boards and heavily covered in tar.
Overlapping tarred boards running top-to-bottom (not side-to-side) could also be possible.
The more expensive types like slate shingles, roof tiles et.c, are not likely for a building like this.
You could try to replicate what the edges of this roof would look like:
The snow looks really good, compare with these roofs:
When it starts sliding off like this the snow will be less deep at the top of the roof since the build up is reduced by the bottom layers having moved down the slope. This is tricky to replicate so choose another type.
Note that wind can also cause the coverage to be thicker on the lee side of the roof. I don't know if that area of Norway has a predominant wind direction. It can also depend on local geography ...
Sometimes it looks strange:
I think they need to think about the insulation beneath that roof, leaks too much heat ....
Jberardi
KitMaker: 95 posts
Armorama: 88 posts
Posted: Thursday, November 07, 2019 - 04:07 PM UTC
Clearing my plate and beginning to contemplate a new project, and I realized I never posted final photos of this labor of love. Hope you enjoy.
JB
MakiWawa
Warszawa, Poland
KitMaker: 448 posts
Armorama: 448 posts
Posted: Thursday, November 07, 2019 - 10:43 PM UTC
is it possible for one man to pull a reindeer on a sleigh?
cheyenne
Posted: Friday, November 08, 2019 - 01:42 AM UTC
Might even be easier in snow ....
