Armor/AFV: Modern Armor
Modern armor in general.
GAZ-66 Radio Van - Question
165thspc
#521
Kentucky, United States
KitMaker: 9,465 posts
Armorama: 8,695 posts
Posted: Thursday, October 11, 2018 - 07:15 AM UTC
I wish I had known I had other options for upholstery colors before I painted my cab interior.
165thspc
#521
Posted: Thursday, October 11, 2018 - 07:33 AM UTC
Interesting found photo;
This must be the mother of all communication set ups for the GAZ:
165thspc
#521
Posted: Thursday, October 11, 2018 - 09:12 AM UTC
Looking now for additional roof details I might add.
There appears to be some sort of roof mounted storage box on this truck. What those triangular support plates at the driver's side rear might be I cannot imagine.
In the photo above the truck has a number of tie down points for the guy wires supporting the various satellite antennae.
165thspc
#521
Posted: Friday, October 12, 2018 - 08:01 PM UTC
Request For Further Information:
Interestingly enough, out of the blue, fate has dropped yet another Trumpeter GAZ-66 model into my lap. I was going to resist the tempation but it seems fate had decreed that I will be building the experimental (concept version) of the GAZ 6x6 truck identified as the GAZ-34.
Any further reference info on this rather rare vehicle would be appreciated.
Until just this past evening I had only ever seen this vehicle in toy form.
Frenchy
Rhone, France
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Friday, October 12, 2018 - 08:10 PM UTC
https://www.youtube.com/watch?v=wbq7rnoN3os
Don't know if this diecast is accurate....
Full size
A few bits of info here (looks like only 5 were eventually built...) :
http://www.ussrtoscale.com/----34.html
https://es.fehrplay.com/avtomobili/2492-istoriya-sozdaniya-avtomobilya-gaz-34.html
Here's a 1/35th scale scratchbuilt one :
from http://karopka.ru/community/user/20126/?p=1&MODEL=451964#cmtlist
H.P.
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 1,432 posts
Armorama: 1,390 posts
Posted: Friday, October 12, 2018 - 08:59 PM UTC
Mike,
Take a look here:
http://panzer35.ru/forum/46-15972-1
I'll see what else I can dig
165thspc
#521
Posted: Friday, October 12, 2018 - 09:21 PM UTC
Many thanks guys, Frenchy I was specifically looking for under body views and that photo of the metal model confirmed that the 34 Would have rear suspension similar to the US Deuce and a Half. (Easy parts availability there.)
But as to the drive line; that threw me a real curve indicating that the rear drive shaft went through a frame mounted pillow bearing on its way to the back axle.
Then Angel added the link to the other model and things became more clear. Those photos indicate that the GAZ designers used what is known as an "up and over" arrangement where the rear driveshaft goes through a pillow bearing block actually mounted directly onto the #2 axle. Again much like the GM Deuce.
Some of the body work on the loadbox might be a little more challenging but with my spares box of Deuce and a Half parts the drive line I can handle.
Thanks All
ayovtshev
#490
Sofiya, Bulgaria
Posted: Friday, October 12, 2018 - 09:29 PM UTC
Mike,
GAZ-34 was sort of a hybrid:
PTO and power transmission to rear axles(fifth driveshaft) were taken from ZIL-157.
Main and auxiliary gearboxes plus driveshafts came from ZIL-131
Rear axles with differentials and engine were from GAZ-66
HTH
165thspc
#521
Boy, zoom in close on the guy's modeling of their brake lines and the differentials have all the proper construction welds.
Holy Smokes!
165thspc
#521
Posted: Friday, October 12, 2018 - 09:40 PM UTC
Mike,
HTH
Big truck builder's are more like "system integrators" than builder's. They probably manufacture the frame but everything else comes from anywhere they can find the usable parts.
In the US it might be:
Engine - Catapillar
Tranny - Allison
Axles - Rockwell
Brakes - Bendix
Etc. Etc.
165thspc
#521
Posted: Friday, October 12, 2018 - 09:49 PM UTC
Bye the way Angel I am guessing the GAZ has air over oil actuated brakes???
There is a air pump on the engine and we have these big air actuators spread all over the vehicle chassis. The early 66's only had one acuator but appearently something was lacking in braking power and in later production they went with two.
Wish I had that on my Toyota Tacoma!
165thspc
#521
Posted: Sunday, October 14, 2018 - 08:33 AM UTC
Looking for additional details (especially colorful ones) to add to the GAZ-66 communications van.
Can anyone shed light on what the object attached below the front bumper might be?
If I had to hazard a guess I would say it was a "hot stick". Electric utility workers use them to handle live electrical wires and breakers. It would consist of an insulated pole, handle on one end with an actuator and a hook or mechanical pincher on the other.
In this case it could be used to adjust "hot" antenna while not interrupting radio transmission. ??????
165thspc
#521
Posted: Monday, October 15, 2018 - 02:44 AM UTC
My buddy who had offered me the additional GAZ-66 kit did not come thru this past weekend, He said he had seen the kit somewhere but then went back and could not find it in his stash. (Yes his stash IS THAT BIG!)
We have another Cincinnati based IPMS show coming up this weekend so hopefully his search will fair better this week.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Monday, October 15, 2018 - 03:30 AM UTC
Mike,
I couldn't find nothing about the bar.
Except, that the radio truck is R-125...
I searched in tow bar direction, nothing...
But as I zoom in on the object in question, it seems to me that I see a tap and a pipe on its close end,while the far end looks like intended to be mounted on something...
What about it being a spray arm?
The black&white strips of paint will make it visible while in operation.
JimboHUN
Budapest, Hungary
KitMaker: 461 posts
Armorama: 443 posts
Posted: Monday, October 15, 2018 - 07:05 AM UTC
Hi,
I have not read all posts but maybe this helps:
http://mhrfweb.makett.org/MHRFWEB/?page_id=584&vt=1&wppa-album=296&wppa-cover=0&wppa-occur=1
Adam
165thspc
#521
Posted: Monday, October 15, 2018 - 02:46 PM UTC
Thanks Adam for the contribution of the additional photos.
One thing I noted on the radio van shown there: The large telescoping antenna and it's associated mounts on the front corner/passenger side of the shelter body are sure going to make it difficult if someone ends up needing to get to that spare tire!
165thspc
#521
Posted: Tuesday, October 16, 2018 - 06:06 AM UTC
Interior layout drawing of the R 142N cabin for anyone who might be interested:
ayovtshev
#490
Sofiya, Bulgaria
Posted: Tuesday, October 16, 2018 - 06:54 AM UTC
Thanks Mike!
I will make good use of these interior drawings some day!
165thspc
#521
Posted: Tuesday, October 16, 2018 - 06:59 AM UTC
Glad I could help.
The drawings make it look almost roomy -until you get all that radio gear in there!
165thspc
#521
Posted: Tuesday, October 16, 2018 - 07:17 AM UTC
I suspect this part you remember all too well.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Tuesday, October 16, 2018 - 07:57 AM UTC
Yes...2 people stationed there.
Not quite convenient to sleep in cold and wet spring nights
The Staff Room in the back was cosier...
Spent once 4 days and nights on position with our radio truck.
Our only luck was- we were ordered to deploy the Deymos in a potato field-so at least we had enough food...
165thspc
#521
Posted: Wednesday, October 17, 2018 - 01:30 AM UTC
Angel you had mentioned six people being assigned to the 142 so I figured 3 sleeping in the shelter, 2 in the truck cab and the last person walking guard duty!
ayovtshev
#490
Sofiya, Bulgaria
Posted: Wednesday, October 17, 2018 - 01:50 AM UTC
Yes Mike,
At least in the unit I served 23 years ago:
1 Truck Driver(Private or Ensign)
3 Radiomen(1 of them Phone Operator)-Private/Ensign/Junior Sergeant)
1 NCO(Sergeant)
1 Officer(Senior Lieutenant/Captain).
Still there were always at least 2 people on duty(1 Radioman and the NCO/Officer).
165thspc
#521
Posted: Thursday, October 18, 2018 - 11:51 AM UTC
Angel, not trying to put you on the spot or anything but I am looking for additional roof details to dress up the top of the radio box. Would you happen to know what these triangular panels are or what they store?
ayovtshev
#490
Sofiya, Bulgaria
Posted: Thursday, October 18, 2018 - 08:44 PM UTC
I have no idea,Mike...
The vehicle has Hungarian registration plate and the box is DF-3 type.
Our Deymos box was K66H and it didn't have this shape on the roof.
With regard to antenna on the roof:
The frames are zenith radiating antenna,for operation they were raised by hand and locked in place with supports(one is visible on the picture).They were used as radiating device for R-130 HF transmitter and could be used both on the move and while stationary.
The long anntenas situated on both front corners of the roof are whip antennas.They have different lengths-the right one is 4,0 m., the left one-3,4 m. long.Both antennas could be raised from within the box and could be coupled with each of the transmitters(R-130 HF,R-111 UHF and R-123 UHF) depending on the distance of communication.These antennas were also used both while stationary and on the move.
Rule of thumb was to use simultaneously as less antenna as possible, because of their interference.
Mostly I hated the telescopic ones, raised by hand
