Once More Unto the Breach
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 1,410 posts
Armorama: 1,369 posts
Posted: Wednesday, May 01, 2019 - 03:56 AM UTC
Progress update Pf.11 Pontonwagen
Load of Pf.11 ready:
From right to left: 4 Longitudinal beams, 1 Fixing beam, 1 Base beam, 1 Transition ramp(8t), 2 Halfbeams, Pf.11 with 2 Spike plates in the load bed, 18 Cover planks, 1 Anchor and 1 Connecting piece. Still missing are 2 sets of Anchor cables, will add them after painting.
Pf.11 with load:
Top view:
Next I'll finish the horse harness elements(6 horses were needed to pull the fully loaded Pf.11) and will prime/paint the trailer and its load.
Then I'll start working on the pontoon(it is a half-pontoon actually),
GulfWarrior
KitMaker: 1,034 posts
Armorama: 1,012 posts
Posted: Wednesday, May 01, 2019 - 05:41 AM UTC
That looks great, Angel!!
I need to hurry up and get my MAN 5 ton finished in the Logistics World campaign so I can work on this one. Probably the M9 ACE or the M1 ABV.
petbat
KitMaker: 3,254 posts
Armorama: 3,038 posts
Posted: Wednesday, May 01, 2019 - 07:07 AM UTC
Stunning work Angel
k_mero4
Sofiya, Bulgaria
KitMaker: 393 posts
Armorama: 369 posts
Posted: Wednesday, May 01, 2019 - 09:45 AM UTC
I do not know about you, but I have the pleasure of watching his progress closely. It 's great.
Angel, congratulations.
Kalin
BogiBg
Västra Götaland, Sweden
KitMaker: 397 posts
Armorama: 388 posts
Posted: Wednesday, May 01, 2019 - 11:02 AM UTC
Angel, you have incredible skills. Your work is simply fantastic.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Wednesday, May 01, 2019 - 06:33 PM UTC
Thanks gentlemen for your kind words!
Kalin, why don't you show here the Pf. 12 you are scratchbuilding?
GulfWarrior
Posted: Friday, May 03, 2019 - 12:22 AM UTC
Greetings Modelers!
I went ahead and extended our campaign until 31 DEC 2019. So, if you haven't done so yet, join up! There's plenty of time now! Even a slow-assed modeler like me can finish at least one kit before the end of the year!
Post! Post! Post! Let's see what you're working on!
k_mero4
Sofiya, Bulgaria
KitMaker: 393 posts
Armorama: 369 posts
Posted: Friday, May 03, 2019 - 04:30 AM UTC
Hello, Richard!
About a month ago I began building a Pionierfahrzeuge Pf.12 (Rampenwagen). Scratchbuild + Panzerart's resin tires. This is my progress in building it.
My question is, can I join the campaign?
Kalin
GulfWarrior
Posted: Friday, May 03, 2019 - 06:06 AM UTC
Well, it's a little farther along than I'd like; but sure, why not!
Welcome to the campaign!
ayovtshev
#490
Sofiya, Bulgaria
Posted: Saturday, May 04, 2019 - 04:45 AM UTC
Sprayed some paint on the Pf.11 I'm doing for this campaign:
Started construction of the halfpontoon:
Made a wrong calculation with pontoons width, but found the mistake early and now the pontoon is sitting on top of the Pf.11:
And a mock up of the most usefull picture for my build (Pf.11 in a road side ditch):
The original:
k_mero4
Sofiya, Bulgaria
KitMaker: 393 posts
Armorama: 369 posts
Posted: Saturday, May 04, 2019 - 11:33 PM UTC
The last picture is how the model will look finished.
I think he'll be cool.
Good luck.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Sunday, May 05, 2019 - 12:53 AM UTC
Thanks Batze, but...
The finished models will definetely not lay on their side in a road ditch
ayovtshev
#490
Sofiya, Bulgaria
Posted: Tuesday, May 07, 2019 - 07:11 AM UTC
Halfpontoon's construction finished:
Some ropes will be added once halfpontoon is painted,
GulfWarrior
Posted: Tuesday, May 07, 2019 - 07:35 AM UTC
Lookin' good, Angel!
ayovtshev
#490
Sofiya, Bulgaria
Posted: Wednesday, May 08, 2019 - 05:22 AM UTC
Thanks Richard!
petbat
Posted: Wednesday, May 08, 2019 - 12:22 PM UTC
The original roll on roll off trailer design....
Looking fantastic Angel.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Thursday, May 09, 2019 - 07:16 AM UTC
Thanks Peter!
I'm getting closer and closer to the finish line with my builds for this campaign.
Pontoon painted and partially weathered:
Had to do some changes to trailer load locations to assure the pontoon is sitting nice and neat:
Tried the combo:
48 cm. long...
I will need quite a big display box for it.
Still need to do some final weathering, so a bit more to come from me soon,
petbat
Posted: Thursday, May 09, 2019 - 10:17 PM UTC
You really have the wood down pat there. Simply fantastic Angel.
ayovtshev
#490
Sofiya, Bulgaria
Posted: Thursday, May 09, 2019 - 10:58 PM UTC
Thanks again Peter!
There's no better way of modelling wood, than using real wood:
Cheap wooden(birch) coffee stirrers.
Sprayed with the basecolour, left to dry, then sanded to show the grain.
Then thinned AK Wood Wash(highly recommended, BTW), some White Spirit here and there.
Then another sanding with fine grit paper and finally- 2 layers of diluted Tamya Flat Clear, applied by brush.
Plain and simple as that
SpeedyJ
Bangkok, Thailand / ไทย
KitMaker: 1,617 posts
Armorama: 1,150 posts
Posted: Thursday, May 09, 2019 - 11:52 PM UTC
Congrats on this Outstanding build Angel. Great detail on the load.
Kind regards,
Robert Jan
ayovtshev
#490
Sofiya, Bulgaria
Posted: Friday, May 10, 2019 - 01:40 AM UTC
Thanks Robert!
It was a fun build with a lot of Manual reading, guessing and combing for photographic proofs.
petbat
Posted: Friday, May 10, 2019 - 11:49 AM UTC
Okay, just to show I have not been idle (doing several kits at once....)
Dragon Sherman V (aka M4A4) and Legend Crab Flail conversion.
Firstly, an often overlooked requirement for this vehicle - the front 4 suspension bogies have been modified to lower the front of the tank. The weight of the Flail apparatus resulted in the front bogie almost bottoming out and the middle ones compressing noticeably as evident in photos of the real vehicle.
Legend mantelet with cover and periscope extensions added. Had to use the kit barrel as the Legend one had a huge slot hole from trapped air and correcting was not worth the hassle. Just cut the cover part off the Legend barrel section, dilled it out and fitted the Dragon one. Didn't see a need for a turned replacement. Also added some cast texture:
Added Meng bolt heads to the track skids although you can barely see them here. The kit instructions do not mention these (however I discovered that there are a string of bolt heads moulded in the sprues which I did not notice until later). All the white bits are styrene rod glued in the location holes for the kit tools. These will be trimmed flush and PE straps and tie downs added later. This pic of the other side proves all road wheels sit flat after the mods have been done!!
PS, before someone tells me the grouser box tops are on backwards, they were turned around on the flail to prevent dirt and debris accumulating in them!
Some of the Legend parts trimmed from the carrier blocks. A few air holes, which is to be expected, and yes I have to try and straighten quite a few bananas, or some scratch building will be needed. Note the slot hole in the barrel (second from the top) as per comment above.
Peter
GulfWarrior
Posted: Friday, May 10, 2019 - 01:44 PM UTC
lookin' good, Peter!
GulfWarrior
Posted: Sunday, May 19, 2019 - 01:41 PM UTC
OK. The Takom M9 ACE is under way!
ayovtshev
#490
Sofiya, Bulgaria
Posted: Wednesday, May 22, 2019 - 08:28 PM UTC
Short update from my side:
-A thread about German Assault Bridges made me realize I did a stupid mistake in my Campaign build: while building the Uebergangsschiene(8t) for the load of Pf.11, I somehow missed the fact, that it is arched, not flat...
-I scratchbuilt one(AFV Club's Assault Bridge was used as refference) and mounted it on the trailer:
As to finishing my subjects-I'm still waiting for the Weathering Muse to drop by...
