Armor/AFV: Axis - WWII
Tamiya jagdpanther wm gun
OleSaeterboe
Norway
KitMaker: 30 posts
Armorama: 20 posts
Posted: Monday, May 20, 2019 - 06:06 AM UTC
Can this gun be used on the Tamiya King Tiger?
m4sherman
Arizona, United States
KitMaker: 1,811 posts
Armorama: 1,762 posts
Posted: Monday, May 20, 2019 - 07:56 AM UTC
I'm not sure what you are asking. Do you have an after market barrel you are trying to use?
TopSmith
KitMaker: 1,563 posts
Armorama: 1,488 posts
Posted: Monday, May 20, 2019 - 08:03 AM UTC
Yes, which barrel were you trying to fit to the Ktighr?
OleSaeterboe
Norway
KitMaker: 30 posts
Armorama: 20 posts
Posted: Monday, May 20, 2019 - 08:24 AM UTC
I mean the Tamiya wm gun for the Tamiya Jagdpanther.
TopSmith
Posted: Monday, May 20, 2019 - 12:38 PM UTC
What is a wm gun? Did you mean an aftermarket gun for the Jagdpanther to fit on a king Tiger?
m4sherman
Posted: Monday, May 20, 2019 - 12:51 PM UTC
What scale are you working on? By wm do you mean metal?
If the length of the barrel past the mantlet is the same the barrel should work, but there were several barrel configurations.
OleSaeterboe
Norway
KitMaker: 30 posts
Armorama: 20 posts
Posted: Monday, May 20, 2019 - 01:13 PM UTC
1:35 and wm is white metal.
TopSmith
Posted: Monday, May 20, 2019 - 01:31 PM UTC
A couple of questions.
1. Do you already have the metal barrel or were you thinking of buying one?
2. What companys barrel do you have/want and it's part number.
3. Which King Tiger do you have/want it to go on?
OleSaeterboe
Norway
KitMaker: 30 posts
Armorama: 20 posts
Posted: Monday, May 20, 2019 - 08:23 PM UTC
I`m thinking of buying the Tamiya jagdpanther barrel. I have the King Tiger Porsche turret kit no 35169.
d111298pw
#456
Delhi, India / भारत
KitMaker: 646 posts
Armorama: 630 posts
Posted: Monday, May 20, 2019 - 08:45 PM UTC
I've never seen a white metal gun barrel from Tamiya, only turned aluminium barrels.
The KT kit you are building used the monobloc (one piece) barrel. So, if your WM barrel is also this configuration, then you might be able to make it work.
m4sherman
Posted: Tuesday, May 21, 2019 - 12:08 AM UTC
Link here for reference only!
Most of the early KT's used a one piece barrel:
https://www.ebay.com/itm/1-35-35B20T-RB-MODEL-METAL-BARREL-88mm-for-GERMAN-TIGER-II-PORSCHE-PROMOTE/143242987050?epid=24017950969&hash=item2159f2862a:g:rJYAAOSw-MRbtf2x
There are several other options out there, and say they are for Dragon, but can be made to work on the Tamiya kit. These are a better starting point than a barrel for the JagdPanther.
