Early Aviation
Hosted by Kevin Brant
modelling a crashed AC
Biggles2
Quebec, Canada
KitMaker: 7,235 posts
Armorama: 5,828 posts
Posted: Tuesday, July 23, 2019 - 11:36 AM UTC
I wish to model a crashed WWl aircraft in 1/72 as part of a larger dio. I know 90% of a WWl aircraft is made of fabric covered framework. How to represent that in 1/72 realistically without extensive scratch-building? Looking for a quick and easy yet effective method because I'm lazy!
Are there any tutorials, examples, etc., here?
Chillidragon
KitMaker: 102 posts
Armorama: 68 posts
Posted: Tuesday, July 23, 2019 - 12:10 PM UTC
If the aircraft didn't catch fire or splinter into pieces, you won't need to model the framework. How about a heavy landing - collapsed undercarriage, broken airscrew?
phantom_phanatic309
#372
KitMaker: 2,327 posts
Armorama: 422 posts
Posted: Tuesday, July 23, 2019 - 12:19 PM UTC
I've considered doing something similar myself a few times.
Maybe get a kit of the aircraft you want, chop off the sections you want to display damaged and build up the frame from plastic strip or rod. Painted blank decals could probably make torn fabric but I don't know if it might be too thin? Think about the aircraft your building and what it would be made from. Albatross for example had ply covered fuselages and Fokker used aluminium tubing for the frames of their aircraft.
I saw one done once that used one of Eduard's etch frame kits. Must have required the patience of a saint!
Vicious
KitMaker: 1,451 posts
Armorama: 1,066 posts
Posted: Tuesday, July 23, 2019 - 12:52 PM UTC
some plane like the Albatross was made in plywood and only the wing and tale in canvas
https://forum.ww1aircraftmodels.com/index.php?topic=10327.0
Biggles2
Quebec, Canada
Posted: Wednesday, July 24, 2019 - 03:39 AM UTC
Hmmm...I'll have to wait until I decide what aircraft I want to use, then research it's construction method. I want to do one that has thoroughly crashed. Burnt is an option I'll have to think about. Guess I should also look for pics of crashed planes.
phantom_phanatic309
#372
Armorama: 422 posts
Posted: Wednesday, July 24, 2019 - 06:45 AM UTC
Now this would be good to model!
joepanzer
KitMaker: 735 posts
Armorama: 682 posts
Posted: Wednesday, July 24, 2019 - 01:14 PM UTC
Wow!! Were there captions with that photo? I'd like to know if he got electrocuted?
This may be a silly suggestion but have you thought of tissue paper? It may be silly at that scale, but I found an instructable on a quick way to do it:
https://www.instructables.com/id/Covering-a-model-airplane-in-Tissue/
The article says you can Krylon clear spray it. Then, lacquer it, tear it up.
I agree with a "Hard Landing" approach. Just my opinion, but a crash would be just that in this case. Think F1/Indy Car vs NASCAR when they crash into an immovable wall at 200mph.
Don't forget the cables. Those things had a mess of them.
JackFlash
KitMaker: 11,659 posts
Armorama: 256 posts
Posted: Friday, August 02, 2019 - 07:20 AM UTC
Article on wrecked or derelict WWI aircraft
Here you go. Some image links are broken.
RLlockie
KitMaker: 970 posts
Armorama: 810 posts
Posted: Friday, August 02, 2019 - 07:34 AM UTC
As those are telephone rather than electricity lines, I doubt it. Clearly not a high speed impact though.
And as they say, any landing where you can walk away is a good one. If you can use the airplane again, itís a great one.
Tanksami
Victoria, Australia
KitMaker: 1,288 posts
Armorama: 1,200 posts
Posted: Friday, August 02, 2019 - 02:20 PM UTC
What type of aircraft is in the wires? It looks cool
CaptnTommy
Connecticut, United States
KitMaker: 421 posts
Armorama: 10 posts
Posted: Monday, August 19, 2019 - 10:41 PM UTC
1. draw a line where you want any damage.
2. Start small, bend a wing, knock off an engine. dent a leading edge.
3. for fabric use the thinnest aluminum foil you can find. I have found candy bar foil is about the thinnest.
4. doped linen is stiff, get a piece of bed sheet and clear spry paint see how it bends and wrinkles when painted.
7. talk to a RC modeler or go to a club meeting or flying field and ask if any one has crash pictures.
8. always have fun.
Captn Tommy
