Cars: Other Racing
For automotive racing topics not already covered.
Hosted by Joel Willstein
Revell 1/25 Roush IMSA Trans Am JPS Mustang
RussellE
#306
Victoria, Australia
KitMaker: 3,423 posts
Armorama: 1 posts
Posted: Thursday, October 24, 2019 - 04:07 PM UTC
Joel! This is a massive turn around from the original plan!
But if anyone can do it, you can
Hwa-Rang
Kobenhavn, Denmark
KitMaker: 6,618 posts
Armorama: 1,339 posts
Posted: Thursday, October 24, 2019 - 08:18 PM UTC
Amazing decal work Joel. The color combo works just as well on the IMSA Mustang, as on the classic Lotus JPS F1's. Beautiful.
Dixon66
New Hampshire, United States
KitMaker: 1,058 posts
Armorama: 285 posts
Posted: Friday, October 25, 2019 - 12:12 AM UTC
Looking great. Cannot wait to see more.
Joel_W
AUTOMODELER
KitMaker: 10,696 posts
Armorama: 1,143 posts
Posted: Friday, October 25, 2019 - 01:50 AM UTC
Russell,
I'm glad that you like my efforts to date. Now comes the actual build, as all I've done is paint the chassis, pan, and tube frame.
Joel
Joel_W
AUTOMODELER
Posted: Friday, October 25, 2019 - 01:54 AM UTC
Jesper,
Thanks my friend for those really kind words. I've got to admit that I've always had a soft spot for the JPS sponsored cars. I even managed to build the JPS Lotus 72E
Joel
Joel_W
AUTOMODELER
Posted: Friday, October 25, 2019 - 01:55 AM UTC
David,
Thanks so much for stopping by, and appreciating my efforts to date. Now the really hard part of the build starts: the actual build.
Joel
Joel_W
AUTOMODELER
Posted: Sunday, November 03, 2019 - 03:59 AM UTC
Well, another week has passed, and it's time once again for my weekly update.
My focus started out with building up the chassis, cockpit, trunk, and engine sections. All the various basic parts for these areas were primed with Mr. Hobby Gray #1500 primer, Then all the parts were painted with Tamiya X-1 Gloss Black. Those parts that needed various shades of Aluminum, Steel, & Polished Steel were air brushed with the proper Alcad 2 color. Some small parts I opted to hand paint with either Testors Bright Silver, or various shades of Mr. Color Metalizers.
The side frames each have various lines that are wrapped in a protective rubberized casing to protect ones hands from being burnt. The color really varies all over the place due to dirt, grime, grease, oil, and what not. Since I found it basically impossible to mask them, I hand painted them with multiple coats of Ammo Mig Matt Red. Still the high spots didn't cover as well, giving the effect of wear & tear. The instructions call out for the oil filter to be painted Red which makes no sense as that's the color that STP used on their products, and Fords usually used AC Purolator filters that were White. A few pictures of Roush Yates Crate V8 motors show White oil filters, so I went with White.
The radiator and housing were glued into position, then the front steering assembly with the rubber boots being painted with Tamiya XF-69 Nato Black for some much needed contrast. Then the dry sump oil tank and battery housing were glued into the rear of the chassis. All the various lines and wires I'm planning on, will be added much later into the build.
I opted to hand detail paint the rear shocks rather then cut them off the frame supports as you won't really see much of them once the rear shell is installed.
Next up I glued both side frame rails to the chassis, which brings up a major gluing issue. Seems that for some strange reason Tamiya Extra Thin just won't melt and join any parts molded in Black. Now these parts don't really feel like, sand, or polish like regular plastic molded parts do. I opted for the smaller parts to use either CA or Gel CA glue. For larger parts like the frame rails where I needed a lot of working time for alignment and proper fit, I reverted to Testors Liquid glue. Worked great. Just like their tube glue from the good old days.
And finally yesterday, I got around to Clear gloss coating the body shells and sides of the chassis pan. I still use Mr. Color C46 Gloss thinned with Mr. Color Leveling Thinner. Only now I changed from a 1:1 ratio to a 2:3 ratio. Two tack coats 5 min apart. Then two wet coats 15 min apart. The 2nd wet coat was applied with a slower pass closely watching how it was laying down, and making slight corrections as needed. Here's 3 pcs of the glossed shells. Nothing has been done to them at all, as I'll give them a full 6 days to dry & cure.
Thanks to all for stopping by, and checking out my build to date. It's always much appreciated.
Joel
Dixon66
Armorama: 285 posts
Posted: Sunday, November 03, 2019 - 08:29 AM UTC
You are really nailing this one Joel. Bravo!
Joel_W
AUTOMODELER
Posted: Sunday, November 03, 2019 - 09:03 AM UTC
David,
Thanks so much for that thumbs up. Still a very, very long way to go.
Joel
AussieReg
AUTOMODELER
#007
Victoria, Australia
KitMaker: 7,060 posts
Armorama: 173 posts
Posted: Sunday, November 03, 2019 - 11:12 AM UTC
Looking great Joel, the detail painting really stands out and gives a clear view of some of the extra lines and items that go into these cars. The clear coat looks to have laid down very nicely, and it has knocked back the vision of the decal surround "ghosting" a lot.
Looking forward to seeing the shell polished out and in place on the pan.
Cheers, D
rdt1953
KitMaker: 996 posts
Armorama: 67 posts
Posted: Sunday, November 03, 2019 - 11:25 AM UTC
Looking good Joel - nice turnaround and save !
The chassis looks like diecast metal in the pictures - is it ?
Cheers - Richard
Stickframe
#362
KitMaker: 1,482 posts
Armorama: 1,196 posts
Posted: Sunday, November 03, 2019 - 05:35 PM UTC
Hi Joel, the mustang sure looks great - body work and chassis. The black body really pops - looking forward to see this pulled together!
Nick
md72
#439
KitMaker: 4,621 posts
Armorama: 278 posts
Posted: Sunday, November 03, 2019 - 07:11 PM UTC
Wow, Joel. That shot down the chassis looks like a real aluminum welded up structure.
Cosimodo
#335
Auckland, New Zealand
KitMaker: 1,441 posts
Armorama: 36 posts
Posted: Sunday, November 03, 2019 - 09:24 PM UTC
Beautiful work Joel.
Now that I have read the whole blog some amazing effort there changing mid-stream. The final finish on the black looks superb with gold decals achieving the painted on look.
cheers
Michael
RussellE
#306
Victoria, Australia
Armorama: 1 posts
Posted: Sunday, November 03, 2019 - 10:49 PM UTC
I can only join the chorus, Joel!
Amazing work
Joel_W
AUTOMODELER
Posted: Monday, November 04, 2019 - 02:07 AM UTC
D,
Your most positive comments are as usual, much appreciated.
I found it pretty difficult to detail paint much of the molded on details as they were pretty soft in some areas. Plenty of touch ups needed. Still, not perfect but it's the best I can do.
As you said, the gloss really did blend in the Matt Black on all the decals. Hopefully, the lip will start to fade once the polishing process starts.
The road to the interior completion sure looks like a long one, but pretty interesting as I'm learning a ton about the Roush Yates V8 Crate engines. The amount of information and pictures on the net is just beyond what I thought I could find. The trick is really the search phrases as different ones bring up completely different results.
Joel
Joel_W
AUTOMODELER
Posted: Monday, November 04, 2019 - 02:14 AM UTC
Cheers - Richard
Richard,
Great to hear from you. I know that even though you don't post much these days, that you're always following my builds no matter how much I screw them up. And yes, this time the save was really needed as I had the wrong body shell for the Folger's car. Only I could accomplish that kind of screw up.
The chassis is my attempt at oxidized and dirty Aluminum sheeting. I primed it with gray not black, then a slight rubbing out to smooth it some what. Then Alcad 101 Aluminum. the effect is what you see. Looks somewhat more realistic in person. The bottom with a million sink holes from the rail moldings on the top took on a life of it's own.
Joel
Joel_W
AUTOMODELER
Posted: Monday, November 04, 2019 - 02:16 AM UTC
Nick,
Much appreciated for those kind words.
Going to be a long haul with the 3 compartments. I'm not in your class when it comes to detailing, but I'm going to add wires, lines, and hoses as needed to give a better presentation. I've also been cutting off molded pcs on front engine plate to make new ones as Revell's moldings aren't even the right shape.
Joel
Joel_W
AUTOMODELER
Posted: Monday, November 04, 2019 - 02:21 AM UTC
Mark,
Thanks for your Thumbs up. I really do appreciate it.
As I explained to Richard, I wanted a slightly different effect to the pan then just Alcad 101 Aluminum over Semi Gloss Black. The effect up close and personal looks way better then in the picture, and does add a little more interest. To bad 90+% of it won't ever be seen, but what is, hopefully will catch the viewer's eye. I used a similar method of the side of the frame that has the Aluminum plate. There I used a Molten pattern of Semi Gloss Dark Gray over the Gloss Black. The idea was to break up the one shade/texture over such a large flat area.
Joel
Joel_W
AUTOMODELER
Posted: Monday, November 04, 2019 - 02:28 AM UTC
Michael,
Thanks so much for your most positive thumbs up, it's certainly greatly appreciated.
I can assure you that I really lucked out with the stripping, and starting from scratch a 2nd time. Usually I'm not that lucky.
Joel
Joel_W
AUTOMODELER
Posted: Monday, November 04, 2019 - 02:32 AM UTC
Russell,
Why thank you my friend. Your thumbs up really means quite a lot to me.
I'm hoping that I can use finer grits of wet emery cloth so that the polish and wax will have a even greater shine and depth to it.
I've really been focusing on tweaking my total gloss painting procedures, especially how I apply the various coats. Finally, the bulb over my head turned on, and it looks like I'm on the right path. Just hoping that the next paint job turns out this well.
Joel
RussellE
#306
Victoria, Australia
Armorama: 1 posts
Posted: Tuesday, November 05, 2019 - 09:42 PM UTC
You are the master of shine, Joel!
I have to admit, I admire your determination and effort. Far beyond what I could muster on my own builds
Joel_W
AUTOMODELER
Posted: Wednesday, November 06, 2019 - 02:22 AM UTC
Russell,
Thanks buddy. I really appreciate your thumbs up.
Joel
rdt1953
KitMaker: 996 posts
Armorama: 67 posts
Posted: Wednesday, November 06, 2019 - 02:35 PM UTC
PM sent - check your inbox
Cheers - RT
Joel_W
AUTOMODELER
Posted: Thursday, November 07, 2019 - 01:38 AM UTC
Rich,
Got it. And thanks.
Joel
