| Subject: M3 Lee Academy help |
 | rjeffs2501 | Location: Virginia, United States Member Since: May 02, 2006
Posts: 120 entire network,
115 this site
| Posted: Wednesday, October 11, 2006 - 10:55 PM BST |
I am working on the academy m3 lee tank and want to put an engine compartment in, does anyone know if anyone makes an m3 engine compartment or would a m4 engine compartment be compatible? also, what desert camo did the US army use in africa? thanks |
| HIDE SIGNATURE AREAS |
 | Sabot | Member Since: December 18, 2001
Posts: 12,273 entire network,
8,813 this site
| Posted: Wednesday, October 11, 2006 - 10:59 PM BST |
An M4 or M4A1 engine compartment would be the same for an M3. It's only a matter of time before someone puts out an M3 engine compartment for the Academy kit, if they haven't done so already.
I believe the standard M3 camouflage pattern in Africa was OD green with white stars. They may have even used yellow stars too. |
115 this site
| Posted: Wednesday, October 11, 2006 - 11:23 PM BST |
do you know if they ever used a desert tan or khaki? I know the british did. |
 | redneck | Location: Pennsylvania, United States Member Since: June 06, 2005
Posts: 1,585 entire network,
384 this site
| Posted: Wednesday, October 11, 2006 - 11:35 PM BST |
I have seen a few pictures of Lees in a sand color (Don’t know the exact color) but it looks like most of them were Green.
I’ve also seen a few in a sand and dark brown camo pattern but don’t know if it was used during the war or not. |
 | ericadeane | Location: Michigan, United States Member Since: October 28, 2002
Posts: 2,472 entire network,
2,423 this site
| Posted: Thursday, October 12, 2006 - 12:48 AM BST |
US M3 Mediums in Africa were either very dusty OD or dried mud smeared on the OD. |
Roy Chow
1st VP AMPS
www.amps-armor.org | | |
 | Pedro |  | Location: Wojewodztwo Pomorskie, Poland Member Since: May 26, 2003
Posts: 905 entire network,
726 this site
| Posted: Thursday, October 12, 2006 - 01:06 AM BST |
British used Lee's in overall sand or sand/green with undersides of hull/barrel in white. For those you'd have to add sandshields, British rails for attaching truck disguise and British stowage boxes (if you want to go for some accuracy you'd have to scratchbuild them anyway as the ones from the box did'n ever existed. Greg |
I'm not a rivet counter! And I'm proud of it !!!
For those about to rock, we salute you!
115 this site
| Posted: Thursday, October 12, 2006 - 01:15 AM BST |
thanks guys! I am doing some research on the net, I usually just build OOTB but I want to be as accurate as possible. |
 | MSGsummit | Location: Tennessee, United States Member Since: November 16, 2002
Posts: 593 entire network,
449 this site
| Posted: Thursday, October 12, 2006 - 01:22 AM BST |
I just picked up the Academy Lee. Just wondering if you have run into any snags or problem areas with the build.
726 this site
| Posted: Thursday, October 12, 2006 - 01:56 AM BST |
For an OOB build only fit issue for me was betwen rear fighting compartment wall (part C9), upper hull (part F1) and part B32. those make for three layers of armour and gives dificulties fitting upper and lower hull assemblys when C9 is properly fitted in place. I removed peice of F1 to make it fit better. I'm still not through with constraction but this semed to be the bigges issue. Cheers Greg |
 | SKiernan | Location: Colorado, United States Member Since: March 11, 2006
Posts: 47 entire network,
46 this site
| Posted: Thursday, October 12, 2006 - 03:39 AM BST |
Robert I just picked up the Academy M3 Lee and was surprised to see the upper hull was not one piece. Are there any fit problems trying to get all the angles to line up Steve |
115 this site
| Posted: Thursday, October 12, 2006 - 07:33 PM BST |
I have'nt started the build yet, did you run into any problems? |
115 this site
| Posted: Thursday, October 12, 2006 - 07:35 PM BST |
Sid Arnold of ABM makes a very nice upgrade for the Lee. It includes an engine module that has just what you'd see thru the screen of the engine deck. [/quote]
is there a web site for this?
2,423 this site
| Posted: Thursday, October 12, 2006 - 08:03 PM BST |
is there a web site for this?[/quote] I don't think ABM has its own website yet. However, Sid sent me the following along with pictures of these. (I've enclosed the photo of the engine pack below): Hi Roy: Thanks for the interest. You can order directly from me - U.S. cheque, money order or PayPal". There are attached jpgs of all 3 items: ABM011 - U.S. Early M3 Lee Delux Update Set U.S. Retail $60.00 Resin 1/35 early production update set (113 parts) for Academy M3 Lee. Includes replacement 37mm gun turret & sub-turret, 37mm & 75mm gun counterweights, corrected 37mm gun mantlet, revised 37mm & 75mm gunner's sights, correctly sized drivers visor, correctly sized hull stowage boxes, partial engine compartment module, early & late style air cleaners, late style exhausts, revised lower hull rear plate, revised engine deck plate, revised front headlights & rear taillights, early/late style sirens, 30 cal. MG stowage brackets, revised tools, Karaya soft copper tow cable, complete replacement suspension system and many other fittings. Suitable for replicating U.S. WW2 M3 Mediums typical of the North African campaign. ABM012 - U.S. Early M3 Lee Basic Update Set U.S. Retail $17.00 Resin 1/35 early production update set (12 parts) for Academy M3 Lee. Includes replacement 37mm gun turret & sub-turret, 37mm & 75mm gun counterweights, corrected 37mm gun mantlet and correctly sized hull stowage boxes. Suitable for replicating U.S. WW2 M3 Mediums typical of the North African campaign. ABM013 - U.S. Early M3 Lee Suspension Update Set U.S. Retail $17.00 Resin 1/35 early production update set (48 parts) for Academy M3 Lee. Includes correctly proportioned and sized suspension bogies, springs, spring bases, return rollers, detailed drive sprockets, idler mounts, positionable idler wheel axles, 3-piece idler wheels. Easy assembly using Academy kit road wheels and suspension arms. Let me know if you want to place an order. Shipping is U.S.$5.90 for one item and $7.90 for 2-3 items. Next 2 releases are ABM014 Grant Delux Conversion Set and ABM015 Grant Basic Conversion set (release date late-October). Cheers Sid Arnold Armoured Brigade Models Ottawa, ON Canada email: sidneya@sympatico.ca |
Roy Chow
1st VP AMPS
 | chefchris | Location: North Carolina, United States Member Since: February 06, 2006
Posts: 977 entire network,
931 this site
| Posted: Thursday, October 12, 2006 - 08:30 PM BST |
Just be careful to line everything up when assemblingthe upper hull. I had no problems whatsoever - I did fix all the rivets, turret, and 2mm too tall bogies. I also used some left-over eduard M3 p/e for the tools ,etc.... Chris |
115 this site
| Posted: Thursday, October 12, 2006 - 08:41 PM BST |
Roy, Great photo and I will keep you in mind if I plan on ordering any of the sets. rjeffs2501@yahoo.com |
115 this site
| Posted: Thursday, October 12, 2006 - 08:43 PM BST |
thanks chris, appreciate the help |
