Dioramas
Any suggestions for Pine trees?
sweaver
Kentucky, United States
KitMaker: 759 posts
Armorama: 410 posts
Posted: Tuesday, May 29, 2007 - 10:40 PM UTC
Hey guys! I am working on my first dio right now. It will be of the Battle of the Bulge, so I need lots of tall evergreens, right. Well, I decided to make my own, so with the help of Lynn Kessler's book "How to Build Armor Dioramas" I'm going to try. I just bought some Woodland Scenics lychen and Dark Green coarse turf, which I hope to use to make the branches.
I first used my Dremel to grind some basswood rods to a point. I hope to drill holes in a spiral up the rod, then glue in wire. Next I'll pull apart some lichen and glue it to the wire, and last, I'll mist the lichen with white glue and water and sprinkle on the turf. It might take several applications.
Is this a good idea, and if so, are there any common pitfalls I need to steer clear of?
As I said before, this is my very first dio, so ALL comments are welcome!
Thanks!
RoelGeutjens
Belgium
KitMaker: 410 posts
Armorama: 383 posts
Posted: Wednesday, May 30, 2007 - 12:33 AM UTC
Hey Samuel
I have a topic on how to make pine trees on my website (you can find it on the tips and tricks page). It's very easy and gives realistic trees. Check it out and good luck
Grtz Roel
rhenders
Arizona, United States
KitMaker: 159 posts
Armorama: 142 posts
Posted: Wednesday, May 30, 2007 - 01:39 AM UTC
Here are some that I made.....
I made them from 1/4"x1/4" balsa stock. I but them in a drill and tapered them done to a point at one end then. Once this was done then I took caspia a dried plant and used those for the branches and needles. It just happened to be dark green in color as well. In the end all looks great! The only thing is that is took about 5 hrs per tree! Good luck...
Kinggeorges
Barcelona, Spain / Espaņa
KitMaker: 1,378 posts
Armorama: 843 posts
Posted: Wednesday, May 30, 2007 - 02:04 AM UTC
Hi Samuel,
I'e just done a pine tree for a small vignette I'm working on.
I second Roel advise : it's a cheap and convincing way to make pine trees or fir. I didn't use a banch of wood as a base, but iron wire put together and cut at the top to make the branch.
Best,
Julien
18Bravo
KitMaker: 6,658 posts
Armorama: 5,604 posts
Posted: Wednesday, May 30, 2007 - 02:35 AM UTC
Google Jack Work trees. Similar to mehods already described using asparagus fern.
Blade48mrd
KitMaker: 1,185 posts
Armorama: 810 posts
Posted: Wednesday, May 30, 2007 - 02:44 AM UTC
Samuel -
Roel, Robert, and Julien have some outstanding examples and advice for 'evergreens'. I'd stay away from the lichen and use dry flower/plant that are available at Craft stores likes 'Michael's',etc. or check your yard. Remember that not all the trees and areas in Ardennes were lined with 'pine trees'. Try this link for one of the best references to 'Bulge', more particularly Peiper's Kampfgruppe sSS PzAbt 501, but has great photos (see below taken from Peiper's 'advance' route:
http://www.ss501panzer.com/index.htm
Blade48mrd
sweaver
KitMaker: 759 posts
Armorama: 410 posts
Posted: Thursday, May 31, 2007 - 03:50 AM UTC
Thanks for the advice!
How would I make deciduous trees? Weed roots? Sticks?
Grumpyoldman
Staff MemberConsigliere
KITMAKER NETWORK
KitMaker: 15,328 posts
Armorama: 7,293 posts
Posted: Thursday, May 31, 2007 - 04:52 AM UTC
Hi Sam
Here's a few articles that may help:
Simple Trees
Making Tree Stumps
Hybird Tree Creation
Super Tree or Super Nuts?
Making Trees With Wire
Making Palm Trees
and:
Building Young Evergreens
sweaver
KitMaker: 759 posts
Armorama: 410 posts
Posted: Friday, June 01, 2007 - 08:25 AM UTC
Those were some great articles, especially the last one.
