Commonwealth Thunder!
GregCloseCombat
KitMaker: 2,408 posts
Armorama: 2,394 posts
Posted: Thursday, July 25, 2013 - 04:53 PM UTC
Ben - sounds good. Looks like a great kit.
Rick - hope you get in. You always do top work
I just painted on some tracks and wheels with thinned tamiya paints.
Thundergrunt
KitMaker: 657 posts
Armorama: 481 posts
Posted: Thursday, July 25, 2013 - 04:58 PM UTC
@ Bear Of course you can get in on the build just enlist in the campaigns section and welcome aboard, Grest subjects here as well as the modelers..Ill be asking you some sherman questions I know..
@ Ben I am an Aircraft guy also and just ventured this way and and went from 1 kit to 20 in about a month, and just completed my first armor build for the shermans GB. it is great fun still learning how to assemble it a good order a little bit different than A/C and then try some weathering. But welcome aboard glad to have you in the campaign just enlist in the Campaigns section and we look forward to your build.
@ Greg Hows the knee coming along. Your Dio is looking awsome, I was going to do a sherman for this GB but after seeing you Cromwell I may do that one in stead great work my friend.
thebear
Quebec, Canada
KitMaker: 3,960 posts
Armorama: 3,579 posts
Posted: Thursday, July 25, 2013 - 11:55 PM UTC
I'm in !! Okay only problem is the pictures are going to be Iphone pictures since my camera is somewhere in a box 5 hours from here but I'll do my best..
The Cromwell is a great kit and if you want something different Bison has some great decals ... I built it a few years ago .. I would suggest the PE set by Tamiya for the kit (or any other if you want more but the grill is the most important part.
I loved that build
Rick
thebear
Quebec, Canada
Posted: Saturday, July 27, 2013 - 04:50 AM UTC
Well just to show I did't have too much done ..Here are my in boxish pictures..
This is one thing I've done was remove the three rectanglular plates on the intakes ..You can see the before and after in the picture.. Those plates seem to be post war modification..
And last picture is the front plate of the turret as it comes in the kit...I'm going to sand off the bulges and maybe add the casting numbers to this part. pictures to follow ..Sorry for the bad pictures..
Rick
GregCloseCombat
Posted: Saturday, July 27, 2013 - 07:48 AM UTC
Thanks Eugene. Go for the Cromwell. The flat bolted sides has great appeal I think.
thebear
Quebec, Canada
Posted: Monday, July 29, 2013 - 08:50 AM UTC
Sanded off the bulges on the front of the turret and added the casting numbers .. I put on a coat of mr. surfacer but will add the final coat when the whole turret is put together ..
Next on my list to do are to remove the blobs on the side of the turret and replace them with wire attachment points...remove the bolts on the rear hull ..these were added later to be able to convert any Churchill into a Croc more easily .. removed the bolts and supports just infront and below the round side hatches ..These too were added to the later Mark VIIs.. After that it should be smooth sailing ..
Rick
SgtRam
Staff MemberContributing Writer
AEROSCALE
#197
KitMaker: 3,971 posts
Armorama: 2,859 posts
Posted: Monday, August 19, 2013 - 11:57 AM UTC
Liking the look of this all, some great looking builds happening. Well I am close to completion of the build, and think I am ready for paint and primer.
JScicluna
Tasmania, Australia
KitMaker: 77 posts
Armorama: 52 posts
Posted: Monday, August 19, 2013 - 05:35 PM UTC
Well finally decided to upload my project. I will be modelling a Staghound in Normandy. I started this on the 01st June 2012 however have since become side tracked on the diorama.
[URL=http://s1348.photobucket.com/user/j101s82/media/P1000593_zpsaa5af0a9.jpg.html]
[URL=http://s1348.photobucket.com/user/j101s82/media/P1000598_zps3e9a94f9.jpg.html]
I was planning on building OOB (First time using PE however after priming I have decided to add stowage. The Legend set arrived yesterday in the mail now all I have to do is find time to add it prior to painting.
[URL=http://s1348.photobucket.com/user/j101s82/media/P1000601_zps56208c74.jpg.html]
and lastly a quick peek at the base
[URL=http://s1348.photobucket.com/user/j101s82/media/P1000600_zpsabaa0985.jpg.html]
I am currently working on some US Airborne troops as part of the special forces campaign to add to this diorama
GregCloseCombat
Posted: Monday, August 19, 2013 - 05:50 PM UTC
Kevin. Great Churchill. Should be fun to paint
Jimmy. Nice going. I'm doing one of these in 1/48 for the rapid recon campaign and I'm jealous you have all those little parts done already.
Delbert
#073
KitMaker: 2,659 posts
Armorama: 1,512 posts
Posted: Monday, August 19, 2013 - 10:29 PM UTC
Hi Everyone
Thought I'd post some more progress photos.
Got the hull mosty done on my M-10 Achilles, the rear plate required a lot of holes to be filled as it is set up for the tools in either the British or Canadian configuration.
I'm using a P.E. Antenna set I picked up for this one, and I think it will add value to the kit.
later
Delbert
thebear
Quebec, Canada
Posted: Friday, August 23, 2013 - 01:03 PM UTC
Nice work guys ..
Rick
IamTJones
Niedersachsen, Germany
KitMaker: 128 posts
Armorama: 125 posts
Posted: Friday, August 23, 2013 - 01:09 PM UTC
Got some more work done on the Bishop, loving the detail on this kit!
thebear
Quebec, Canada
Posted: Sunday, August 25, 2013 - 09:26 AM UTC
Got a bit done on my Churchill.. I've backdated the turret by sanding the bulges off the front plate ,changed the cupola for the earlier type.. I've also added a new vane sight, changed the molded on lumps on the sides of the turret by drilling holes and adding wire and the casting numbers ...
Started to add the PE from Eduard..
I added the mud scrapers from a AFV Club AVRE kit..
And that's about where I'm at for now ..
Rick
GregCloseCombat
Posted: Sunday, August 25, 2013 - 03:07 PM UTC
Delbert. Keep it going. TDs are cool!
Tristan. Clean fit to that kit
Rick. Off to a flying start
I'm working a few other campaigns as we all do so hope to have something next time
shorty53
#330
KitMaker: 175 posts
Armorama: 72 posts
Posted: Monday, August 26, 2013 - 08:49 PM UTC
Have completed the build on my M3 Grant. Next step to undercoat.
ltb073
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Thursday, August 29, 2013 - 12:11 PM UTC
Some nice looking work here guys
Im not ready yet to start my build but I pulled it out of the stash anyway
I know there is a problem with the boggies on this kit but I'm not a rivet counter so I can over look that
I will try to reproduce this paint scheme
looking forward to getting started soon
thebear
Quebec, Canada
Posted: Thursday, August 29, 2013 - 09:43 PM UTC
I think by the time that kit was brought out Academy had fixed the suspension problem ...But I might be wrong..lol
Rick
ltb073
Posted: Thursday, August 29, 2013 - 11:02 PM UTC
Rick
Rick the review that I read on PMMS by Terry Ashley said that the boobies were the same incorrect ones that came with the Accademy M-3Lee kit, but like I said I can overlook that and move on
IrishGreek
Michigan, United States
KitMaker: 627 posts
Armorama: 571 posts
Posted: Sunday, September 01, 2013 - 05:36 AM UTC
Would an M10 Achilles qualify? If so, I will enlist, although I am a little late
thebear
Quebec, Canada
Posted: Monday, September 02, 2013 - 02:51 AM UTC
Hi John... Delbert is building one so I'm sure you are good to go ...Have fun sir!
Rick
We want pictures!
IrishGreek
KitMaker: 627 posts
Armorama: 571 posts
Posted: Monday, September 02, 2013 - 03:27 AM UTC
Thanks Richard! So here are my two starting shots...
And a closeup of the date, on Comp screen:
Started on the bogies last night... hope to have some pics soon
steph2102
Isere, France
KitMaker: 735 posts
Armorama: 606 posts
Posted: Monday, September 02, 2013 - 06:23 AM UTC
hello, here is my entry into the campaign.
steph
SaxonTheShiba
KitMaker: 1,233 posts
Armorama: 557 posts
Posted: Monday, September 02, 2013 - 06:57 AM UTC
Richard, that is a sweet looking Churchill so far. Attached is my entry for this campaign.......a Dragon Firefly and it will be in Polish Markings.
Best wishes,
Ian
SgtRam
AEROSCALE
#197
Posted: Monday, September 02, 2013 - 07:32 AM UTC
Churchill has been painted, I went with an SSC No. Khaki Green mix I got from the internet, 3 parts Tamiya Olive Drab and 2 parts Tamiya Desert Yellow. I do like the way it came out.
The exhausts are being treated with True Earth Burnt Out effects, and I will add a little pigment when done.
thebear
Quebec, Canada
Posted: Tuesday, September 03, 2013 - 11:08 AM UTC
Nice work Kevin ...And to the rest of you ..Let's get building!!! This place is starting to move ..Have fun guys .
Rick
