Scratchbuilders!: Aircraft
This is a group for aircraft scratchbuilding questions, topics and projects.
Hosted by Mike Kirchoff
want to scratch build a cockpit
bowlpuncher
KitMaker: 65 posts
Armorama: 15 posts
Posted: Wednesday, October 17, 2018 - 01:13 AM UTC
I have an old Hawk 1/48 scale mig15 and ti's cockpit is little more than a plastic slat the pilot sits on. I want to make the floor, front panel the seat I. I just help getting started. how do you match the contours of the model kit? I know I might be able to find a resin pit but I want to do this on my own.
Grauwolf
#084
Quebec, Canada
KitMaker: 2,323 posts
Armorama: 639 posts
Posted: Wednesday, October 17, 2018 - 04:17 AM UTC
Use a contour gauge.
https://www.amazon.ca/General-Tools-Contour-Gauge-Duplicator/dp/B00004T7RA/ref=asc_df_B00004T7RA/?tag=googleshopc0c-20&linkCode=df0&hvadid=292938355125&hvpos=1o1&hvnetw=g&hvrand=15671326695306889146&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1002604&hvtargid=pla-575181970552&psc=1
18Bravo
KitMaker: 6,702 posts
Armorama: 5,644 posts
Posted: Wednesday, October 17, 2018 - 06:12 AM UTC
I use a contour gauge on larger things. Mine certainly would not fit in a 1/48 cockpit. I'd just stick a ribbon of putty against the fuselage wall. slide it back and forth to remove it - don't pull it straight out or you'll deform it. Now you've got the contour that you can trace around. Alternately, use a piece of A+B hardenable putty. Coat the fuselage with a very light film of oil, and form the putty against it. When it hardens, pull it off. Again, a contour you can trace around. And if you've already got putty lying around, it costs you nothing extra.
kevinekstrom
Illinois, United States
KitMaker: 67 posts
Posted: Tuesday, December 25, 2018 - 12:52 PM UTC
I have this exact gauge and it will work fine on 1/48.
