Armor/AFV: Allied - WWII
Meng M4A3 pictures.
m4sherman
Arizona, United States
KitMaker: 1,866 posts
Armorama: 1,808 posts
Posted: Friday, August 30, 2019 - 02:00 PM UTC
Nonetheless, it still looks amazing. Good luck on this.
I think it's a good kit, thanks.
m4sherman
Posted: Friday, August 30, 2019 - 02:05 PM UTC
Doesn’t the kit come with a metal barrel?
Dan
From what I understand a limited number will come with a metal barrel, the first 1,000 I think.
That barrel, and the kit plastic parts, are the standard barrel with the thread protector, or can be made with the muzzle brake.
I am building a very early 'A3 with a non-threaded barrel.
m4sherman
Posted: Saturday, August 31, 2019 - 06:16 AM UTC
Comparing the Asuka and Meng hulls. Not much difference, however the Meng hull shell is one piece. The final drive is also slide molded, which makes it much easier for the builder.
The three hulls, Asuka, Meng and RFM. The Meng hull has some fine details the the RFM does not, but I wish Meng had made the hull the same way Asuka and RFM did theirs.
While the lower hulls of both Asuka and Meng are nearly the same there is a difference with the gap for the final drive in the upper hulls. The Asuka and RFM are slightly wider than the Meng, about .030 (.8mm), or .015 (.4mm) on each side. This is because the Meng bolt strip part of the final drive is that much narrower than both Asuka and RFM.
m4sherman
Posted: Saturday, August 31, 2019 - 12:33 PM UTC
Moving a little slow today, drugs for my bad tooth are making me groggy. None the less I have been doing more comparisons. I checked the final drive covers of the three kits and all are in a fraction of the others, except the bolt strip. The RFM is the widest at about 46mm, the Asuka and Meng are about 45mm, with the Asuka being a fraction wider.
Sleepwalker71
Singapore / 新加坡
KitMaker: 265 posts
Armorama: 186 posts
Posted: Tuesday, September 03, 2019 - 08:02 PM UTC
Dan
It seems I was lucky. My kit has a metal barrel.
m4sherman
Posted: Wednesday, September 04, 2019 - 12:05 AM UTC
Dan
My kit has the metal barrel. After looking closer the kit has a plastic end for the unthreaded barrel. The muzzle brake is not intended for use with this version, so there is another version coming. Hopefully Meng will do the 75mm and 105mm versions.
m4sherman
Posted: Friday, September 06, 2019 - 03:34 PM UTC
Well I had a tooth pulled, and after more drugs I got a little done. Finished the boogies. Added the missing bolt heads and the spring adjusters.
Not much done on the hull and turret. I made the smoke thrower pipe from scrap metal tube.
m4sherman
Posted: Saturday, September 07, 2019 - 04:09 PM UTC
Started adding some turret details. For the extra lift ring I used a left over part from an Asuka kit, and I think the 50 cal barrel holder from Asuka is much better. The left side disc at the rear of the turret top is supposed to get a ring per the kit. Pictures show only a center bolt and a smaller bolt mid way to the front, so I filled in the locating hole. The hole for the antenna looked too large so I filled it in. I have a Panzer Art metal antenna base to use.
m4sherman
Posted: Sunday, September 08, 2019 - 12:10 PM UTC
Decided to see how the Meng tracks work, with a twist. I don't like the rubber chevron, so am adapting a Bronco metal chevron set. Both track pads are the same size. I am using .020 (.5mm) brass rod. The tracks fit the sprockets as well as others I have tested. The extended end connectors fit well and look ok.
m4sherman
Posted: Friday, September 13, 2019 - 04:34 PM UTC
Slow progress, with the tracks almost done. I want to get the suspension on before adding the last lengths. Started adding hull details. So far everything still looks good, just the rear hull plate to deal with.
bat_213
Canada
KitMaker: 110 posts
Armorama: 95 posts
Posted: Saturday, September 14, 2019 - 11:03 AM UTC
your build is looking very nice ,well done .
panamadan
Minnesota, United States
KitMaker: 1,513 posts
Armorama: 1,449 posts
Posted: Sunday, September 15, 2019 - 01:07 AM UTC
Very good
Dan
