Armor/AFV: Modern Armor
Modern armor in general.
Building the M9 ACE from TAKOM
OldWarloke
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Tuesday, June 02, 2020 - 08:19 AM UTC
Sorry - jumping in late here - as to the issue of loose drive sprockets; if the vehicle interior will allow, I will drill out the sprocket axle holes in the chassis tub and run that piece of plastic rod all the way across the vehicle for even more support for the sprockets. (Especially on Shermans! I wish I could do the same for the Sherman rear idlers but alas no.)
I'm confused? You realize this isn't a Sherman ?
On this vehicle you could cut off the mount and use a shaft all the way across the lower hull. The thing with the sloppy sprocket fit was just an easy fix, as the Sprockets on this kit were desighned to get glued on.
The Track whyle being workable keeps comong apart and is best glued together.
Regards.
Donald
Ps. The inside of the sprocket just has a thin back wall and nothing to mount a shaft to.
tanknick22
KitMaker: 1,139 posts
Armorama: 1,100 posts
Posted: Tuesday, June 02, 2020 - 10:47 AM UTC
Man the instructions really suck on this kit.
They aren't clear where B5 goes, Here is how it goes.
This above is the engine cover.
If you don't install C33 & C34 first before the small armor plates you'll never get them in.
Trim to fit as shown.
Nice build im thinking about building one I have one question did the Army upgrade theirs to the M9A1 like the Marines did or was it just the Marines that did the upgrade?
OldWarloke
Posted: Tuesday, June 02, 2020 - 12:53 PM UTC
Sorry, I just build them . I have no info on any over variants.
Donald
165thspc
#521
Kentucky, United States
KitMaker: 9,465 posts
Armorama: 8,695 posts
Posted: Wednesday, June 03, 2020 - 02:43 AM UTC
I am implying that a shaft all the way thru might support the drive sprockets even better on this vehicle - then as an aside I said that I have encountered a similar problem when installing the drive sprockets when building numerous Sherman kits.
OldWarloke
Posted: Thursday, June 04, 2020 - 07:41 AM UTC
Installing the Dozer Blade
OldWarloke
Posted: Thursday, June 04, 2020 - 07:46 AM UTC
Now for the Camo. & periscopes.
Donald
OldWarloke
Posted: Saturday, June 06, 2020 - 02:20 AM UTC
The Final Construction Pic.
OldWarloke
Posted: Saturday, June 06, 2020 - 02:21 AM UTC
Now the Finish Pics.
OldWarloke
Posted: Saturday, June 06, 2020 - 02:25 AM UTC
OldWarloke
Posted: Saturday, June 06, 2020 - 02:29 AM UTC
OldWarloke
Posted: Saturday, June 06, 2020 - 02:33 AM UTC
OldWarloke
Posted: Saturday, June 06, 2020 - 02:37 AM UTC
This build was a lot of fun.
Highly recommend it.
Regards.
Donald
Here's a link to all the Pics.
https://1drv.ms/u/s!ArouE_A-TfGGga8dRpYR0-pqAx_DSw?e=rTto44
Next coming up is Trumpeters BREM-1 Russian Armored Recovery Vehicle based on their T72/T90
RobinNilsson
Staff MemberTOS Moderator
KITMAKER NETWORK
Stockholm, Sweden
KitMaker: 6,693 posts
Armorama: 5,562 posts
Posted: Saturday, June 06, 2020 - 02:48 AM UTC
Sorry for not paying attention for a littlw while.
In your step #58 where you installed covers.
I am afraid I have some bad news ...
This image comes from a walkraound over at PrimePortal
http://www.primeportal.net/ce/dieter_mueller/m9_ace/index.php?Page=1
The covers should butt up smooth against that mounting edge. Some plastic strips, maybe a little putty and some careful sanding should fix it.
OldWarloke
Posted: Saturday, June 06, 2020 - 02:57 AM UTC
Hey be that it may, the cover in the kit was made in one piece.
I'm not one of the EXPERTEN it's good enough.
Donald
bat_213
Canada
KitMaker: 110 posts
Armorama: 95 posts
Posted: Friday, June 19, 2020 - 12:22 PM UTC
your build looks great.
